Question about Pioneer Audio Players & Recorders
Non-functional pioneer remote - Pioneer Audio Players & Recorders
  • 22 more comments
  • rtcheatham Aug 16, 2008
    The model # is cuvsx045 and the remote use to work but now none of the buttons work and its seems to be not accepting power from the batteries.
    The model # is cuvsx045 and i can't seem to get any of the buttons to work even though there is batteries in it. Its a Pioneer
    I believe it is getting power from the batteries but their seems to be some function or reset button that needs to be implemented in order to free up the remote. But thanks I'd hate to take up peoples time with a broken remote.
  • rtcheatham Aug 17, 2008
    Now I have taken out the batteries and cleaned the board but I still can't get any function from remote is it locked somehow?
    I cleaned the battery posts but they still seem just a little brown could their be anyway around this to check for functionality.
    I'm not sure what you mean fixya on the profile page just brings me back to the homepage and there is no troubleshooting guide or manual for my model.
    I checked that process and no light comes out at all even though there is fresh batteries and there in right.
    I guess I should just accept I have a broken remote but there is no warranty and the product is out of date so I can't return it . Just give up huh.
    No universal power adapter but i'm still hoping i just locked it up somehow with an advanced button feature.
    I looked into it but all they really do is clean the buttons no board work but it is an option for this poor old girl any other suggestions?
    its not highlighted so all I get is a typing prompt. am i doing something wrong.
    The crystal bulb doesn't seem to light up or go off at all.
    I went to the remote doctor but he seems to stress cleaning the buttons I cleaned them to no avail.
    Replacement seems an option but pioneer is out of stock ebay has one maybe i'll look into it but it just seems like there is an easy fix.
    thanks for your help no fixing what aint fixable later
    I just bought a navilight8 and now I can't seem to get the code to work my pioneer 511S receiver any thoughts?
    Please read the last comment thread I junked the old remote and now need codes for a new navilight8 for Pionner 511s receiver.
    I found out I could get a replacement remote for the system but at 149 is was just too much now I am working on getting a navilight8 to function.
  • rtcheatham Aug 18, 2008
    I have a universal remote now I just need the codes for a Pioneer 511S
    I guess i am having a problem it seems like i getting info on past problems does anyone know any expanded codes list for audio to include pioneer to its lists of navilight8 codes.
    Thanks everybody but I trashed the remote and the universal just wasn't the answer for my tech needs so I'm going to save up for the original remote. No need to respond any further to my question. Again thanks.
  • rtcheatham Aug 19, 2008
    I have a new question imagine that!!! Please respond in kind if you know how to change topics and start a new thread or if you know if you only get to ask one question for your premium membership. but i need the owners manual/guide for a mitsubishi cs-35503 television.
    I guess the manual for mitsubishi television that are vintage doesn't exist.
    Thanks again but I'm going to sign off for now as I don't believe I have the tech experience to follow some of the more complex techniques. Thanks again for your help and as a suggestion you might add a few key capabilities to the sight such as comment delete from the original questioner and the ability to understand billing better. Again thanks for your time and patience.
  • 2,071 Answers
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
Posted on Aug 25, 2008
    Sergeant:
    Champion:
  • 246 Answers
Please change to another new remote
Posted on Aug 19, 2008
    Genius:
  • 1,447 Answers
Hi-
Code Search Method
  1. Turn on the device you wish to program.
  2. Press and hold CODE SEARCH until the indicator light lights, then release.
  3. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit.
  4. Press and release off-on until your device turns off. You may have to press off-on up to 200 times.
  5. When your device turns off, press the ENTER button and the indicator light will go off.
Code Entry Method
  1. Manually turn on the device you want to program.
  2. Find the code for your device in the code list.
  3. Press and hold the CODE SEARCH button until the indicator light lights, then release.
  4. Press and release the device you want to program, the indicator light will blink then remain lit.
  5. Enter your code using the number buttons.After your code is entered the indicator light will turn off.
  6. Aim the remote at your device and press the off-on button. The device should turn off.
and try these codes Pioneer004, 006, 090, 091, 092, 179, 185, 196, 228 -- FOR TV's and for RECEIVERS Pioneer034, 033
Posted on Aug 18, 2008
    Scholar:
  • 163 Answers
  • 876 Answers
Get under a strong light and take a look at the remote carefully-are any little buttons stuck 1/3 or 1/2 way in? This happens sometimes and will completely stop the remote from working.
