Question about General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator
I have a GE Model PFSS6PKXBSS, french door, bottom freezer. Below the deli drawer, there is a buildup of water and then it freezes. Water leaks out of the right side of the refrigeator on top of the frezzer seal and then to the floor. I was trying to find the drain to see if it is clogged, but not sure where it is.
SOURCE: deli drawer
Dear Master Tech: The model number is GLRT13TEB3. The problem is every time you try to open the deli drawer it falls straight down.
It is as if the tracks to hold it are too far apart? Also the tracks are part of the glass shelf.
Any help with this annoying problem would be much appreciated.
Thank-you, Nanc T.
Posted on Feb 17, 2008
  • 78 Answers
SOURCE: Kenmore refrig model 10671182101 water leaking in the interior
iced up drain , clean and defrost drain
Posted on May 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: maytag mff2557hes icebox not cold, freezer works.
OK, I will take you to the Maytag Service Library, You will need to put your refrigerator through some self diagnostic to locate the problem, click on link below and let me know when you are ready, Thanks, Sea Breeze
http://www.servicematters.com/maytag_library/docs/16025690.pdf
Posted on May 22, 2009
  • 4793 Answers
SOURCE: water build up underneath deli tray drawer
clean drain hole regularly....
Posted on Feb 09, 2010
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile french door refrig not cooling but freezer is cold
Look into rear of freezer and see if a layer of frost is building on rear panel. If yes you will need unplug and manually defrost with a hair dryer. That will help speed things up. You will also need the correct model number to get the correct parts. The odds are the defrost heater is defective. Because cold air is heavier than warm it tends to settle to bottom freezer making it appear OK. If there is no frost in freezer rear wall then we would look for the air supply damper to be closed between compartments. Look and see what you are going to need do and I will look up the parts assuming your model is a PFSF5NJXBB I will return soon, Thanks, Sea Breeze
Posted on May 16, 2010
Why is fridge not cooling?
Did you check to see if the auto defrost mechanism is working? Defrost heater any good? Ice in back of freezer?
Nov 26, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
FRIDGE WITH FRENCH DOORS AND FREEZER ON THE BOTTOM. WATER IS LEAKING FROM SOMEWHERE AND SETTLING UNDERNEATH MY DELI DRAWER TRAY. SOME OF THE WATER IS FROZEN. I HAD TO TOWEL THE WATER UP AND PRY OUT THE...
Your model must also have an evaporator on the top section because if the fresh food section deli has water below the trays you either have a door seal leak allowing moisture in or the fresh food section evaporator drain is also blocked. I really think your defrost drain is blocked and now everytime your refrigerator goes into defrost the condensate remains inside your refrigerator. Click Here=> Leaking Refrigerators Just What may Be Happening and read that page and then click here=> Leaking Refrigerators Read over all of the different ways leaks happenn and if this solution is helpful please rate the solution because I need all the rate's I can get. If you have questions I will be here so please ask, Thanks, Sea Breeze
Jun 29, 2011 | Refrigerators
I am continually getting a frozen sheet of ice beneath the deli drawer
Hi this is your water tank leaking due to it freezing from too low of temperatures, this particular model, had problems with damper assembly leaking, you will need to change out the water tank, but before you do that you need to fix the temperature problem, which requires adjusting or replacing the damper assembly in the back of the refrigerator at the bottom, You can install a bigger gasket or the new damper comes with one. If you need futher assistance let me know.
Sean
Mar 27, 2011 | General Electric Profile PFSS2MIXSS...
I have an ge french door bottom freezer model gfss6kkxass. it has started collecting water under the vegtable drawers and leaking down front of freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
ll
Sep 26, 2010 | General Electric GFSS6KKXSS Stainless...
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
General Electric PFSS6PKXSS Stainless Steel Bottom Freezer Commercial French Door Refrigerator Logo
565 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
