Question about Lexmark C533DN InkJet Printer
I need to change the Black 105XL cartridge. How do I open the printer. Does it need to be turned off to change cartridges?
  • Official Brand Answer
  • 3,344 Answers
This video How to Replace the Ink Cartridges of your Lexmark Printer applies to S300, S400, S500, S600, Pro200, Pro700 and Pro900 Series printers.
Posted on Jun 01, 2011
Chsnge ink cartridge
Hi there!
Here's what you can do to change the Printer cartridges.
1. Make sure that the printer is turned on. Turn it on if it's not.
2. Open the printer cover, then wait until the carriage is idle.
3. You will see the Tri-color & the Black cartridge. The tri color cartridge is the green one which is on the left and the Black is the one on the right.
4. Press down the Cartridge you want to replace you will notice that it will be released from the cartridge holder. Once it's loose slide the cartridge out.
5. Make sure that the correct Genuine Hp Cartridge is what you have. For your printer HP PSC 1610, HP 94 will be for the black and HP 95 is for the tri color.
6. Open the cartridge package. Remove the protective tape. Make sure that you do not touck the copper colored contact and nozzles.
7. Hold the print cartridge with the sticker facing up and the copper colored contacts facing the printer and slide it into the cartridge.
8. Use your thumb to push the cartridge all the way in. You may need a little force to make sure that the cartridge has been installed securely.
9. Once installed close the cartridge cover. Make a copy to test.
Hope this helps!
Jun 17, 2011 | HP PSC 1610 All-In-One InkJet Printer
Hello. I'd like to use 105XL cartridges in my pro205, i think i have to reset the chip or to reset my printer because of these kind of cartridges are designed for more expensive models of printer. How...
The 105XL cartridge is only available for the higher-priced printer models like Pro805, Pro901 and Pro905. It's not compatible with your Lexmark Pro205. I'm sorry if I didn't have the answer you expected.
Jun 07, 2011 | Lexmark Prospect Pro205 Wireless...
My daughter loader a black ink cartridge without removing the cellophane tape. The printer is now flashing the check black ink cartridge message. We have tried reloading the cartridge properly. Still not...
here is what you do .
1.first unplug the printer ,and shut down you computer .
2.then open then printer cartridge area. remove both color & black cartridges
3.check the black cartrage ( the head of cartrage is it damaged ,,, i mean it should just be like glass surface no ups and downs .. if the cartrage is ok then (youdont have to change it )
4.power on you printer without loading any cartridge .
5.now unplug again and insert cartridge only black .and plug your cartridge .( note PC will turn off in entire procedure) and let your USB cable out of the printer
6.turn on your PC when you see the desktop insert the USB cable. and let the process happen ..!
7. give out print command
i hope that will solve your problem !
do vote /write if it helps you
Apr 04, 2011 | HP Photosmart C3180 All-In-One InkJet...
HP6988 printer skips lines and only prints bottom half of black lines. Installed new black cartridge, printed test page. Still no change.
Most deskjets include a maintenance section. Open this printer in PRINTERS on Control Panel (assuming Windows). right click on the printer and select properties. You will have to look for the maintenance section. There you should find an option to "clean heads". You may need to do this several times if never done before. After each cleaning, print a test pattern. Hope this helps.
Mar 31, 2011 | HP DeskJet 6988 Printer
Changed the black cartridge and it still reads to install black cartridge
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Jan 19, 2011 | Office Equipment & Supplies
While color cartridge prints well, the black and white -- despite new cartridges -- is faint and/or blurry.
Hi, you are facing this issue as your Black ink Cartridge is empty, if you open the hud of the printer you will see there are two Cartridge, one is for Color and one is for Black, your color cartridge is fine as it will printing properly. In order to resolve the you need to change the color cartridge. If you want to replace the Cartridge by your own below weblink will help you:
http://www.ehow.com/how_4443714_install-cartridge-dell-photo-printer.html
Feb 22, 2010 | Dell Inkjet 720 Printer
Ink
  1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
  2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
  3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
  4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
  5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
My x1240 scans but does not copy or print. What do you suggest?
You will need to do the following diagnostic tests to determine the exact cause of the error:
· Remove the ink cartridges
· Perform the self test (test B below)
· Test the ink cartridges
A. To remove the ink cartridges:
Switch the printer on by pressing the green button.
Open the front cover of the printer. The cartridge carrier should move to the center of the opening.
Remove both cartridges.
If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand.
Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer.
Inside the printer, locate the silver metal carrier bar on which the print carriage slides.
Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion.
Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening.
Now pull both cartridges out.
B. To perform the self-test:
Disconnect both the power cable and the USB or parallel cable.
After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.)
Turn the printer off by pressing the green power button.
Hold down the grey paper feed button.
Turn the printer on by pressing the green button.
After the printer begins to feed paper, release the grey button.
Once the paper exits the printer, press the green button to turn the printer off.
If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. Please contact our Technical Support Centre for your service options. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below.
C. To test the ink cartridges:
Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place.
Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step.
Turn the printer off using the green power button.
Hold down the grey paper-feed button.
Turn the printer on using the green button.
If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly.
Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly.
If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase, or contact our Technical Support Centre.
IF u have problems u can use this link:
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Mar 15, 2008 | Lexmark X1240 All-In-One InkJet Printer
Lexmark z53
You will need to do the following diagnostic tests to determine the exact cause of the error: · Remove the ink cartridges · Perform the self test (test B below) · Test the ink cartridges A. To remove the ink cartridges: Switch the printer on by pressing the green button. Open the front cover of the printer. The cartridge carrier should move to the center of the opening. Remove both cartridges. If the carrier does not move to the center of the opening, you will need to remove the cartridges by hand. Turn the printer off and remove the power supply cable (the small circular one) from the back of the printer. Open the front cover of the printer. Inside the printer, locate the silver metal carrier bar on which the print carriage slides. Locate the black rubber carrier belt above the carrier bar. This belt has tracks on its inner portion. Grab the top portion of the belt and move it toward the right. As you move this, the ink cartridge carrier will move to the left. Continue to move the belt until the carrier is in the center of the opening. Now pull both cartridges out. B. To perform the self-test: Disconnect both the power cable and the USB or parallel cable. After one minute has passed, plug the power supply cable (the small black circular one) back in. (This step is necessary to reset the printer.) Turn the printer off by pressing the green power button. Hold down the grey paper feed button. Turn the printer on by pressing the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the power light blinks twelve times while no cartridges are installed, there is a problem with the printer. If this is a new purchase, you can also exchange the printer at the point of purchase. If the paper went through the printer as if printing was occurring, you will need to do some more testing. Continue as instructed below. C. To test the ink cartridges: Open the front cover and insert only the black ink cartridge. Make sure that you push it back until it snaps into place. Close the front cover. If the light flashes twelve times, there may be a defect in the black cartridge. If not, proceed to the next step. Turn the printer off using the green power button. Hold down the grey paper-feed button. Turn the printer on using the green button. After the printer begins to feed paper, release the grey button. Once the paper exits the printer, press the green button to turn the printer off. If the light flashes twelve times, there may be a defect in the black cartridge. If a page came through with a black line, your black cartridge is working properly. Now you need to take the black cartridge out and perform the same steps with the color cartridge. If the light flashes twelve times, there may be a defect in the color cartridge. If a page came through with colored lines, your color cartridge is working properly. If one of the cartridges is causing the problem, you will need to replace that cartridge. If it is a new cartridge, please exchange it at the point of purchase. Good luck
Aug 30, 2007 | Lexmark Z53 Color InkJet Printer
Lexmark C533DN InkJet Printer Logo
238 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