Good Luck to You
    Master:
  • 521 Answers
Why dont you try universal remote.they are much better option in this case.this is the link.have a look and select one for you.
http://www.replacementremotes.com/store/productdetailp.cfm?productid=7749
thanks.
    President:
  • 624 Answers
You have done everything you can do without having the schematic and troubleshooting it to find the exact problem.
With the model number of your receiver I could send you the service manual in PDF format and it has the schematic for the remote most of the time.
If you have an infrared detector you can see if it is sending out the light from the remote. You can not see the light coming out of the remote with your eyes, it is infrared and the human eye cannot see that range of light.
Sometimes the problem with remotes is in the receiver. They have a remote sensor that sometimes gets broken solder joints on the leads that connect to the display circuit board. It is a common problem with receivers that the remote does not work.
If your remote is not fixable or if the problem is not in the receiver, you may be able to get a replacement. I know you said they are no longer available, but sometimes there are still replacements that will work that are a different model number. In fact, many different Pioneer remotes will work on your receiver and a few will operate all the functions which means you will not lose any operations.
Please list your receivers model number and I will check to see if Pioneer has an adequate replacement for you. I work at an authorized Pioneer service center and have access to everything from Pioneer.
Let me know if you would like to continue to try and solve this problem, and knowing the model number of the receiver would help, that way I could find the schematic of the remote and also figure out if there is a replacement for it.
Good luck,
Dave
Posted on Aug 17, 2008
    Genius:
  • 1,665 Answers
If it is not getting any power from the battery, inspect thoroughly contacts to be clean and batteries well fitted. You may need to dismantle it to (usually using a knife) to inspect inside terminal wires. If you are not familiar with electrical repairs, better take it to repair shop to figure out problem's cause.
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Aug 19, 2008
    You at last can try to gently clean key pad bottom surface and corresponding board surface using a cloth wetted in volatile liquid cleaner and see if thereis response if keys are pressed. It must be carefully dismantled to do this work.
    Kleanthis Mavropoulos Aug 25, 2008
    See also if you can get a substitute from link
    http://dev.electronicadventure.us/290P03...
    Genius:
  • 1,011 Answers
Dear Sir/madam,
The remote you have some technical fault it cannot be repair yourself. So, better go for the replacement from the following address. Call number to confirm.
REPLACEMENT REMOTES 146 Northstar Dr. Rural Hall, NC. 27045 Phone: 336-969-1842 Fax: 336-969-0360
Also click this link for manual to do repair yourself. Try out......
http://www.theremotedoctor.com/trouble.html
thanks
good luck
  • 1,879 Answers
After trying all the suggestions and still it ain't working- buy a new remote control.
  • monk3ybidzness
    monk3ybidzness Aug 17, 2008
    shout-out to charcois - ouch sano!
    Master:
  • 763 Answers
Try to use alkaline battery or any battery with a long span of energy. if still dont work, send it back to the place where you bought it and ask for assistance from them if it still on warranty. hope that helps!
CHARCOIS
    Genius:
  • 1,011 Answers
Dear,
the easiest way to check all remote buttons is here
just open the camera of ur mobile phone or any other digital display camera.
place your sensor (IRLED) of remote infront of the camera so that u can see the sensor from ur camera.
just press each button one by one and u will see light emitting from that sensor in your camera.
if all button emitt light then it is confirmed that remote is ok, the problem is in tv reciever (Photodiode or phototransistor).
but see the light intensity. is it glowing high or low.
if low then u have to change the battery.
regards,
  • 4 more comments
  • SALMAN NASEER Aug 17, 2008
    check it by my above mentioned method and u will get positive results dear,
    ok, now through this method it is diclaired that remote is faulty..
    but just view it inside so check their is a crystal oscillator. mostly that goes off. just try by changing it and maybe u dont have to buy a new one..
    regards,
    is it
    dear,
    here is a link for replacement ..
    check it and check does ur existing remote look like the above mentioned in this link. if yes , then at lower left side there is a replacement
    http://www.replacementremotes.com/store/...
    regards,
    dear,
    here is actual model price compar.
    http://parts.pioneerelectronics.com/mode...
