Question about Electric Lawn Mower
Tried to start my sears optional start pull or electric .full of gas but wont start
  • Electric Master
  • 7,482 Answers
Hi aunt1231...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
Have fuel and spark but mower still wont start
Hi James:
Just because there is fuel getting to the carb does not mean it is getting through it.
There should be a drain plug on the bottom of the carb. Drain some gas just to make sure any contaminates are removed.
Try removing the air filter and squirting a little (like a thimble full) of gas into the carb intake. Some machines like to be primed. My Sears Craftsman has been hard to start from day one. It just likes a prime. Then runs fine.
May 13, 2015 | Garden
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
Sears troubleshooting
I think you mean it wont run after running out of gas. You may have to remove the spark plug and shoot a small shot of starting fluid in the hole and replace the plug. Cranking means turning the engine with the starter motor.
Aug 15, 2014 | Garden
Craftsman fuse location
A model number would help alot.....it should be under seat and start usually with a 917 -----number. Sears has a website that is nice....enter your model number there and you can pull up a electrical parts and wiring breakdown. That being said a popular place for alot of standard sears tractor mowers is located on the right hand side under the gas tank....clipped to the metal edging. Check the web site at sears parts and enter your model.
Apr 01, 2014 | Briggs & Stratton Garden
I just bought a Sears snow thrower, I put in oil and gas went to start it but the pull cord will not pull up. I then tried the electric starter but it just made a grinding sound. Why won t it start?
Check the crankcase and make sure it has oil. It sounds like the engine is frozen. If its brand new, take it back to Sears and have them start it for you.
Dec 16, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Kenmore 100.85081400 no heat
check the thermal fuse on the blower housing if its open some units wont heat,also check the heating element if heated electrically,or the ignitor on gas fired units,by the number you provided i believe you meant its a 110.85081400 instead of the 100.85081400 (and is electrically heated) you provided which is produced by whirlpool for sears (kenmore) also there is a control board located inside behind the control panel that may be a culprit,but check the first two things i suggested at the top
Jul 23, 2012 | Kenmore Elite HE4 Electric Dryer
Wont start what is spark plug gap whatelse bulb full,new,gas in it,lines hooked
These are bad about flooding with the least amount of trying to. I usually can get mine started by letting it sit for 5-10 min. push the bulb 3-4 times hold the trigger and push the choke on full with 3/4 speed set. Pull 1x. Don't worry usually it won't start on this setting, it really just helps get the choke and carb set. Put choke back 1/2 way and try to start, if so, gas the trigger a couple of times but not holding in down. If it don't start put the choke on full again and try to start without holding the trigger. It should start after this. Take the plug out replace the coil wire onto plug and pull the cord gently to see if you're getting spark at the plug. Holding the coil boot to prevent it giving a small jolt.
Jul 27, 2010 | Homelite Mighty Lite Lawn Trimmer
The car has full electric powers but it wont turn over. what's the problem
Just because the lights go on and the radio plays does not mean you have full power.
Many things can keep a car from starting, and the cold makes them worse.
Did you try jump starting?
And most importantly did you crank the engine for maore than a minute at a time? That means you have flooded the engine with gas.
To fix this, jump the car while holding the gas pedal to the floor. Do this 4 times at 20-30 seconds each.
Then try and start without holding gas pedal.
Jan 04, 2010 | 1998 Kia Sephia
Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
I have 9 hp Craftsman chipper vac with a manual pull start I want to upgrade to an electric start What is involved? Is there a kit to do this?
If it has the option of electric start all you need to do is puchase the starter from Sears and bolt it on. No to hard at all. But for a more definite answer you need model and serial #'s
Kurt
Mar 18, 2009 | Craftsman 6.5 Hp Chipper Vac
Electric Lawn Mower Logo
48 people viewed this question
Top Electric Garden Experts
dannydoesita
JohnPaul Robertson
roeb
Are you an Electric Garden Expert? Answer questions, earn points and help others
