Question about Sony CFD-ZW755 Radio/Cassette/CD Boombox
Radio plays with batteries but when power cord is used the display says check battery.
  • 11 more comments
  • Terry Holmes May 29, 2011
    I called Sony and they had me do that too. It still says check battery.
    Sony mentioned nothing about reprogramming anything. The only thing they mentioned was a replacement for about $80 plus shipping. When done I could get a new one cheaper. That is not a good fix. What mechanism needs to be reprogrammed? Mechanisms are mechanical not electrical.
    It's five years old. My daughter was running a CD and it quit. She thought it was completed so she pushed the radio button and it displayed "check battery". So unless I can fix the part that tells the unit to play the radio using house current we will have to throw it away. Anything else would cost to much.
  • Terry Holmes May 30, 2011
    The radio was purchased new by my daughter's school five years ago. She teaches LD kids and was playing a CD for her class. when it finished she put in the second CD and got the message "check battery. There were never batteries ever in the radio.
    Her Information Services guy told her to take it home and put the three AA and six D batteries in the box. After doing so the radio worked without the cord. When the cord was put in it again said "check battery". The batteries have been out again over night and again it displayed the message "check battery". I just finished doing it again and this time the display showed
    "- - : - -" no sound no nothing.
    Nothing was spilled; the box is immaculate. The cord is like new; no shorts, no burns. I have opened the box and removed the switching unit with the transformer and it looks perfect. All the diodes are on the board are ok.
    I have a Gardner Bender GDT-11 multimeter. I don't capacitor checking capability though. All solder joint look good. How do you attach a photo if need be?
    And there are no split parts, loose wires, black spots.
    The cord registers .5 ohms on both sides. Dropped to this value relatively quickly.
    Looks like I only have capability to change the size of the writing box.
    Since there were never batteries in the radio before this message came on the first time it is like new inside.
    Recall that the box was always used with the power cord never with batteries. Only after the message did batteries ever get put into the box.
    There are seven diodes, a fuse, and 6 capacitors. The capacitors are all the same 223K's (.022 micro-farads). None of them has over heated. The diodes are ok. If I have to unsolder the capacitors to check them it will have to wait until tomorrow. We have to meet our appointment at five o'clock.
    The fuse was the first thing I checked.
  • Terry Holmes May 31, 2011
    I was thinking about this over night and I have concluded that it is inappropriate to start unsoldering components to check them at this time. Why aren't we checking the voltage at the five pin connector on the power board first?http://esi.sony.ca/esupport/esupport/CD%...
  • Sony Master
  • 3,018 Answers
  • Unplug the unit and remove the batteries and wait for 2 full minutes. Then using the cord only and leaving the batteries out, plug it in and see it the unit works properly.
  • This is a test I am having you do. So if it does not fix your problem then just leave a comment as to your findings and I will respond.
Regards, Tont
Posted on May 30, 2011
  • 8 more comments
  • Iron
    Iron May 30, 2011
    She used this at a school you say? Did anything get spilled on the stereo at all? Even just a little? Can you inspect the power cord used for the socket to feed power to the stereo? Tell me if there are any cracks or rips and look at the end of the tip and tell me if it is burnt (the metal contacts on the very very tip of the end of the cord) If it works with the batteries but messing up with the cord then this has to do with the cord or the circuitry used from the cord power feed. The smaller batteries are for memory and the bigger batteries are for the actual powering of the stereo.
    Tony
  • Iron
    Iron May 30, 2011
    • If a diode was bad it would probably throw the breaker. The transformer not melted so that's a good sign. Do you see any loose wires by ac power feed on the circuit board? Do you see any electric components split? Any cold soldier joints on the board? Any black spots? Do you have a multi meter? If the cord is good, and their are no cold soldier joints and no split parts then it's time to start pulling and testing electrical components.
    Tony
  • Iron
    Iron May 30, 2011
    • You can sort of check capacitors with a multi meter. True a capacitance meter will tell you the capacitance but you can test for short, open, leaky and functioning with a multi meter. Capacitors store some good energy. Exorcise caution when fooling with them.
    • Remember this is AC no DC the unit must remain off the power feed until back together.
    • As for up loading pics, from your end I am not sure, on my end there is a little are at the bottom of where I am typing fro "links, pictures and You Tube upload." You click the word "picture" and then choose from where on your pc.
    • How does that power cord test with the multi meter? Throw the meter on ohms and test from one plug end to the same side on the end where it plugs into the radio. Test both and tell me the readings. Also, not if it goes up and then drops right away please.
    Tony
  • Iron
    Iron May 30, 2011
    • If you have a photo bucket you can just link me to a pic if you upload it there. Just an idea. In looking at the manual for this stereo it does not indicate anything for the "check batteries" but to check the batteries. Is there any corrosion around the terminals? How about on the inside of the radio in that area? As I think here, cord looks good, only ever used batteries, says check batteries. It's like something in the battery area is effecting the other power feed or the general function of the radio when not using the batteries. By a short or something is effecting that area. How does the battery area look? The board by the battery case?
