Question about Cameras
Charge battery install battery, turn camera on after 10 seconds camera turns off and yellow light blinks. installed new battery same results ????
  • rene May 29, 2011
    Type?
  • Cameras Master
  • 17,970 Answers
I suggest remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time.
If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera (Alkaline or Lithium). Finally, there's the possibility that your camera may have a problem that requires professional repair.
Additionally, in the next link, check this article about simple-fix-for-digital-cameras and verified if your lens isn't any problem reviewing this other article fixing-lens-error-on-digital-camera.
Keep us updated.
Posted on May 29, 2011
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Kodak digital camera not charging/ indicator not shown while plug in charger
Either an error occurred during charging, an AC power disruption occurred during charging, the wrong AC power adapter is being used, batteries are over- discharged, batteries are defective, or no batteries are installed in the camera.
Try charging the batteries a couple of times. If that fails, try charging the batteries in an external charger. If the batteries still will not charge, purchase new batteries and try again
Jun 30, 2010 | Kodak EASYSHARE M1063 Digital Camera
I have 3 blinking red lights
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 10, 2010 | Kodak EasyShare One Digital Camera
My Kodak easyshare M853 want charge.Itworked fine til I let it sit or a while now it want charge. Can you please help? I tried A NEW USB CABLE THE LIGHT FLASHES BUT ONLY FOR FEW SECONDS.I HAVE TRIED 2...
Dec 30, 2009 | Kodak Easyshare C813 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Can't charge the battery
I didn't have the time to find out what was the problem cause i needed the camera immediately so i bought a new battery and a new charger.Thanks for the help!!
Aug 07, 2009 | Olympus FE-220 Digital Camera
DSC-F707 camera cuts off after 10 second , just bought a new battery.
I also bought an aftermarket battery for my F707 on Ebay and got the same "for info...." message.
I contacted the seller and they sent me a new one and it worked, don't see a way around it.
Oct 26, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Batteries won't charge?
I would return it and get a new one, and if that doesnt work then buy a different one because these ****. I am stuck with mine, but I wouldnt suggest it to anyone...
Jan 10, 2008 | Sony Handycam DCR-TRV130 Digital Camcorder
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
