Question about Remington 16" Electric Chain Saw
Can't locate my manual.. which mixture do I put in my Remmington 16" chain saw- model# 111174-01? Been a while since I operated this equip. Can't seem to download the manual from your site. Craig
  • Remington Master
  • 2,239 Answers
I would run it at a 25-1 fuel oil mix with a good two stroke oil.
Posted on May 29, 2011
Homelite chain saw MODEL UT109460 will not start up I don't have a manuel and need help to figure out why it won't turn on at all.
Hello again Asher, I'm back. Let's just check a few things:
Gas may be old and stale, this happens when you don't use machine for a long while. Empty old and put in new. Cap should have measurement.
If this is a fuel/oil mixture machine, did you use straight gas? Not good if you did. This could damage your engine.
Do you have spark? If not did you move OFF to ON switch?
Did you put on choke and pull cord till engine almost starts?
If it does this did you then put choke to 1/2 choke?
If you get to this point and engine does start, let it warm shortly and put choke to open.
If still no start it is possible that you have a carburator problem, and need a rebuild. Please let me know how you made out, GOOD LUCK.
Oct 22, 2011 | Homelite ZR10926 16 Chain Saw
Poulan " Wild Thing
It is running lean, they always need to run a little on the rich side free running, once the engine is loaded it will then need the excess fuel, it runs ok without the bar and chain because there is no load, start by replacing the fuel filter in the fuel tank, check the fuel hose up to the carb for signs of fuel leakage, replace if reqired, if the carb has standard adjuster screws, increase the H screw by 1/4 turn out ( anto clockwise ) this will richen the mixture.
Aug 22, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the correct fuel/oil mixture for an older Eager ****** 16 inch chain saw?
It really depends on the model number of your Eager Beav er unit. Anything within the last 6 years is 50 to 1 older models can be anywhere from 25 to 1, to 32 - 1 up to 40 - 1. t all depends on the model number.
The usual fuel mixture is 40 - 1 or 3.2 oz. per gallon.
Your chain saw would have to be pre-1995 to use a mixture greater than 40-1. If your chain saw is other than that then use a 32 - 1 ratio. 4.oz per gal.
This is a great fuel mixture calculator:
http://www.csgnetwork.com/oilfuelcalc.html
If you know your model number you can use this page to get an owners / operators manual:
http://www.mccullochpower.com/node7877.aspx
Jun 16, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Fuel mixture for MAC 3200 CHAIN SAW
Mix the oil to gas at a ratio of 50:1.The oil bottle will tell you how much oil and gas you need to get to that mixture.
May 11, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
The chain came off of my Remington 16" electric saw. How do I put the chain back on?
If the saw was at speed when the chain came off there are probably burrs on the chain drive links (the part that goes in the bar). They often cause binding and in extreme case may cause the chain to ride up and off the bar when operated. Use a file on the drive link flats to remove all burrs.
An Operator Manual far almost all models of RemingtonPower chainsaws can be found here:
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
HTH
Lou
Dec 28, 2009 | Remington 16" Electric Chain Saw
Looking for the age of a Remmington model 121
These rifles were made between 1936 and 1954. There is more detailed information about them on the Remington website.
Oct 17, 2009 | Remington Electric Chain Saw
I inherited a approx. 14" Homelite chainsaw from my father who passed away. it is approx. a 1978 model and in good condition...but no owners manual. Using authentic homelite oil,can you tell me what the...
The answer to your question can be found here:
Chain Saw Collectors Corner
http://www.acresinternet.com/cscc.nsf
Click "Chain Saws", then "next page" once, cursor down and select "HOMELITE CORPORATION", keep selecting "next page" until you find your model. A "MIX OIL SPECIFICATION:" appears on the page. the listings on these pages are not alpha numeric. ABC often follows XYZ and 25 precedes 10.
2 cycle oil technology has improved since this saw was purchased. I use Stihl 2-cycle Engine Oil to operate a Pioneer I bought new 1980. My manual says 24:1. It was operated at 32:1 for many years, the last 5± it runs at 50:1. I suggest you run it operate at the mixture recommended by the OIL supplier. HTH
Lou
Oct 09, 2009 | Garden
Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Sep 25, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Putting chain back on remmington chain saw . Can not dowload manual
Lay chain over sprockets and adjust arm to tighten chain.
Sep 11, 2009 | Remington Electric Pole Saw
I am probably in wrong place, but am looking for owner/operator manual for remington electric chain saw...can you help me? Thanks
Posted by lsg2111 on Jul 13, 2009
What is the model number of your saw. It is located on the saw itself. If you can get me that I can try to see if I have that model available
You must help us if we are to help you!
Jul 10, 2009 | Remington 16" Electric Chain Saw
Remington 16" Electric Chain Saw Logo
99 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