    Regards,
    Tony
  • Iron
    Iron May 30, 2011
    • OK, so you want to pull the parts around the AC power feed, where the cord plugs in, and check them. You have a diode check at the bottom of your multi meter. Polarity should read one way only and not the other. Resistors will read on ohms. Capacitors read through the ohm side of a multi meter.
    Tony
  • Iron
    Iron May 30, 2011
    To test capacitors they must come clean out. And the other components 1 leg must be removed but I prefer to completely remove each part and re-solder so as not to break a leg. Pay attention to how the components are in before removing. While resistors can go in either way, the other components can't
    Tony
  • Iron
    Iron May 30, 2011
    • Capacitors can give false readings if not un-soldiered. Did you check the fuse by chance? If all checks good in that area you will need to move on to the rest of the board. 1 piece at a time. Something is malfunctioning in there and a piece at a time is how I would have to do it if it were here in front of me as well.
    Regards,
    Tony
  • Iron
    Iron May 30, 2011
    I kind of figured but I have to ask.
    Tony
  • Iron
    Iron May 30, 2011
    • Without the schematic or radio in front of me I can't see the layout of the radio so I have to mention anything that comes to mind. I don't want to miss something simple after having the radio in pieces. Some tend to think I am overly thorough but I don't think there is such a case. If I should suggest something that seems silly please understand I have seen it all in my day and I just don't want to leave any stoned un-turned. But I will help you get the stereo running. It is fortunate you can use a multi-meter as many don't and then it's really difficult if not impossible to aid in an internet repair. I am on every day from 1400 to 0200 hrs.
    Regards,
    Tony
  • Iron
    Iron May 30, 2011
    1400-0200 central time USA.
    Genius:
  • 1,196 Answers
Connect the power cord to the radio without the batteries inside, i mean remove the batteries from the radio, and see what it will display.
Posted on May 29, 2011
  • Ishola Olayemi May 29, 2011
    Good, This shows the mechanism on the radio are not well programmed, there is factory defect on the mechanism, i will advice you take it back to them to help re-program the mechanism.
    Of course i know, mechanism are mechanical, what i mean is that, the battery slot might be having partial contact with the electrical power cord parts, which makes it display, check battery. are you out of warranty? If not, let them fix it on this basis.
Package, manuel and receipt were accidentally thrown away and we don't know how to charge the radios. They work, but are running low on battery power! They have a power supply cord that you plug both...
From what I just read on the Cobra website, you may be misinterpreting the battery indicator lights:
My radio keeps showing low batteries
This may simply be a matter of misinterpreting the low-battery indicator. We use two different types of battery indicators:
  1. Battery Level Indicator: This battery indicator is always visible, and has several segments. When all the segments are lit, the batteries are full. When only the last segment is lit, the batteries are almost exhausted.
  2. Low Battery Indicator: This type is usually NOT visible. It only appears when the batteries are low, at which time it flashes on the display to warn you of a low battery condition.
Please note that when you turn on your radio it first performs a display test. Everything on the display will light up for a few seconds, including the Low Battery Indicator. This does not mean that the batteries are low. After a few seconds the display test will end, at which time the Low Battery Indicator should go away.
Here is a link to the Manual for your radio:
https://www.cobra.com/downloads/manuals/PR260WX_MANL.pdf
It is a PDF file, which requires that you have Adobe Reader or equivalent installed on your computer for it to open and display properly. If you don't have it, it can be found here (it's free!):
http://get.adobe.com/reader/
Jul 16, 2011 | Cobra microTALK PR 260-2 WX Two Way Radio
The alarm display in the lower right corner on model #RC40-A keeps blinking and will not stop. This happens with both wake 1 and wake 2 options. I fixed it once by unplugging the unit but it this did not...
Hello
Just reinstall the battries and adjust the time once again.
Battery back-up operation
* This clock radio is equipped with
a memory holding system that can
be powered with 2 "AA" batteries
(included). The power failure
protection circuit will not operate
unless battery is installed.
* When normal household power
is interrupted, or AC line cord
is unplugged, the batteries will
power the clock radio to keep
track of time and alarm settings
programmed into memory.
* When the battery backup functions,
the digital display will not light,
however, the function of alarm
still occurs during the power
interruption if remaining battery
power is adequate.
* Normal operation will resume after
AC power is restored so you will not
have to reset the time or the alarm
To install batteries:
1* Remove battery compartment door
(located at the bottom of the radio)
by applying thumb pressure to the
tab on battery door and then lift
the door out and off the cabinet
2* Insert 2 AA batteries (included).
3* Replace the compartment door
Replace batteries every year.
Power is fed to the unit even
when it is not functioning. To
cut the power supply off, the
power cable must be unplugged
OK.
