Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I have a 13X42 inch Metal Frame Pool and we have added over 55 lbs of salt to our pool and its still green and saying low salt.... what should we do and how much salt does out pool actually need??
    Problem Solver:
  • 11 Answers
You need to get water tested then add the right amount of shock + others and check in a few days to see where the water is at. The salt system only keeps pool right when in balance.
Posted on Jun 01, 2011
Two weekends ago I came back from a 4 day trip to a green stincky pool. Low flow, we cleaned the filter and scrubbed the algae, by morning a beautiful sight. Yesterday after not look at the pool over the...
You should definitely shock however the best solution for solving an algae problem, which is what you have, is using a product called
Algimycin 2000
this will clear up your pool in about 24 hours
US Parts Center
Aug 18, 2011 | Intex Automatic Salt Water System for ...
We have a 18x48 ultra frame intex pool. It at first gave us a lot of problems saying low salt so we cleaned the cell with vinegar and it began working no probs for the past 3 weeks. On the weekend I went...
I can't explain all of this but to get the rid of the green and reduce the salt level you need to drain half the water and refill. At this you need to shock it so the chlorine is up to about 10 ppm. You need some way of testing to tell this. If your chlorinator is ok then when you start the pump and chlorinator it should continue cleaning it out. The dead algae will be filtered out with the filter. If the flow slows down you will need to clean the filter with a water sprayer on a hose. I hope this helps.
Aug 09, 2011 | Intex Automatic Salt Water System for ...
My water is cloudy and says low salt. I added 120 lbs and it still beeps low salt. I have a CS8111 saltwater system & filter combo. It is on an above ground pool 24' X 52".
Check the electrolytic cell!!! You will get a low salt alarm if cell has calcium or sodium build up.. If it does, soak, flush and clean with vinegar.. Also, make sure you run the pump only, no chlorinator for 24 hrs to properly disolve the salt you just put in....
Aug 05, 2011 | Intex Automatic Salt Water System for ...
I have a 15x 42" intex metal frame pool an i also
Most likely you are not. The manual is very conservative!!! I have a 14000 gallon pool and I run my intex salt system during the summer at 10 to 12 hrs pump and 8 to 10 hrs chlorination in between those 12 hrs and my pool stays very clear. But..... If you don't clean the unit and let it alarm for low flow, low salt or not run the unit log enough, you WILL HAVE GREEN WATER!!!
Hope this helps, If it does, please rate the tip!
Jul 22, 2011 | Intex Automatic Salt Water System for ...
I have done everything the manual says, but my saltwater system will not stop blinking error code 91. The salt level is fine, and the cell is clean. Do I need to replace the cell. My pool is now green and...
Bummer!!! Looks like you checked both things that would cause the code 91 error for "Low Salt". Here's what I've done to solve my low salt "91 code in the past.. I overshoot by 1/2 bag = 20lbs of the recommended salt add quantity when the code appears. Calculate by using this formula..
.0067 X Pool Gallons. I have a 14,000 gallon pool and when I get the 91 code for low salt, I add about 110 lbs of salt. Manual says 93 lbs...let it circulate for 24 hours by running the pump only and then start the chlorination cycle.. Before doing this, you MUST make sure the cell in clean.. If any calcium buildup inside, it can give you a false "Low Salt" alarm.
I hope this helps!!
If this helps, please rate... Thanks
Jul 17, 2011 | Intex Automatic Salt Water System for ...
How much salt to start with a 15ft round pool
Assuming you have the Intex salt water system and the easy set pool, here's what the manual says:
15x33" - 65 pounds (80 for metal frame)
15x36 - 65 pounds (100 for metal frame)
15x42 - 80 pounds (110 for metal frame)
15x48 - 95 pounds (N/A for metal frame)
hope this helps!
May 28, 2010 | Intex Automatic Salt Water System for ...
I have an intex chlorinator and an intex 24' x 48" round pool. I added only 250 lbs of salt, but the table said 290 lbs. I never got a "low salt" reading. When the water level got low I added water and...
high chlorine can cause problems too it will give false readings for your ph and alkalinity.
The most important thing to remeber is that there is a sequence to follow.
First buy a test kit for salt about 11 bucks for 10 tests. you need to have the ppm's at 3000
if it is to high drain 20% water re-fill and filter/curculate for 6 hours then test again. once at 3000 then go for your chlorine it should be between 1.0 and 1.5 with a test kit now with those 2 in line go for ph adjustment ph should be as close 2 7.6 as possible. Ph will cause more problems like cloudy water or algea more than anything else.
another thing you need to realize is that the intex salt system sucks. Once you set it for the # of hours to chlorinate you are basically guessing as to what is needed. Yes there is a guidence chart as to hours to run but it is over kill and lets too much chlorine be generated start with 3-4 hours of generating but remember also that at 4 hours generating that is nowhere near enough filtering
you will need to shut power off get it out of sleep mode and continue to filter
on avberage a pool should be turned over 3 times a day my pool 7000gl and the 2000gph all in one intex salt pump needs run at least 10 hours a day alone without the chlorinator
my pool only 18' so with your total gallons it will be longer
one last thing to consider is that when in chlorine generating mode the filter slows down because of all the electronics. You can not hear it happen but if you put your hand in front of the discharge you can tell
Jun 27, 2009 | Intex Automatic Salt Water System for ...
Keeps saying low salt level
I would say the rain is diluting the system at this point, or the system sensor has gone out. But if you had heavy rains I would be looking at that idea first.
thanks for using Fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 23, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
156 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
