Question about Koolatron Vacuums
No power going into WC18 wine cooler - Koolatron Vacuums
    President:
  • 1,216 Answers
A fuse must be down check all fuses
Posted on May 29, 2011
How to remove red wine stains from carpet?
Get some Oxyclean spray from the grocery and use that.
Aug 08, 2017 | Vacuums
Panasonic mc 6220
To open a Panasonic MC 6220, pull quite firmly (but not enough to break it) on the vertical wine molded handle on the front of the vacuum cleaner. It sits between the 3 power selections buttons, and the window that shows how full the bag is. It takes a U3 bag - remove the orange/red mounting bracket from the wall of the vacuum, and then from the bag itself. Make sure you mount it properly on both (and the bottom of the bag so it fills completely) to avoid any dust leaking out. Good luck! This is a fabulous vacuum and lasts a long time, if you maintain it.
Aug 24, 2014 | Vacuums
How to cook hamburgers - temperature, etc.
Prepare Patties
1. Put minced scallions and chopped mushrooms in bowl.
2. Add red wine vinegar.
3. Add ground beef to bowl.
4. Mix everything together with your hands.
5. Flatten the beef into four patties that are 1/2-inch thick and 5 inches in diameter.
Cook Patties
1. Set stove-top grill or burner to medium-high.
2. Preheat nonstick frying pan. The pan is the correct temperature when a drop of water dances on its surface rather than sticking to it.
3. Place patties in the pan and cook for 2 to 3 minutes.
4. Flip patties and cook for another minute, and then add sliced cheese to the tops of patties if desired.
5. Cover pan and allow burgers to cook for a final 2 minutes. Cook 3 to 4 minutes for well-done burgers.
6. Remove hamburgers from pan and place in hamburger buns.
7. Add condiments and toppings such as ketchup, mustard, sliced tomatoes, lettuce, red onions and pickles.
Share some please! ü
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 12, 2011 | Vacuums
Hi, I have a older model Sunbeam water cooler that hasn't been used for a while ..Need to know how to clean and sanitize it? got any ideas
Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Jun 07, 2011 | Vacuums
Wine cooler has error code on bottom half "E4". What are the possible problems?
Sound like a problem with the fan unit; the connectors to the fans get moisture in them and corrode.
Just stripping the wires and hard connecting them, only tool needed is a phillips screwdriver. There are 3 connectors on the side to remove the control panel shelf. Its a pretty simple job.
If this not solve it, need to replace the fan.
Hope helps.
Mar 31, 2011 | Vacuums
Prima water cooler just noticed that the cold water is not cold. Looked in back and copper coils all iced up.. turned off and put cut to collect water, what needs to be replaced> have another...
try to adjust to lessen the setting of thermostat maybe the setting is to full thats why the thermostat cannot cut off after the water chilled. then observe the unit.
Mar 02, 2011 | Vacuums
Hamilton beach water cooler has mildew taste
Hi, your post is showing a photo of a vacuume cleaner? Don't think so,lol. If you water cooler has a mildew taste in the air, you need to go to a hardware store, just about any, and buy a roll of evaporative water cooler tablets that you add to the water to prevent this from happening. They are the size of a quarter and come in a roll or other container depending on the amount you buy. They have different names, so just ask for the tablet additive for your water cooler and they will no what you need. I hope this has helped you.
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Oct 23, 2010 | Vacuums
How to add freon to dandy wine cooler
Adding Freon to a refrigeration system takes very specialized equipment and years of experience...it would be impossible and irresponsible of me to try to tell you how to do it through a computer...
heatman191
Aug 17, 2010 | Vacuums
I have an eureka capture + pet lover vacuum, I
A high pitch wine may be the sign of a bad bearing. Try to narrow down exactly where the noise is coming from. You may have to remove the brushroll and turn it on without it to see if it could be coming from there.
Jul 17, 2010 | Vacuums
Vacuums Logo
57 people viewed this question
Top Koolatron Vacuums Experts
JoeVacs
Are you a Koolatron Vacuum Expert? Answer questions, earn points and help others
