If the red light is on for such a short period of time, it probably means that the headphones are charged. The red light will flash for a long time and then turn green only when you charge on the dock headphones that need charging. I suggest to try to use them without charging them and see if the headphones work.
If it is within the warranty period get Dyson to replace it. If not, live with it until it fails completely, then buy a Hoover. Your computer board is starting to fail. That's not repairable.
generally when charging the light will be red until a full charge is indicated and the light will turn green. if while trying to charge the light remains green I would try reinserting the battery or charging unit. If still the same you might have a problem with either.
I am personally using a Plantronics CS60 wireless headset with a Meridian Nortel M2006 Phone and it works just fine.
Here is how you can setup the Plantronics CS60 wireless headset.
NOTE: Before setting up the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
The headset and the base unit are supplied subscribed to each other. However, if you wish to use a replacement headset with the base unit (or if you lose your connection to the base unit), then you must re-subscribe as follows:
1. Return the headset to the charging base.
2. Press and hold both the + and - buttons on the back of the charging base until the red light on the front of the base starts to flash.
3. Let go of both buttons. The red light should continue to flash.
4. Press the mute switch (black wheel on the top of the headset) straight down until a green light appears on the headset, then let go of the wheel, and the light should remain on the headset.
5. Resubscription is finished when the red light on the base is fully illuminated and the green light on the headset disappears.
6. Remove the headset from the charging base lift telephone handset/press headset button if not using a handset lifter. The headset and base should now be connected.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position.
To Re-Subscribe:
7. If this procedure does not resolve your issue to try a system reset.
Machine no longer takes a charge. Light remains yellow, if you plug anything in there's not enough power. Any suggestions? Purchased XPower Powerpack 300 Plus from QVC appx. 6 - 8 years ago.
NOTE: Before re-subscribing the system make sure the IntelliStand switch (on the right side of the charging base) is in the "_" position and NOT the "=" position. To Re-Subscribe:
Lulu1121 and guest, red means no charge and will remain red till its fully charge. Then it will turn to green. In fact, coby battery can be charge directly without the whole unit attached. But if on charge too long and still red, battery is dead, kaput, finish. some even show evidence when the casing is swollen...gel chemicals inside is swollen. The power supply that came with it is the only way you can use it...portability is out of the question.
Don't turn it off, the battery needs to be constantly charged or refreshed. They will go bad just sitting around with no voltage applied. The UPS draws very little power and has surge protection so there is very little to worry about.
