Question about Maax Pearl By CS42wh Pearl CS42 in White
My sensa touch control will not function, the electric controls are not the problem is there something i can do to the sensa switch.
I need a new power cord for my west bend skillet
West Bend Electric Skillet ' eBay
www.ebay.com/bhp/west-bend-electric-skillet
eBayFind great deals on eBay for West Bend Electric Skillet in Electric Skillets. Shop with ... NEW West Bend WB1 Heat Control Sensa-Temp Power Cord Plug Probe ...
Nov 28, 2015 | West Bend Kitchen Appliances - Others
Tip
Acura Electric Window One Touch Control
This tip outlines the procedure to restore one touch control to the electric windows on your Acura following the disconnection of your car battery.<br /> <br /> If you have disconnected the battery for any reason on your Acura you will find that the one touch control feature on your electric windows no longer operates.<br /><br />You can resolve this by following this very simple procedure to reset the one touch control feature and get it operating again thereby saving you a trip to the dealer!<br /><br />1) Start the engine and then push down on the drivers window switch until the window is fully open.<br /><br />2) Pull up the drivers window switch until the window closes fully but keep holding the switch for at least 2 seconds after it closes.<br /><br />3) Auto function should now be restored. Lower and raise the window to check the one touch control.<br /><br />Hope this tip has helped. Please do leave a vote for it. Many thanks.
on Nov 14, 2010 | Acura RDX Cars & Trucks
Tip
Acura How To Restore Electric Window One Touch Control
on Nov 06, 2010 | Acura CL Cars & Trucks
Circuit board fuse blows when the compressor tries to start
If its a standard split cooling system you should have a control wire that connects the indoor unit to the outdoor unit. That control wire has 2(or more) small wires and normally red is the hot(24volt) and white is the common. Power from red may be shorting to ground or touching the metal on something. It could be the wire touching another wire causing a short. Or if the outdoor unit has safety switches such as a low or high pressure switch, the wires to them may have rubbed against the copper tubing inside the unit causing a short to ground. It could be the electrical contactor or any circuit circuit board it may connect to. Most the time I find that the control wire (small wire) will be pulled on or chewed at the outdoor unit. Something can pull on it and cause it to ground where it connects to the unit behind the control panel. Be sure to be safe!!! A bit of experience may be needed. A good tech can usually find a short in 10 mins.
Jun 14, 2015 | Koldfront Ultracool 14,000 BTU Portable...
Why wont my 2001 ford windstar blow out of vents ? only on defrost?
Air Flow Control
Air flow control is accomplished in the following manner:
  • Primary control is through the function selector knob , mounted on the heater function selector switch, which is part of the heater control .
  • The function selector knob has the following positions: OFF, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST.
  • The heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318) . Refer to the System Airflow Schematic and Vacuum Control Charts.
  • An internal single-pole electrical switch is also controlled by the selector. The switch controls the electrical supply to the heater blower motor switch (18578) .
  • The position of the function selector knob determines the manner in which the system will operate.
  • Each position of the function selector knob is detented for positive engagement.
  • You probably have a vacuum leak , Pull heater control panel an check for vacuum . A broke vacuum hose or The vacuum selector valve is bad ! Or check for a vacuum hose in the engine compartment being off somewhere !
Mar 08, 2015 | 2001 Ford Windstar
1997 Ford Taurus front defrost not working
. Air won't blow out of the floor or center vents just defrost ? Do you have manual or automatic climate control ?
Air Flow Control
  • Primary control is through the function selector knob mounted on the A/C-heater function selector switch, which is part of the integrated control panel.
  • The function selector knob has the following positions: OFF, MAX A/C, A/C, PANEL, PANEL/FLOOR, FLOOR, FLOOR/DEFROST and DEFROST. The A/C-heater function selector switch combines a vacuum selector valve with an internal electrical switch.
  • The vacuum selector valve directs source vacuum to various vacuum control motors (18A318). Refer to the Vacuum Control Diagram , System Airflow Schematics and Vacuum Control Chart .
  • Two internal, single-pole electrical switches are also controlled by the A/C-heater function selector switch. The combination of these electrical switches controls the electrical supply to the A/C clutch and heater blower motor switch (18578).
  • Vacuum Control Motors The vacuum control motors (18A318):
    • are located on the A/C evaporator housing, A/C recirculation air duct and heater air plenum chamber (18471).
    • direct system airflow to the vehicle interior as determined by the remote climate control module or manual override.
    • The five-passenger seating configuration has an additional vacuum control motor mounted on the heater air plenum chamber to control airflow to the rear seat A/C register (19893).
Jul 09, 2017 | Ford Cars & Trucks
I need Part no e29583-9907 WB tm #1 control
This was extremely hard to find but I have it here for you, it is on ebay, but I can vouch that it is working fine and in great shape:
http://cgi.ebay.com/WestBend-Sensa-Temp-Heat-Control-WB-1-1500-W-Cord-/360309017863
Oct 12, 2010 | Rival S16 Electric Skillet
Error Message F2 E6
Perform the following actions to fix your error:
Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'Upper Cancel key ' function and wait for 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thank you !!
May 30, 2010 | Whirlpool RBD305PR Electric Double Oven
I have a Maytag in wall oven (part# MEW653ODDS). Only three buttons on the control panel are functioning (cancel, convection bake, and favorites). The oven seems to work properly, but the number of...
HI. This will be the actual control board in this case, that will be the culprit. the control board, and touch pad, are integrated. These symptoms are indicating that the key pad membrane is damaged. This will require you to replace the entire control board. Once the control is replaced, these issues will be corrected.
Nov 03, 2009 | Maytag MEW6530DDS Stainless Steel Electric...
Maax Pearl By  CS42wh Pearl CS42 in White Logo
128 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
