Screen froze and says sd card has been removed
  • 85 Answers
If the card is still in the machine remove it and restart your machine. If the machine is still froze, turn it off, remove the battery, replace the card, and boot the machine back up. If this fails you may need to obtain or re-install your machines operating system.
Posted on May 29, 2011
Stuck in restart mode, keeps restarting and will only work once sd card is taken out
Did you download a new program or app before this happened? Try plugging sd card into a computer and delete any recent downloads and then try the card in your tablet again.
Jul 20, 2014 | Samsung P5100 Galaxy Tab 2 10.1 16gb...
I have just received a new Archos vision 43 player which worked fine until I tried to use it wit a 16gb Kingstin SDHC micro memory card and the screen froze, and it would not turn off or change...
hello,
maybe your device doesn't match putting up high memory card, remove that and place back your default micro sd card..
note:you should go back immediately to your previous sd card,before many conflicts occurs
may this was helpful to you,goodluck
Feb 25, 2011 | Audio Players & Recorders
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My ipod touch is frozen and i tried shutting it down but it froze on the slide to power off screen
Did you remove the battery, try this and remove any sd card, then
replace the battery and try it.
Feb 04, 2010 | Apple iPod touch
Tried to update my Tom Tom One by connecting to my
Remove the SD card
The card needs to be formatted properly first that's all,
formatting is better done in a card reader.
Right click on it and select format select FAT32 as the files system
Update your device without the SD card.
Make sure your GPS runs OK without the SD card
Now re-connect the tomtom but don't let tomtom home run. exit TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options.
Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on switch off the tom tom and insert the sd card and re-boot
It should now work again
Sep 14, 2009 | Tomtom ONE GPS Receiver
N95 screen goes white
sounds like the software prob.most of these big multimedia phones crash and need to be updated by a repair shop.these have to be offical nokia updates.....but before that lift out your sim card and sd card and clean them,stick them back in and start it upagain.sometimes these get dirty
Sep 06, 2009 | Nokia N95 Cellular Phone
Frozen map screen
Try purchasing a new SD memory card (brand name) and installing the files there. Sometimes the manufacture sends cheap SD cards and the data is easily lost in damaged or poorly made SD cards. I have a EVESHAM 2007 and installed the files from the original CDto a new SD card and solved freezing and other problems resulting from poor data transmission from the cheap SD.
Also, try going online to the manufactureer's web site to see if they have downloads/ updates available there to replace the origianl install files that came with the unit. Always put on new brand new SD card.
Hope this helps
Feb 23, 2009 | GPS
Frozen screen
Try first removing the batter for about 5 minutes to refresh the camera, then make sure also that the battery is fully charge...then after that check the camera again...
Hope that helps.........
Sep 15, 2008 | Fuji FinePix 2650 Digital Camera
R4 SD card
you may have a r4 sdhc card that needs diverent soft ware go to www.r4sdhc.com
Jun 18, 2008 | Nintendo DS Lite Console
Gps wont work it is frozen
Well Sprinkler, I have one also and had a similar problem. But I took SD card out and Batt. for 1 hole day and put back in first the batt and tried power up and it come on. I think my SD card caused the problem. Hope this helps!
Sep 20, 2007 | Audio Players & Recorders
Computers & Internet Logo
David Payne
David Payne