Jul 10, 2011 | RCA Rc40 Clock Radio
How do i change the memory back up battery?
Hello
You can replace the battery without loosing its memory. Follow these instructions. Battery must be changed as fast as you can. So read well and they do the work.
o Bose radio uses a standard nine-volt battery that serves as a backup for the memory and alarm when it's unplugged or when the power is off. It will power these functions for up to three days. Using the radio without the battery won't damage it, but the memory won't be backed up. The battery does not provide enough power for normal operation, including the lighted display.
To install a battery, turn the radio over. Push on the arrow on the battery chamber cover and move it aside. Match the terminals on the battery with their opposites inside the chamber, and push the battery securely into place. Close the cover and return the radio to an upright position.
Connect the power cord to the jack on the back of the radio. The flat side of the connector must line up with the flat side of the jack. Since the power cord contains the FM antenna, uncoil the cord for the best reception. Plug the power cord into a standard electrical outlet.
An FM cable connector is on the back of the radio. Contact your cable company for help in setting up your connection. When you set it up, be sure to use a splitter that separates the FM signal from the TV signal so that the TV signal won't be transmitted to your radio.
If your remote is slotted on the back, press the tip of a pen into the opening and push the battery chamber cover to the side. If there's no slot, push the tab to one side with your finger and open the chamber cover. Use only a lithium battery size CR 2032 or DL 2032. Place the battery into the chamber with the plus sign face-up. Push the chamber cover closed and it will lock.
Mar 18, 2011 | Bose Wave Radio
Have a pro-97 with power probems. I pluged an external power into the unit with battery pack installed. Now have no battery power. What can I do?
first of all I have this radio, and i bought the power cord from radio shack and rechargeable batteries. i left the radio on charge with the yellow battery holder with the right batteries in it in the unit some how there was a power surge and now i cant use the DC power plug but it works fine on batteries so open yours up take out the batteries out and smell if it smells burnt take it to radio shack they can fix it
Jul 08, 2010 | Radio Shack Pro-97 Handheld Scanner
My 20 farad boss capacitor lights up but dont display any volts even when i try to charge it and it suppose to..
OK this just happened to me an i tried something that might work for you all i did was disconnect the main power cord from the battery then double check your wire connections to your fuse then after your done checking the wire connect the power cord back to the battery then start your car up turn the radio on an your display volts should be there
Jul 24, 2010 | Boss Audio CAP10 10 Farad Digital...
We have an Emerson PD6620 Radio/boombox. For many years, we used the AC outlet to play the component. We tried the battery route with new D batteries (8) and the unit did not work. Is there an AC/Battery...
This 6620 has a small micro switch where the a/c power cord plugs in. It will not run on battery power untill you pull the power cord out of the radio jack.
Jun 28, 2010 | Emerson Audio Players & Recorders
I have a bose awrc1p radio display light changes
This could be the battery causing the display to act strangely. If the radio still works audio-wise, the following should fix the display: The older model wave radios have either a 9v or 3 AA batteries (accessible from the bottom). Remove any battery, and reset the system by unplugging the power cord for about 40 seconds. Plug it back in without the battery attached. If the problem goes away- replace the battery or batteries. (which is only there to hold the clock time, presets etc when not plugged in) BTW- you'll have to set the clock, alarm, presets etc after this procedure. If the problem doesn't go away, call Bose. I think they can repair this for $99 and/or offer a new one as a trade-in discounted.
Jun 12, 2009 | Bose Wave Radio
Blank screen
This has happened to my radio several times after I've dropped it. This is how I fixed the problem:
1) Take the radio out of the cradle and let it play until the battery runs low and
the radio can no longer play.
2) Put the radio back into the cradle, plug in the power cord. When it comes on
the screen should no longer be blank.
Aug 25, 2008 | Samsung NeXus 25 MP3 Player
Milwaukee Job site radio
Questions:
1. Does the AC cord look ok? Not damaged?
2. Have you tried another AC outlet?
3. Does the AC cord unplug from the radio?
When you operate the radio from the AC power cord, the radio uses an internal power supply consisting of a step-down transformer, rectifier, and filter that converts the AC to DC to operate the radio.
When you run the radio off of batteries, it powers the radio directly. In some radios, when you plug the AC cord into the radio, it activates a switch that disconnects the battery voltage to the radio so that the batteries wont be damaged from the voltage created by the internal supply.
The radio can be powered by either the batteries or the internal supply. You don't want either supply affecting the other, so that is why a switch is sometimes used.
Since the radio works fine off of batteries, that would indicate that there is a problem with the internal power supply. This could be a blown fuse, bad transformer or bad rectifier diode.
Good Luck,
- Jim
Jan 24, 2008 | GE Superadio III AM/FM
Open Questions:
Sony CFD-ZW755 Radio/Cassette/CD Boombox Logo
216 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