    regards,
    ok, its not functioning, it is confirmed what u have done with my method of checking it..
    so dear, what about crystal oscillator, a yellowish or whitish color two leg component, is there.
    ask for a technician to change it or check it with some tester. eg crystal tester...
    moreover, it is possible that u have locked it..
    because it locked condition, u cant see light emitting from it..
    remove the battery by the way and let it without battery for some minutes and then again check it.. hope it work
    regards,
  • 157 Answers
Hi
Click on Fixya to get your solution
Cheers
  • John Smith
    John Smith Aug 17, 2008
    i meant click fixya under my solution and youll get the best possible fix for your problem
  • John Smith
    John Smith Aug 18, 2008
    try this website
    http://remotefinder.rca.com/default.aspx...
    Master:
  • 623 Answers
Instruction on how to repair your remote...
Posted on Aug 16, 2008
    Genius:
  • 1,268 Answers
Double check batteries if they are aligned properly and positioned at their correct poles (+ and -). Also, you can open the casing of the remote and clean the keypads and keypad board using an alcohol. You can also use an eraser and thoroughly scrub the keypad board.
  • 6,487 Answers
I think it will be better for you to have teh remote repair or replace since its not getting any power from the battery , you can check this link for the remote repair or replacement http://www.pioneerremotes.com/index.cfm?page=22
Hope that helps..........
  • 2 more comments
  • Mark Gil
    Mark Gil Aug 16, 2008
    The site that I gave you to also offer reapir for your remote that you can check so it will be option to have it repair or replace from them...
  • Mark Gil
    Mark Gil Aug 17, 2008
    If still not working check the link that I gave you and have the remote repair or replace from them ...
  • Mark Gil
    Mark Gil Aug 18, 2008
    How about sending that remote for repair ? check this link http://www.pioneerremotes.com/index.cfm?...
    Good luck........
  • Mark Gil
    Mark Gil Aug 19, 2008
    I think so because it very hard to find that manual...
    Genius:
  • 1,689 Answers
May we have the model number of that and if in case will you describe to us how you founf out that it is non-functional, thanks
  • 3 more comments
  • marlon john madrid
    marlon john madrid Aug 16, 2008
    have you checked on the contacts of the battery, there is a way you can open the remote up and you wll be able to see the battery contacts, check if it is rusted or corroded, and look for a balooned capacitor or a leaking one, if you do, than it will be best if you have this repaired or replaced.
    thats no problem, if in case you will have other issues, just let us know.
    marlon john madrid Aug 17, 2008
    you may try using a universal power adapter, set it to 2.5 - 2.9 volts, open the unit, find a way to link the positive and negative of the power adapter to the remote, a little risky if you have more that 3 volts.
    well if that is the case then you may have a swollen or leaking capacitor on the remote, have you seen one by the way? if so, you may either get that part replaced or a new remote will do too
    rtcheatham, what remote will you get?
  • 1,512 Answers
Hi
I did read through your comments, I am only going to offer advice to your original question. I have a great deal of experience in these matters and am confident you can repair the device, solving all your problems.
Your remote will most probably be repairable. There are only a couple of things that normally stop a remote from working. Most have been mentioned already across the various posts. To summarise then in order of probability:
  1. faulty batteries or battery connections.... Cleaning the terminals with an finger nail emery board,then a spray with contact lube spray such as CRC 2-26
  2. moisture or contaminants on the switch contact PCB(black carbon etchings) forcing more than one button to be "jammed on" See this TIP I have written. Also has details on how to get the remote apart.
  3. dry/cracked solder joints to the infra-red LED. Resolder the connections to the PCB.
  4. Faulty or dry jointed ceramic resonator non-functional pioneer remote - 37e4657.jpgresolder first, they dry joint alot. If still no luck, replace the device with the exact same type. Contact me with the markings on it and I can provide you with information to source it.
  5. faulty IR LED.
  6. cracked PCB. Not repairable, you may be able to get a replacement PCB from Pioneer.
