Question about Vornado Circulating Fan
My vornado is squeaking and runs slow at some speeds
Speed control The speed control isn't working properly. It only goes at high speed. The low and medium speeds don't work. Where can I get a replacement part for the speed control? Thanks.
try to clean the bushing and put some oil if its not work try to replace the capacitor about 2 to 5 micro farad... like this at the bottom...
Sep 12, 2015 | Vornado Silver Swan Table Fan
2005 stratus squeaks in front end over bumps and car shakes when slowing from speeds of 35mph and over
The noise would usually be the strut or the control arm bushings. The vibration could also be the component making the noise, or warped brake rotors.
Feb 25, 2014 | Dodge Stratus Cars & Trucks
Squeaking on Toyota Yaris at slow speed
Service the brake system and check for:
Tyre tread for feather edge.
Worn disc pads.
Warped rotors.
Warped flange.
Jun 12, 2013 | 2007 Toyota Yaris
Hi i have a fan motor vf20 and 220v how many mfd capacitor i must use.
hmm replace it with the same as the original if possible if you cannot find then you can use a Little more higher it will boost the speed of your motor. if you use a little more lesser then it will slow down your motor
Oct 25, 2011 | Vornado VF20 Table Fan
When car is running idle or at slow speeds it makes a squeaking sound
There are several heat shields that can squeak or you could just need a new serpentine belt. Unfortunately, a lot of things can cause a 'squeak' but without knowing what area it comes from, if it changes with engine speed, or vehicle speed, I can't give you any pinpoint information.
Mar 01, 2011 | 2001 Ford Escort ZX2
3 speed standing fan. #1 the blade barely rotates.#2 a little faster. #3 it starts slow then speeds up like it's going to take off. It also makes an annoying sound like it's rubbing on something or is...
It is the motor. Probably needs cleaning and lubrication.
You can send it to Vornado.
It is not hard to get apart, just draw a diagram of what color wire is what speed.
You "could" do it yourself.
Jun 10, 2010 | Vornado Circulating Fan
The air conditioner is making a squeaking noise and blowing cold air but not full strength
The squeaking noise is probably a bad or dry bearing in the fan motor, causing it to run slow or not at correct speed. Sometimes there are oilers on the motor that you can try to oil but the motor really needs to be replaced.
Aug 06, 2009 | Heating & Cooling
Vornado Circulating Fan Logo
325 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
