Question about Sport & Outdoor - Others
I have a 1997 motor guide wireless 24volt Big Water trolling motor. hooked it up to the batteries and put in a new 9volt battery in the foot pedal. the lights come on on top of the motor head and the foot pedal beeps, but the prop doesnt turn or spin (like there is no power to the bottom of the motor) any suggestions to what the problem is or how to fix it? (just bought the motor from a lady who's husband died. dont have any manuals)
    President:
  • 2,047 Answers
Hello there, as you said the power does not get to the bottom of the motor. The motor could be faulty or just completely bad. First you have to determine that the motor is good until you can determine this it is quite impossible to determine if there can be any fix. Take out the motor and try to power it on its own if it works fine then the problem is not from the motor but most likely the problem is from the motor. Let me know what your findings are. Hoping to hear from you soon. Thank you for visiting FixYa.
Posted on May 29, 2011
I have a motorguide fw71 fb bow-mounted trolling motor which I believe is receiving a short somewhere. I have the batteries hooked up right with a 30amp breaker going to each and often when I troll on...
Using an ammeter check for current draw and compare that with specs to determine if your draw is excessive. If motor has ever overheated and some of the windings have had the insulation burn off you will have a motor with less resistance and it will draw more current since less back emf is being generated.. Under those circumstances it can overheat and also blow existing fuses. Should that be the case you are looking at shopping for a new motor.
Apr 18, 2017 | MotorGuide FW71 FB Freshwater Series...
I bought a W75 wireless trolling motor at an auction. It sold as new and still in the box. There were no owners manual with it or any other papers like warrany papers and the such. Everything looks new...
there is no warranty for second hand goods sold as new or not
is the battery for the unit connected correctly a sit needs it's own to work besides the battery for the remote unit
is the receiver in the unit switched on to receive the remote control signal
try going google and typing in -- operator's manual for ( make and model ) trolling unit ---and downloading any pdf versions available
Apr 24, 2017 | MotorGuide Motg W 75 Wireless 54"
How do you reset remote for w75 wireless trolling motor
Its very easy:
Reprogramming the Wireless Foot Pedal or RemoteNOTE: This activation procedure applies to the foot pedal and remote.
IMPORTANT: To activate multiple foot pedals or remotes, the motor must be unplugged from the power source and then plugged
back into the power source between activating each control device.
1. Unplug the battery cables from the power source. Wait 30 seconds and then plug the motor into the power source.
2. In less than ten seconds, press and hold the "+" and "-" buttons on either the handheld remote or the foot pedal controller
simultaneously.
May 07, 2011 | MotorGuide STANDARD MOTOR REPLACEMENT...
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
How to attach leads to batteries
This is what they call a series connection. The two 12 volt batterys are wired together in a series to make one 24 volt battery. The positive wire or red from your trolling motor goes to the positive post on battery 1. The negative lead from trolling motor goes to the negative post on battery 2 then there is a short wire that goes from negative on battery one to positive on battery 2. NOW GET THAT HOOKED UP AND GET IN THE BASS.
Nov 29, 2009 | Electrical Supplies
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Prop spins slow on any speed on the foot pedal
There is a good chance that the control board is bad. This is a common problem with these units. I have replaced my control board twice. When the control board goes out, some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 27, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minn Kota power drive trolling motor will not steer to the right **** huard
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Apr 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Sport & Outdoor - Others Logo
21 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
