Question about Sony PRS-505
Even after wiping off all the books, reloading them, and reseting many times, I'll be reading and the 505 restarts about every half hour. When it restarts it freezes first and I have to remember my page number because when it starts again my reading history is gone. Is there a battery I can replace? I don't want to buy the newer version because I love having the left and right hand page turning capability.
3 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: The bottom half of my
does it means the upper part of the screen still displays? If yes, then it means the screen for your Sony PRS 300 as gone bad or defective. In this case, I think you would be needing a screen replacement.
The problem now is getting a screen replacement. Online stores does not have a replacement screen for this unit. But I would suggest contact Sony via e-mail or phone, and as for the screen replacement of this Sony PRS 300. They might have it or direct you specifically to a dealer where you can get the screen.
Go to Sony's website, click on "Contact us" and you would find their phone number and or e-mail address there.
Good luck.
Posted on Jan 04, 2011
  • 1040 Answers
Tanya, Reset will not help you because the error you are getting is of the hardware in nature rather than of software... It seems that the bus which connects the motherboard and screen or the screen itself is malfunctioning... Therefore get it serviced...
Hope this has helped you.. Thanks...
Posted on Jan 05, 2011
I have a 2007 Suzuki XL7 is it true that after disconnecting battery over a week, you have to reset computer
Usually, disconnecting the battery for more than half an hour will reset almost all computers. It will then have to go through a "re-learn" cycle. You'll use more gas until it does that and it may not run quite right.
Jan 25, 2017 | 2007 Suzuki XL-7
My Paperwhite is the original. I read about 1 hour per day. It holds the charge good.
First, if you have not done it in a while, restart your device. Press and hold the power button for several seconds until you get the option to Restart. Often just restarting any device will resolve many issues.
If you have a lot of books, etc., on the device, go through and remove what you do not need. For good measure, Restart again after deleting a bunch of stuff.
Finally, you could try a Reset. This deletes everything so you have a clean slate. On a Kindle this is not as drastic as it sounds. Although you do not have to, I would De-register the device before doing a reset. You will probably have to re-register anyway. De-registering may avoid some confusion later. Also, if you have documents or material other than books, make sure you can access it again somewhere or back it up before the reset. REMEMBER, DOING A RESET WIPES OUT ALL CONTENT. The device will be just as you received it initiall. To reset:
From Home, tap the Menu icon, and then tap Settings.
Tap the Menu icon again, and then tap Reset Device. Your Kindle will restart.
Hope some of this helps.
Jan 04, 2016 | Amazon Kindle Paperwhite
My son forgot the code of his samsung omnia hd i8910 1 want to reset the settings but i cant because of that code
    • Open the telep *2767*3855# - Factory reset hone dialler by pressing the software button on the bottom left of the front screen.
    • Type *#7370#
    • You'll be asked if you want to restore all of the original settings and warned that the phone will restart. Choose yes.
    • Now you'll be asked to enter the lock code. Enter 00000000 as the code. That's eight zeros.
    • Click the OK button and the phone will reset. This takes some time so be patient.
    Occasionally you'll find yourself in a situation where you can't use the screen and therefore can't use this process to reformat a phone. In that case you'll need to do the following.
    • Pull the battery to make sure it's powered off correctly then replace it.
    • Hold down the green call button and the middle button at the same time.
    • With those two buttons held down, press the red power on button.
    • The phone should give you the option to format now and you can press the green key to accept it.
    Be aware that the phone memory and the hard drive will all be wiped clean so back up anything you need to keep either to a PC or to a memory card. Don't forget to remove the memory card before the reset as some memory cards may also be occasionally wiped in this process.
Aug 29, 2012 | Samsung OmniaHD i8910 Smartphone
I need my gmail account acitvated
If you're sure about your username - click on Can't access your account? under the login box.Check the first option "I don't know my password" and you'll be asked for an email where your login details/reset password instruction to be sent. You'll have to answer few questions (like security questions and contact details you've set when registering).
Its a bit tricky, but whole process is less than half an hour even if it fail first time
Jul 29, 2012 | Computers & Internet
My brother gifted me an iPhone 4. I want to erase all the data contained. How I can do this?
You need to factory reset the iPhone. it is a simple process
Begin the process, if possible, by backing up the data on your iPhone 4. Do this by syncing the phone (each time you sync, it creates a backup). This lets you save all your data and settings to restore to the phone after the reset.
When that's done, locate the Settings app on your iPhone homescreen. If you've rearranged your apps, locate it wherever you put it. Tap the icon.
Scroll down to the General menu. Tap it.
Scroll all the way to the bottom to the Reset menu. Tap it.
On this screen, you'll be presented with a number of reset options, ranging from just resetting all the iPhone 4's settings to resetting its dictionary or homescreen layout. The factory reset option is Erase All Content and Settings. If you're sure you want to factory reset your iPhone 4, tap it.
You'll see a warning reminding you that you'll be erasing all music, other media, data, and settings if you do this. If that's not what you want to do, tap Cancel. Otherwise, tap Erase iPhone.
It will generally take a minute or two to factory reset the iPhone, but when the process is done, you'll have a brand-new, pristine iPhone ready for whatever your next step is.
May 24, 2012 | Apple iPhone 4 Black Smartphone
Scanned and code 505 came up what is it
I don't have a book on that bro....just call your nissan dealer on monday and they'll tell you
Apr 22, 2012 | 2001 Nissan Xterra
How can i reload bios or upgrade.on a thinkpad r31 running ubuntu 11.04 if i can do it i'll use freedos or something.i never saw a book on troble shooting,but bios dont allow me into only half of it.is...
Yo! I will have to direct you to a website where you can download anything for your computer. please follow the links below..
www.download.com
http://www.filehippo.com/
Aug 08, 2011 | IBM ThinkPad R31 2656 Notebook
My HTC hd7 keeps on rebooting
HD7 is powered by a qualcomm SoiC Snapdragon chipset. It's basically a large chip containing the cpu/video processing and input output functions. The same chip is used in the HD2 and has been known to cause some problems.
I'll make an assumption and ask you to try something.
Please find some hd movies and place them on the phone memory, then try continuously running them. Before starting this test, measure the room temperature. If you have .. let's say 25 degrees celsius (or equivalent fahrenheit) make a note, writing down the room temperature at witch you started the experiment. Run the movies continuously untill the phone either freezes or restarts. When the phone does that, write down the time elapsed since you started and stop using the phone for about half hour.
Next place the phone in a transparent bag, try to seal it and put it in the fridge (not freezer) for half hour. Open the freezer, and run the same movies again WHILE keeping the phone cool in the fridge. Check to see if you notice any improvements in the time elapsed until a restart. If you do, please reply here and i'll explain what actually happens with the phone and what is the real problem with it (it could get a little..technical).
PS you can use any cpu demanding app instead of movies, let's say 3d games, navigation apps etc.
Jun 29, 2011 | HTC HD7 Cell Phone
I have charged my sony e readerPRS - 505. However
Connect the Reader to the Computer using the supplied USB cable and check whether it is charging,. If it's charging , then keep it connected from at least 4 hour to get it fully charged. If its fully charged, perform a soft reset. To soft reset, just press the RESET button. After soft6 resetting charge it for at least 4 hours., That should resolve the issue. All the best! !
Nov 30, 2009 | Sony E-reader Portable E-book MP3 Player
Sony PRS-505 Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
