Question about DeLonghi TRD0715T Oil Filled Radiator Heater
I have a oil heater about 7 months old. it now onlys stays on for 6 minutes, before it would stay on as long as it was plugged in. did i hit the wrong button. i usually just plug it in, one light will come on, i then hit the on mode and 2 lights will come on and it heats great. can you help me out.....thanks,b.t.
  • 910 Answers
It sounds like the Thermostat on the unit may be set too low so it's reaching temperature and then switching off.
You can get the Free PDF Manual at the link below.
http://www.delonghiusa.com/index.php?texts&pid=10&catid=3
If yours isn't the DeLonghi TRD0715T then please provide your Make and Model for further assistance.
Posted on May 29, 2011
My 6 month old Whirlpool duet front load washer will dispense detergent but will not fill with water or spin. The timer stays the same # of minutes. What is wrong?
Check Owner's manual. If there are no troubleshooting clues, look for a customer service number. There should be a warranty if only 6 months old. If no fix I'd go that route.
Feb 18, 2015 | Whirlpool Washing Machines
I have a kenwood model ew7507tek. powers on but only stays on for 6 seconds
I had two of these heaters and they both started to malfunction about the same time. The lights near the display window would not come on and there was a buzzing noise when it was plugged in. We determined that some kind of a relay inside was not working anymore. I got rid of both of these heaters and had to buy new ones. Seems like they lasted just past the warranty.
Oct 30, 2014 | Kenwood EW7507EK Oil Radiator
1999 malibu 3.1 clyd 5 missfire and now random missfire oil light is on lfters very noise runs rough
Have you confirmed there is no oil pressure and the oil level is full on the dipstick?
The oil pump is turned by the oil pump drive located under the throttle body. The oil pump drive is run of from the cam shaft. It is not uncommon for the camshafts to break on these engines.
It may not be a bad idea to pull the front valve cover and turn the engine over by hand to see if all the rockers are moving.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jan 17, 2012 | Cars & Trucks
Pilot light will not stay on Bosch natural gas tankless water hea
Check to make sure the flame of the pilot is hitting the thermocoupling. If not then you can use compressed air to clean the pilot port and relight and check again. If the flame is hitting the thermocouple, then it may need to be replaced.
May 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
The heater won't stay lit
CHECK YOUR EXHAUST VENT MAKE SURE THAT IT IS NOT PLUGGED OVER HEATING THE UNIT.ALSO IF IT HAS A FLAME SENSE BAR CLEAN IT AND CLEAN ALL SENSOR OFF.AND MAKE SURE ALL WIRE CONNECTIONS ARE PLUGGED IN TIGHT.
Jan 16, 2009 | Desa International CBN20T Heater
Small ReddyHeater won't stay on
The photocell may be dirty or need to be replaced. Take a look in your owner's manual or check online for replacement part.
Dec 18, 2007 | Reddy R70ET Utility Heater
Marantx SR4600 Receiver
Some indication of power supply issue. if it is 6 months old. It should be still under warranty. Should it not?
Sep 07, 2007 | Marantz SR4600
DeLonghi TRD0715T Oil Filled Radiator Heater Logo
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
