Can I increase the volume from the optical output
  • 643 Answers
No usually the optical is a fixed volume output. You could try changing the different soundfields on the tv itself. Hope this helps.
Posted on May 29, 2011
How do I increase the volume on the speaker?
Search Results
    How to improve sound quality and increase volume on ...
    https://www.androidpit.com/improve-the-sound-and-volume-quality-on-...
    Dec 4, 2015 - Not all smartphones are blessed with speaker quality or volume levels to make your stereo envious. ... How do you improve sound quality on your phone? ....I've seen a 'little' cellphone case, foam padded with a zipper, that ...
    How to increse speaker volume on android smartphone
    www.instructables.com/.../How-to-increse-speaker-volume-o...
    InstructablesRequirements:You will need a phone with Mediatek chipset. ... is a quick turtorial on how to increase the volume of front-facing speakers on android smartphone.
    Increase your Android Phone's Audio Output with Speaker ...
    www.techverse.net/increase-android-phone-volume-output-speaker-boost/
Jan 27, 2016 | Cell Phones
Tip
How to set up a home theatre system ?
Considering a home theatre system, you will have to connect both the audio and the video cables of your home theatre system to your DVD player, so let us first start with the connection of the audio cable.
Step 1:Firstly you must find the digital output point on the back of your DVD player. It will be labelled as "COAXIAL" or "OPTICAL". Some of the DVD players may have both the Coaxial and the Optical output. In that case you must connect only either of them. Both the outputs require different kind of output cable. The Coaxial output uses a standard shielded RCA cable which is plugs in an RCA jack which is labeled "COAXIAL DIGITAL". The Optical output uses a fiber-optic cable which has a square shaped connector at both the ends. Both the outputs deliver almost the same quality of sound but the Optical cable sometimes allows us to prevent ground loops. Both these digital cables do not carry any video signals. Now connect either of these to the digital audio input which is at the rear of your reciever.
Step 2:Now you must connect the video cables. Before you start doing that you must decide if you want to connect the video cables through the A/V reciever and then connect it to the TV or just directly connect it to the TV. By connecting the wires to the A/V reciever and then to the TV usind two separate cables has its advantages in which you find convenience if you want to switch the reciever to watch a DVD and also you will be able to see the on-screen menu on your TV. By directly connecting the cable to the TV you will find it easier but again you would not be able to see the on-screen menu.
Most of the DVD players will have three video outputs. Connect all three of them inorder to recieve maximum video clarity from a DVD. It is necessary to have component outputs on your TV and/or your AM reciever inorder to connect all the three video outputs. In case you dont have an component output then you will have to connect only one s-video cable to your TV input. This s-video cable is a single cable with a multi pin plug. In case there is an component output for your TV. then you will require three cables(RCA) which have different colour codes(which are sometimes binded togethr). the colours are usualy Red , Green and White. Using the component output gives you the best video quality next to which is using the s-video output. The DVD player may also have an HDMI or DVI connectors. These help in maintaining the video in its digital form rather than converting it to anolog form.
Step 3: Make sure you dont turn the volume of your surround sound too high in which case any one of the speakers might call attention to themselves. In other words, in case the volume of the surround sound is too high then sometimes one of the speakers on your rear may call your attention separately. Hence it is recomended to keep the volume in its optimum level. Many of you might even wonder if the surround system is actually functioning properly until you experiance an of-screen sound such as a phone ringing at the backround or the sound o thunder in case of a rainstorm . Hence you must know that a surround system is not for loud noises and rather to experiance a three dimensional environment in between a movie.
There are certain things which you can do inorder to experiance a better feel using your surround sound system. Few of them are as follows,
1. It is advisable to get a test DVD which will help you adjust the surround sound levels and make maximum use of the system. For instance get a Sound and Vision magazine home theatre tune up DVD. IT will help you in maximizing the effects of the system.
2. Always remember to keep the central channel speakers setting at low. In case the setting is high then there is a loss of clarity of speech.
3. Try changing the seating arangements around the surround speaker system. Sometimes you might feel better audio quality at certain positions.
4. Always keep the brightness of the TV on optimum range. This is better for viewing more particular details in the picture quality as well as increases the life of the TV. Hence high brightness will reduce the life of the TV as well as give u less details on the picture being viewed.
5. Always have the volume of the sub-woofer at medium when you play music and then gradually increase it to how much ever necessary.
on Sep 12, 2010 | Audio Players & Recorders
Low volume on created DVD
Unlike ripping CDs, ripping DVDs poses many challenges for the average user.
Because you need to get audio and video and need to get them synced correctly problems with the final version frequently arise.
One common problem is that the volume is too low.
The solution might seem to be to simply turn up the speakers, but the sound of a low-volume movie cranked up can crackle or distort. Instead, you increase your DVD rip volume by changing it before you begin the rip process.
Increase DVD rip volume with iSofter DVD Rip (see Below).
http://www.dvd-tool.com/dvd-ripper/faq.html
With this program, a window called "Input Settings" allows you to control the volume before you begin. After the DVD is in the computer, you just use the "Volume" slider to increase the output volume. As of November 2010, the program costs $34.95.
Try Aimersoft DVD Ripper (see Below).
http://www.youtubetoipod.biz/software/aimersoft-dvd-ripper.html
After inserting the disc, you simply click "Load DVD" and wait for it to load
(this could take a few minutes).
The "Settings" button presents a volume slider similar to iSofter's.
Push it to the right to increase the output volume.
As of November 2010, the program costs $35.
The free dvd::rip program offers the most customizable settings for the advanced user
(see Below).
http://www.exit1.org/dvdrip/
Not only can you increase the output volume with a volume slider, you can also compress the sound as well.
This is useful for movies with both loud and quiet parts (such as action movies). It reduces the volume difference so you don't have to reach for the remote every five minutes.
Jun 27, 2013 | Corel 9900-65295-00 Pinnacle Studio 16...
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
I can only hear the person I am talking to through headphones, I want to hear them on my speaker
To solve this problem ,do this; goto start menu >control panel>sound and audio devices
in volume tab under speaker settings , click on "advanced" in speakers tab speaker setup:select desktop stereo speakers
click performance tab Hardware acceleration =full sample rate conversation quality=best. click on apply,and ok
select audio tab in sound and audio output. click on volume ,unmute all . increase all volume to high. close it.
select voice tab in click on volume ,unmute all . increase all volume to high. close it.
click on apply and ok.
then open your audio manager .increase play back volume and unmute all .
important :select default device (sound play back) .to your audio manager's default device . after apply all settings .click ok and close it. in sound and audio output. tick on "use only default devices". . do it and solve it
Sep 08, 2010 | Skype IM
Volume varies between radio and other outputs
Well, the radio is ONboard, so there are no connections or settings in the way. I'd look at the sources on your vid 1-2-3's and see what's up with them first. Are they outputting audio at the standard levels?
May 11, 2010 | Kenwood VR-407 Receiver
Volume problem
try reducing the output volume from the pc, maybe to about half or even a quarter of full volume. now increase the volume on speakers.
Mar 21, 2010 | Logitech X-540 Computer Speakers
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
Volume when on tuner is very different than when on DTV
Under the input menu, there is a volume trim function which allow you to increase or decrease the volume level of each input. It is designed so that the volume of different components can be matched to prevent a blast of sound when changing to a lounder output. You can increase the alevel of the dtv input, and decrease the level of the tuner. Tuner volumes are usually high.
Jan 24, 2009 | Yamaha RX-V1400 Receiver
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
