Leaking water, lint clogged
The washer is leaking from the front right corner, just about a pint of water each time.
  • 1 more comment
  • irisblue Aug 16, 2008
    A repairman came for this problem a year ago and said the leak was due to lint blocking the water softener holder. How do I clean the lint out of the softener holder?
  • irisblue Aug 17, 2008
    It's really how to get the lint out that is clogging
    Apparently I have a problem explaining the leak. The front right top corner of washer has a small container for liquid softener. A small hose, about a 1/4 inch in diameter, leads to it. I was told the leak comes from this small container being blocked with lint. How do I get the lint blockage out?
    Genius:
  • 2,920 Answers
Pull the line or hose loose and take a fine wire and push through the line to try to push the clog on through the line.
Posted on Aug 17, 2008
    Scholar:
  • 163 Answers
    Genius:
  • 1,665 Answers
    Master:
  • 623 Answers
Check drain hose for leaks....
Posted on Aug 16, 2008
    Genius:
  • 1,689 Answers
Have you check on the housing of the washer if it has hairline cracks or other holes that may cause this? if not then may we have the brand and model of your washer, so we will be able to find out what to check.
looking forward to your reply
I HAVE A LEAK FROM RIGHT BOTTOM OF A SAMSUNG WF448AAP/XXA-000 FROMT LOAD WASHER ONLY HAPPENS DURING RINSE CYLCE
Hello Harlan;
My name is Peter. I am a retired field service appliance technician.
Your drain hose is in the back on the right hand side. This is a rubber hose. After a time the rubber may be dry rotted and leak or become partly clogged with soap residue.
Once completing the wash cycle the soapy water may have not completely drained due to a partly clogged drain hose by the time the rinse cycle is complete flooding the washer drain pan.
You do not have water in the bottom of the washer because your pump removed it all, but at a slower rate
Ok, Lets fix this ourselves:
1.) On the bottom right front of your washed is a leveling leg.
turn the leveling leg one full turn clockwise. The right front may be pitched down, causing the drain pan level on this corner to be high. Your washer through vibration may have moved slightly. This is not going to solve the problem.
2.) Pull your washing machine out so you can see the drain hose. Run some laundry on heavy load. Observe to see if your drain hose is leaking. Your hose clamps may be loose and require tightening. If it is leaking it needs to be replaced.
3.) Even if your drain hose is not leaking it must be obstructed, flooding the bottom of your unit. This is easily replaced.
The part number for your drain hose is DC97-12534D. It cast about $24.00.
Nov 24, 2014 | Samsung Washing Machines
Landrover Discovery 300tdi 1997 Windscreen Washer Diagram
Hello! The rear washer tubing runs from the reservoir up thru the front corner support column, thru the roof and over to the door. The tubing run from the reservoir to rear door washer jet differs between left and right hand drive vehicles. On right hand vehicles the tubing run is on the left hand side of the roof. On left hand drive vehicles, the right side.
Normally, there is always fluid present in the tubing, thus no priming is necessary and it prevents any clogging... The rear washer jet is is more than likely plugged... Guru...saailer
May 06, 2012 | Cars & Trucks
Water leaks on floor from my p25 washer.
This is a common problem with Malber. On the lower right hand corner, there's a door with a lint filter. This filter needs to be cleaned on a regular basis. Be careful when removing the filter. It has a large rubber gasket that expands when it's installed and tightened and will offer some resistance when removing. When the filter becomes clogged, water backs up and forces it's way out through the filter.
Aug 31, 2011 | Malber P25 Front Load Washer
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
Jul 14, 2009 | LG WM2688H Front Load Washer
LG washing machine wm0532 is flasing an OE
check the drain filter in the bottom left corner behind the access door
Mar 19, 2009 | LG WM-0532HW Front Load Washer
Leaking Washer Machine
this is joyce
This sounds like a center seal kit, they run around $80.00 they are complecated to install so I would suggest getting someone to install for you.
thanks,
joyce
Feb 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
Feb 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
Washer/limt trap clogging causing over flowing
Your machine has a trap, i dont understand the trap in the wall. The standpipe in the wall should be free of anything, which allows the free flow of waste water from the machine; to discharge water at a fast rate.
Plug off the wall, locate the trap -front bottom right side of the machine, unscrew, clean out, be prepared for some water. Refit. The pump-out tube into the wall should be at a particular height, about 3 fee from the ground. And dont push the tube too far into the standpipe.
Oct 15, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