I have repaired hundreds of remotes over the years, and was a Key Service Agent for Pioneer for 12 years. If you are interested in repairing the remote, check out the TIP I wrote on how to get into the device, then go through the list above, then post back to me your findings. I am sure we can get to the bottom of it.
robotek
  • Graeme Ross
    Graeme Ross Aug 22, 2008
    Hi again, just a quick follow-up. Do you have a question regarding the billing process for the site? Happy to answer any questions you may have about that. Just seems by your non acceptance of a plethora of advice given here, that there has been some confusion regarding what it was that you were expecting to get. Would be great if you could elaborate to us a little about this. Thankyou
    regards
    robotek
Huayu hr330e+. What's the code for Pioneer?
If your Huayu remote is universal, you can use its code search feature to find something that can handle some or all functions of your Pioneer device. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all codes.
May 04, 2016 | Televison & Video
Pioneer receiver -no volume or volume display on screen. As if the function has disappeared. Knob still turns; just NO effect
Did the volume control get an impact? Could be internal damage to the digital control. Did it act up prior to this non-function, like volume went up on a down command or jump up or down when a slight turn was made? Thnose would reinforce a damaged volume control.
Jun 02, 2015 | Pioneer Audio Players & Recorders
Why does my pioneer remote DDX3086 display work, but why can't I turn on my receiver or functions?
Check the remote control for its infrared emission.Check it with fresh batteries.If you wish to get more details about how to check a remote control, please visit this site.One among the posts has details about it.Surf the site with patience.
Aug 03, 2014 | Pioneer Televison & Video
Remote control problem pioneer dv-f727
A few thoughts.
1. The remote was water/liquid damaged and the buttons no loger make contact with the silicon board to send a signal.
2. Low battery??
3. If you are using a universal remote, you may have found a code that only partially functions. Keep going through the codes until you find one that fully functions.
Hope this helps!
Jun 26, 2012 | Pioneer DV-F727 DVD Player
Insignia tv codes for pioneer AXD7409 remote
Hi
There is no direct coding available for this remote. You have to use learning function to use the remote with other components. Here i have added the link to the manual of a pioneer AVR wich uses the remote you have. Check the page number 68 onward. It describes how to use the remote with other systems by use of learning function.
Ajin
http://www.google.com/url?sa=t&rct=j&q=pioneer%20vsx72txv%20manual&source=web&cd=1&sqi=2&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.pioneerelectronics.ca%2Fpio%2Fpe%2Fimages%2Fportal%2Fcit_3424%2F276539348VSX_74TXVi%2520VSX-72TXV.pdf&ei=Fgs1T-e_KM3IrQfqgqG6Dw&usg=AFQjCNHHjp1bjriWfH2o2QOAidZOCveQnQ
Feb 09, 2012 | Televison & Video
Is Pioneer Cdsr11 Steering Wheel Remote works with pioneer avh-p5200?
No. Some of the functions might work. But it is not made to work on the avh models.
Jan 14, 2011 | Pioneer Cdsr11 Steering Wheel Remote for...
NO REMOTE TERMINAL ON PIONEER GM1200 AMP
does it function properly with just the power and the ground?If so try using a ordinary fuse breaker(switchable on/off) and mount it in the cabin of the vehicle where you have easy access to it and can shut it off and turn it on when you need to- Its not necessary to have the remote lead connected to it if it functions well without it.
May 29, 2009 | Pioneer Gm-d8400m 1200w Max, Class D Mono...
Does pioneer model vsx 403 come with a remote control? If so how can you relace it?
I have the same unit. It does come with a remote. The original remote is pretty much impossible to find. But also there are some companies that sell remotes for it. Google Pioneer VSX403 remote replacement. I have yet to get a remote :D
Good Luck.
May 06, 2009 | Pioneer VSX-403 Receiver
No sound for the cable HDTV.
I woud examine the front panel indicators very carefully. Think about what your other inputs are that don't work. Besides all being from external components, are they non-stereo, or non analog, or ? What's common to them? The Multi-Channel function (button 5 alternate function on the Remote) would be a wild guess since on my Pioneer it overrides every other input. Not sure how the onbiard tuner is affected since I don't use it andI'm out of town for a few days or I'd try it.
Mar 14, 2009 | Onkyo TX-SR573 Receiver
Connect my audio(Pioneer sx205)with URC6620
Are you positive that can use a remote? Pioneer's website does not show a remote for that and (if memory serves) the model numbers without an R (as in SX-205R) would be a non-remote unit.
Aug 18, 2008 | Televison & Video
318 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
