Question about HTC Wildfire Cell Phone
I am on 2.1 and wish to get high is it possible
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
Go to Menu->Settings->About Phone->System software updates.
My HTC Wildfire was already 2.2.1 and gives many improvements since updating from 2.1 last Dec 2010.
Posted on Jun 11, 2011
What year was Amanda air command high efficiency 80 gas furnace produced. Have problems with dust. Notice furniture gets dusty when furnace on.
The year it was produced has no relevancy on tyhe dust in your home. You may want to consider having your ducts cleaned and possibly a pull and clean on your blower wheel. Also a good cleaning on the evaporator with routine filter changes will help with dust as well. Best Wishes.
Aug 21, 2017 | Heating & Cooling
My iron every so often makes a high pitch noise
There are several possible answers:
1. The iron has some scale build up and the steam is escaping and clearing a path until it builds up again.
2. If you have an iron with an electronic display or any type of circuit board - we have heard components on them make noise usually no problems.
3. It is highly suggested to read through the owner's manual as this may be a simple cleaning procedure or you may be directed to contact the manufacturer.
4. If are unsure, please contact the manufacturer for further guidance - your safety is of the utmost importance.
Best wishes,
Joe
Aug 25, 2016 | Irons
Hi! I have a 2006 HP High Def Plasma TV model CPTOH-0602, serial CNH6131576. It lost picture, I can hear sound. Wonder what couls be the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 09, 2014 | HP Televison & Video
Replace powersteering line
Work with me on this.
There are two "kinds" of hoses. High pressure and low pressure.
High pressure hoses have a high pressure fitting on each end.
Low pressure hoses often have a pressure fitting on one end, and nothing more than a hose clamp (band clamp) on the other end.
See if yours has two identifiable hoses, one of each.
Before you take any parts off, know that it is possible you only need to tighten a hose connection.
This I found true in about 1/2 the cases.
You can change either hose yourself, but know that you might really wish you hadn't!
You may discover you have to take many parts off to get to the hoses, and be prepared to spend many hours on the job.
Be Blessed
Feb 09, 2013 | 2003 Lincoln LS
Is it possible to lower the top temperature on the thermostate. I can change the lower temp but not the max which I wish to set below the 180 level. Thanks
there is a high and a low limit on these units, the two control knobs are actually the reverse of what you are trying to accomblish,first lower the bottom or low cut off temp first then the high temp ,it must cycle a couple times for it to adjust
Jun 06, 2011 | Honeywell L4103A1019 combination aquastat....
My phone 5220 XM usually hang up, and then restart itself, what should i do to fix this problem.?
you need to update your phone software as early as possible. you can either do it yourself through nokia software updater if you have a high speed internet, or you can take it to customer care to get it updated. hope your problem is solved. wish you good luck.
Jan 29, 2011 | Nokia 5220 XpressMusic Cellular Phone
My camera(model: DSC-S750) is 2 and half years old. The flash is not working under any mode(Auto/On/Slow Synchro) though the camera works fine in flash off mode. Plzz help.........
Possible that the flash circuit is fault ., The best you can do is to open and check for any chances of a line break or a possible failure in the storage capacitor. If there is voltage to the inverter unit then it is possible that the circuit has failed which means a new board must be put into the camera. It is also possible that the flash tube is faulty which can be confirmed if there is high voltage on the tube with the flash trigger but with no action.
Wishing you a very happy New Year.
Dec 31, 2010 | Cameras
Engine overheating 2-3 miles down the road. Heater fails when gauge gets to high. Replaced thermostat. Idiling is fine.
Sounds like possible head gasket failure. Is it pushing antifreeze out through the over flow bottle? When it pushes out enough fluid the heater will not heat. A easy check if head gasket is to fill radiator and leave cap off and start motor. It will blow the coolant out wile running. I wish you luck. Have a good day.
Dec 20, 2009 | 1997 Subaru Legacy
Can i replace my b13 exhaust manifold to sr20 manifold?
If you wish drive on high way only it is possible but in the town it will became ridiculouse.
Aug 09, 2009 | 1993 Nissan Sentra 4 Door
Our sony will not turn on, we hear the click but nothing.
The 7 blinks usually indicate a high voltage problem (voltage too high). It can be a simple regulator problem or something more complex. Please update this to confirm your model as KV-32FS120 and some indication of whether or not you wish to attempt the repair yourself.
Thanks,
Dan
Jan 05, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
HTC Wildfire Cell Phone Logo
51 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
