Question about Garden
Hi Guru I have a 32cc Craftsman blower .. that i can keep running (only if i keep priming the bulb). I have taken apart the carb and cleaned and applied air to the lines to make sure no blockage. Any suggestions appreciated. Thanks
  • 659 Answers
Have you tryed pulling the fuel filter out of the tank and make sure that it is clean as well? If you can get fuel but not much I would assume it is coming from the filter.
Posted on May 29, 2011
Have a craftsman 32cc craftsman model #358791060 I have changed gas lines and is hooked up properly but when I prime the bulb the gas pours out of the carb. Any suggestions as to how to fix this?
Although you think you go it connect correctly, it sounds like you got the primer connected backwards.
Here is the basic layout for a remote primer system.
Apr 17, 2015 | Craftsman Garden
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
I have a craftsman 32cc weedwacker line trimer. Having trouble starting it. I noticed that the fuel lines didn't look to good so I replaced both. Installed a new spark plug and put in a fresh tank of gas...
Sounds as if the Carb needs to be cleaned out. Get yourself a can of non-chlorinated brake cleaner and spray the carb out really well. Then reinstall the carb. Also check any ports in the carb to make sure there isn't any debris blocking the flow of fuel. I would also suggest getting some Stabil Marine (blue) fuel stabilizer. The ethanol in gas destroys small engine carbs. Just mix this in with your gas tank the next time you fill up. How old is this fuel? The ethanol also absorbs water, so even while in the gas can it is obtaining moisture. The Stabil Marine formula helps lesson the effects of the ethanol.
Aug 02, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
32 cc blower not starting
your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Jun 29, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Jun 10, 2009 | Craftsman 4 Cycle Blower/Vac
My tro bilt model tb320bv gas leaf blower will not run at full th
The carburetor may need to be taken apart and cleaned or rebuilt. If you haven't taken one apart before your best bet is to see if you can get an after market carb for it, that would probably be the cheapest way out.
Jan 12, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
