HDMI Interface doesn't work with Samsung blu-ray player. Start-up banner displays on power up for 10 seconds then reverts to "no signal".
  • 44 Answers
First check inside the 2 ends of the HDMI cable to see if there are any bent or missaligned metal contacts. If so then replace the cable with new. If it's good, check inside the connections of the TV and DVD. If good, It sounds like an HDCP problem which is the content protection of the disk. Contact the manufacturer which will have a list of compatible tested DVD players. Also they will have the latest FW for you TV which if possible can be done at home with your computer. Or you could return the DVD player if is not compatible for one that is of the brand recommended. I have seen this a few times.
Posted on Aug 16, 2008
How can I change the language on a sam-sung blu-ray player?
How To Reset Your Blu-ray Player To Factory Defaults (BD-C & BD-D Models)
Page 1
Page 1. Reset Your Blu-ray
  1. Power on your Blu-ray player and tune your TV to the input where the Blu-ray player is connected. For example, if the Blu-ray player is connected to HDMI 1 press the TV input/source/line button to tune your TV to HDMI 1.
  1. Remove any disc from the player and then press and hold the Stop button on the front of the player, not the remote, for about 8 seconds or until the front display reads 'SETUP'. 'Resetting all settings to default values...' is displayed on your TV screen as the Blu-ray player powers off and resets.
    1. The Blu-ray player is automatically powered on after the reset and the select Language screen is displayed.
Aug 16, 2014 | Samsung Televison & Video
Netflix asks for my E-mail address and password every time. I do not have this problem when I stream to my computer, Before asking for this info, it displays the films I have already seen.
After reading through the specs for your player, it doesn't look like it has a native App for Netflix. It may be using a Blu-ray live interface to get you to Netflix that requires authentication every time.
Sorry :(
Hope this helps.
Jun 26, 2012 | Samsung BD-P1500 Blu-Ray Player
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
I just installed an update to my BD-3600 blu-ray. I am "stuck" on the language selection. I'm trying to hit "1" English but nothing happens. what do I do?
Do a reset of the remote and the player:
To reset remote remove batteries and hold power button for 30 seconds. To reset player Power it on and hold the fast forward button down for 10 seconds.
Mar 14, 2011 | Samsung BD-P3600 Blu-Ray Player
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
My samsung bd-p1500 blu-ray player won't play blu-ray discs on regular ones... was having all sorts of troubles with it finally updated the firmware and now it won't play any blu-ray discs
I'm having the same problem. had my Blu-ray and my cable box plugged into my reciever. Blu-ray kept cutting out and not finding a signal while watching my Rome DVDs. I swapped HDMI cables by just switch which cable went out of my blu-ray ( I didn't change what ports they were plugged into on the reciever. That cleared up that problem. I'd assume it was a faulty HDMI cable except that it works fine on the cable box. Anyways, we were watching Iron Man on Blue-Ray and it starts to skip about 2 thirds through the movie. Same as you I updated the firmware, disabled BC-Live, No luck Don't know if the problem is hte Bluray player , the reciever or what. Everything is up to date so I don't get it at all.
Apr 01, 2010 | Samsung BD-P1500 Blu-Ray Player
I have a PS42B541 plasma TV and a 1080P9 DVD player, but the HDMI interface is not working at all. The DVD player is sending the video signal to the TV, but not the audio signal. Also Anynet is not working...
This is a compatibility problem between this model of samsung dvd player and samsung B model tvs. the only solution to fix this problem is disabling anynet option on samsung B model tvs.
Mar 02, 2010 | Samsung DVD-1080P9 DVD Player
I cannot get video signal from my Samsung p1590 Blu Ray player via HDMI to pass through my Onkyo TX-SR606 AV Receiver. I get video if I connect Blu Ray player directly to TV, and have tried all HDMI ports...
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Feb 19, 2010 | Onkyo TX-SR606 Receiver
Samsung BP-1500 problems When I tried to update the F/W to V 2.0 081106_21_XSA.RUF I encountered a problem. I now cannot play any dvd's and my Samsung LCD cannot connect with the player. this is what I...
Just contacted manufacturer with same problem.....your unit needs to be updated....check website...can be done with flash drive or burn a cd
Dec 19, 2008 | Televison & Video
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
