Question about Home
Water doesn't come out strong enough Is there a water reducer in there?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 190 Answers
The aerator on the end of the faucet may be restricting the flow. If you are on well water, the well pump or pressure tank may be the issue. A licensed plumber would be able to diagnose the latter issue.
Regards,
DIYpro
Posted on Jun 08, 2011
  • DIYpro Jun 08, 2011
    Also, if the valve is of the pressure-regulating type, this can certainly also cause for reduced pressure than what one would expect. Unfortunately, it is the nature of the valve and cannot be adjusted.
    DIYpro
Not enough flow and pressure to run sprinkler system
pressure in centrifugal pumps depends on the number of impellers in the pump housing, the clearance of the impellers to the housing and the power of the motor to drive the impeller/s
volume flow is also important as a pump without a high output will not produce pressure
check the jet size at the foot valve that is used to help lift water to the pump
It is a jet pump and will have a smaller line back to the foot valve for that purpose
next wil jet pumps if there is too much flow to the outlet , the pressure required to help lift the water to the pump is reduced and the volume is also reduced
you indicate 4 sprinkler heads per zone but how many zones are operating at one time
check the expected delivered volume for the new pump against delivered volume of the old pump as a starter to find the reason for the poor performance of the new pump
check also the rpms of each pump as that also has a bearing on volume produced
Mar 26, 2017 | Flotec Pump FP4032-10MK
My lg intellowasher wf t8501tp won't go into a
Check the pressure switch and hose. Pressure switch is what turns the pump on and off. Trouble is usually in the hose so check it first. Look for the hose to be unattached or clogged.
Jan 13, 2013 | Washing Machines
Ac drips inside
Tip it outward so the concensate will tend to overflow outside. Be careful you dont drop it.
Typically, window AC will collect the water in a tray to help cool the bottom ocondenser and rely oin evaporation to get rid of the water. Sometimes, during high humidity, it doesn't evaporate quickly enough and will spill out of the pan.
You could drill a hole in the pan outside ... whicl will drain the water ... but reduce the efficciency.
Interesting - I just got your request for a chat ... here is your answer ... and you didnt have to pay for it.
Sep 05, 2011 | Frigidaire FAC107P1A Wall/Window Air...
Overheating
Hello and welcome to FixYa! If you have overheating problem, it can lead to multipleissues. You may be running on low coolant that's why the vehicle overheats. Ifthat's the case, please add coolant and make sure that it sits on the rightlevel, too much coolant can cause overheating too for coolant will overflow. The vehicle may have a faulty or worn out radiator blowermotor that's why it overheats. If that's the case then you will need a blowermotor replacement to resolve the issue. If the radiator is clogged with dirt and rusts this issueoccurs too. The coolant doesn't flow normally on the cooling system if it'sclogged. If that's the case, I strongly suggest that you have the radiatorflushed to drain out dirt and rusts. If you think that the radiator served youenough then it's better to have it replaced. Please do check the radiator hoses, If you have worn outhoses it can cause coolant leakage which can result to overheating. A tiny holeis good enough for the vehicle to overheat. A faulty thermostat sensor can cause the issue too. If youhave worn out thermostat, the fan may not trigger that's why the fan won't workwhen under stressed conditions. A blown radiator blower fuse can cause thisissue too so I suggest that you check the radiator blower fuse and replace itwhen necessary. What causes the radiator blower fan fuse to blow? It's becauseof a failing radiator blower motor, If that's the case have the radiator blowerfan motor replaced. If the fluid in radiator doesn't circulate then it meansthat you have a blown head gasket or a faulty water pump. I suggest that you gofor the water pump replacement first specially if you think that it's near theend of it's service life. Usually, water pops out the radiator when engine isreved (a sign of faulty water pump and possible blown head gasket). Hope you find this information helpful enough and thank youfor using FixYa! Have a good one!
May 24, 2011 | 1996 Mercury Sable
Sometimes there isn't enough hot water for a shower when the hot water mode is set.I have set the hot water temperature to 65 degrees
Are you waiting long enough for the water to be totally heated, before showering? Unfortunately, all the water doesn't reach 60 degrees celsius (140 degrees fahrenheit) in a matter of minutes. Try switching to the hot water mode sooner and allow enough time for the system to heat up entirely. If that doesn't solve the problem, the burner may need cleaning,
Hope this helped you. Please let me know. Thanks.
May 05, 2011 | Heating & Cooling
Car overheats and always says the water reservoir is empty and it is full of water
Feb 02, 2011 | 2000 Saturn Ls 4dr Sedan
Cooling system clogged. water not circulating. car overheats
Dec 08, 2010 | 1999 Oldsmobile Intrigue
Grinds coffee but no water comes thru dumps dry grounds into hopper then stops. A couple of times it has worked ok but then goes back to the same problem. Ahhhhh I need my coffee
Sounds like the grinder is grinding too much coffee than the brew unit can handle. Otherwords itis overloading the brewunit. Try reduce the aroma in the coffee menu to mild.
Jul 12, 2010 | Saeco INCANTO DELUXE Espresso Machine
Overheating ford transit
Feb 14, 2010 | 2002 Ford Escort
Home Logo
35 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
