Need help getting wireless netgear to work with lap top. Lap top was reconfigured and don't have old password.
  • 56 Answers
If you don't have the wireless password for your wireless connection. The thing to do is log into the Router's webpage via the Router's IP address. From there you can go to the wireless section and in most routers this section shows the wireless password.
If you have trouble getting on to the Router's webpage. Just comment back on this and I can probably step you through it.
Posted on Aug 16, 2008
I am a Comcast customer with high speed internet. I am trying to get my wireless router to work on my lap top (Toshiba). The lap top will work if connected to the modem directly. However, when I try to...
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Aug 12, 2011 | NetGear WGR614 Wireless Router
Hey, my name is Wesley Murphy and I'm having trouble with our Netgear g54 wireless router. We just got a lap-top and we're trying to get wireless set up on it. We do have internet, that isn't the problem....
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
you might have put in the wrong password or user id check to make sure you have put these in correctly first make sure the caps lock is on/off what ever applies to your user and password id that you provided to your ISP
also
make sure your routers settings are correct ie:password user name,firewall settings to allow your internet to connect also test the lead/s whether usb or ethernet you might check your modem first to make sure that you are getting a connection
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
last resort ring your ISP internet sevice provider get them to check your modem for internet access online
hope this helps
NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
hope this helps
Feb 10, 2011 | Computers & Internet
I want to connect my lap top to a wireless Netgear
You need to do exactly that.
From your web browser type in 192.168.0.1 put in you user name and password.
Your control panel will come up then you got to wireless settings and turn it on and set a Wep key, write that down then rebboot the router or save the settings.
go to your lappy now and open up your wireless card on the tak bar and search for your netgear click on it then enter that key, You should be good.
Thanks please do leave ratings for all the tech involed in your case, thanks
Jun 12, 2010 | NetGear RangeMax WPN824 Router
I cant log on my lap top through my friends router she dont know
You will need to check the wireless settings of the router.
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on that computer.
router set up page is the page where you can check all the router settings.
Click Here for more information about the routers and network
Feb 24, 2010 | NetGear WGR614 54Mbps Wireless Router...
I need password for my netgear wgr614v7 to hook up lap top the lap top is an dell latitude
the default setting is open (no password required) if someone else changed it in the router you need to ask the person who changed it or reset your router and start over.
Feb 05, 2010 | NetGear WGR614 Wireless Router
My lap top will not recognize router. This
If the product is registered then pleas log a complant with netgear. Visit the link below to create a suppor ticket with NETGEAR:
my.netgear.com
Sep 04, 2009 | NetGear WGR614 Wireless Router
NETGEAR USB WPN 111 and linksys router problem reconfigure proble
check if the usb light on the modem is lid or not.
try to reinstall the usb drivers.
and visit http://www.aakashjain.com/General+Troubleshooting+Steps+If+Your+Internet+Is+Not+Connecting.aspx
here are the simple steps u can follow.
Feb 17, 2009 | NetGear Wireless-G USB Adapter...
No signal to lap top
reset the router n reconfigure. ensure that your pc IP @Network Settings are set to "Obtain IP"
Jul 02, 2008 | NetGear WGR614 Wireless Router
Please help!
1. Click Start, Run, CMD, hit enter and write down the ip address of your default gateway.
2. Open your web browser, in the address bar type http://(ip of default gateway).
3. Type 'admin' for both username and password. If this doesn't work try using admin for just the password.
4. Go to wireless settings and first make sure that the SSID broadcast is enabled, if not enable it. Second, go to the wireless security section and choose an encryption method, i recommend wpa personal. Use a passcode that is easy for you to remember, you will need to enter it before you can access the internet wirelessly.
Apr 08, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
