The image on a CRT TV is produced by a beam of electrons which is controlled by a magnetic field to move the beam top to bottom and left to right. A single line suggests that the vertical deflection is working but not the horizontal deflection (left to right). There are a number of components associated with this and requires a competent TV repair engineer to fix. Better to to buy a new TV!
it just has a bunch of numbers... the clutch is on the engine
yes it has an electric clutch, should be on the front of the engine since it should be a horizantle crankshaft
A single line indicates a failure in one of the hundreds of connections on the back of the LED display panel. It normally cannot be repaired, but can be replaced. It may be more cost-effective to replace the unit.
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
I was just watching TV and all of a sudden the screen minimized down to a single green line spanning across the screen horizontally. The label in the back says it was made in 1996 so it is an old tv. Can anyone help?
I would suggest to locate a part that looks like the one on this link and re solder all the pins, also check for any high power resistor nearby the IC295890 and put some fresh solder.
Let me know if you need further assistance.
The LCD Panel is defective. You will need to replace the LCD Panel. It will probably be cheaper to replace the monitor since the LCD Panel may exceed the monitor cost.
Single lines of single color (red,green, blue) are LCD panel failures.
1 or 2 lines of single color are LCD Panel failures.
Multple color lines could be anything so in this case you start by checking the power circuit.
you have to get into the tv to do the adjustment. take the cover off and then look for the CRT tube and follow the yoke cables that will lead you to the printed circuit. you should see some small tiny knobs there. something like vertical phase or horizantl Phase..you need the verital to adjust the vertical size of the pic..good luck
