Question about Refrigerators
HI, I have a fridge freezer Model TRF295. there is no brand on the freezer so not sure if it is the powerpoint trf295 that people have made reference to on your website. I broke one of the drawers this morning and have been trawling through the internet to find one replacement drawer. can you help? even if you could help with the model of the fridge/freezer combo?
  • 489 Answers
SOURCE: LG LRFD22850 Replacing support grid for bottom crispers in refrig. Need help.
It is a challenge to replace those grids.  Instead of trying to fit the support grids into the frame, bend the frame slightly to fit the grids.  You will need to remove the steel support from the frame before bending the frame.  That is what I have been able to do when I have those problems.
Posted on Jun 08, 2008
tech master
  • 120 Answers
SOURCE: crisper drawer freezes veggies
need more info what brand model and is it a side by side or top mount ? more info will be helpful
Posted on Oct 15, 2008
  • 13 Answers
SOURCE: wheels on drawer broke off and I need to replace
This is the manufacturer's link to their parts list for your model:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208198977.pdf
Original link with manuals, customer service numbers, etc:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KSCS25INSS&siteCd=KAD
Hope this helps!
WizardRepair
Posted on Jul 17, 2009
  • 33 Answers
SOURCE: very loud noise and the middle bit between the
loud noise comes from moving parts such condensor fan motor, evaparator fan motor. be sure they are nt hitting shroud. other is compressor-may be going bad. heat in middle is coming from mullion heater,as long as it doesnt melt gasket or short out, trip breaker should be ok.
Posted on Aug 26, 2009
Testimonial: "Thanks robertflo907 my fridge freezer is intergrated so I cant get to or see the back, is it safe to leave the appliance on. "
  • 52 Answers
SOURCE: The deli drawer popped out and when I tried to put
If that piece broke, you may need to replace that part, I wouldn't recommend any gluing.
Posted on Feb 04, 2010
I have a PowerPoint TRF295 and never took any interest in the temperature settings. I wanted to adjust it but,I don't know which side of the panel is for the fridge and which is for the freezer.Thanks
Hi. Can't make it out in the photo but if they are negative degrees C in the red then your freezer control is on the left.
The ideal temperature setting for a refrigerator is 3?C and for a freezer it's -18?C
Jul 25, 2016 | Refrigerators
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2016 | Hotpoint Refrigerators
Have a fridge freezer trf295 no model indicated. Need to get my hand on a manual. One problem is that the plug for the fridge is behind it don't know what setting fridge or freezer should be at ???
It looks like it might be a badged Sears Special.
http://www.sears.ca/content/bottom-freezer-fridges
The dials in fridges usually go from zero (defrost) to 9. Ideally you want the setting between 4 and 6. Buy yourself two fridge thermometers, they are cheap. Your freezer needs to be minus 16 - minus 18' Centigrade. Your fridge needs to be 2 - 4'C. The thermometers have a green area showing the range. Here is an example.
Aug 12, 2015 | Refrigerators
Trf295 refrigerator
Take the model number an go to the nearest appliance repair store, they can help you.
Feb 12, 2014 | Refrigerators
My powerpoint fridge freezer model trf 285 ice and frost keeps forming on back wall of fridge even with temp turned up to highest
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost TimerProblem
Water Runningin refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 21, 2011 | Refrigerators
Very loud noise and the middle bit between the fridge and freezer isvery hot to touch with my powepiont model no TRF295 what shall i do?
Aug 26, 2009 | Refrigerators
Same deal, Powerpoint fridge freezer. Alarm light flashing.
how do i defrost a powerpoint freezer and what is the right temperature
Jun 16, 2009 | Freezers
Cold freezer warm fridge
The only thing I can say now is to make sure that this unit is level. After that you can check to see what model refer you have and we can go from there.
Dec 30, 2008 | Dometic NDR 1292 Refrigerator
Fridge freezers keeps tripping circuit breaker after 10 minutes or so of being on
Just a thought that this particular powerpoint may be overloaded with other appliances, have you tried pluggin into another powerpoint in another room (on an extension lead if necessary) to see if that breaker trips? This would at least identify if the problem is infact with the fridge.
If the fridge is drawing more power than the existing load on the powerpoint you intend to use, you may need to have the load checked for an upgrade of the breaker or cable, or have a new cable run to a new powerpoint.
Sep 14, 2008 | Refrigerators
Refrigerators Logo
333 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
