Question about Frigidaire GLTF530DS Front Load Washer
Loud banging seems to be coming from inside the drum. Really noticable during spin cycles. Had the struts replaced a few years back, that was my first suspicion. They seem fine. Did notice the metal drum assembly sagging forward and down withing the drum overall drum casing. Metal unit spins freely and seems to be hitting something as I spin it by hand.
Bab shock
Posted on Jul 14, 2011
Why does my LG washing machine make a rattling noise even at low RPMs?
It is not uncommon for items that get loose in the washer (paper clips, coins, etc.) to slip underneath the "paddles" and then make noise as the drum turns. While an annoyance, it is not anything to be overly concerned about. Eventually the item(s) will come back out.
Mar 19, 2015 | LG WM-2277HW Front Load Washer
Amana top loader washing maching permanently tilted drum & loud banging during spin cycle
I guess you washed some curtains and blankets in it that it spun unbalanced. There are 2 things. One is the one of the suspension springs broke off. Another is the center post is already bent. You may have to check inside. If you are handy, you can take off the cover and check. Suspension springs are dangerous when being replaced. You may have to wear a pair of goggles. With the centerpost, it is difficult to replace. I suggest you call a technician for this.
Jan 17, 2014 | Washing Machines
Loud banging noise Kenmore model # 41744102301
Hello,washing machine is mounted on two supports, if it is damaged first which is where the engine so both need to be replaced because they wear out. If you're just a little handy so you know it himself .Ak you order parts so precisely that type because they are different .
May 02, 2013 | Washing Machines
I have a Kenmore washing machine model # 11020854990 which recently had a loud banging and knocking sounds during the final spin cycle. Now I notice the drum seems to have dropped down about an inch plus...
Could be a loose basket nut, or on the bottom tub support there are a few springs that help locate the tub. One of the springs could have come off or broke.
Nov 28, 2017 | Kenmore 24032\24036 Top Load Washer
Maytag Centennial washer makes loud bang and the end of cycle.
I don't think it would be the bearing, as no sounds abnormal occur during it's wash cycle. I think it's at the end of the spin dry cycle, that a "brake" is applied which stops the drum from spin drying, but is being applied overly hard, which causes the drum to "BANG", stop abruptly by the brake. Only a washer repairman could deal with that problem, but, it's NOT dangerous to the washer, IF that's what the problem is. Contact a washer repairman in your area, and they'll probably be able to tell you if it's THAT or something more serious, which I doubt. The reason why the washer moves a bit when at the end of the cycle is probably because the brake which causes the spin dry cycle to come to it's end, does so very fast, which displaces the centrifugal energy abruptly towards lateral motion. Not really dangerous either.
Sep 19, 2012 | Maytag Parts Washing Machines
Washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
May 22, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Loud noise during washing/rinsing cycles
I just replaced the bearings on my Front loader Maytag MAH5500B, as it sounded like a freight train during the spin cycle. The bearing replacement fixed the train problem.
NEW PROBLEM NOW: It's been about a month now since the bearing job and now something is clicking/binding when you spin the back belt wheel. I have taken the belt off and carefully move the wheel and I still get this clicking noise. It sounds as if someone is hitting the plastic drum that the tub is surrounded by. I really doubt it's the bearings this soon, as the sound is not the same! No leaks or metal shavings to speak of or rubbing of the belt wheel.
Seems like it's more noticeable during the wash/rinse cycles then the spin.
Can anyone help.???
Oct 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Loud banging in spin cycle zanussi aqua cycle
if you can get the front plate off you will probably notice that the drum stabilizer roller has either fallen off or is damaged. This part is replaceable and should be no more than 20 bucks.
Apr 27, 2009 | Zanussi F1045W Front Load Washer
Front loader making loud noise with spin cycle
It may be something that was in the wash and fell thru the holes in the inner drum. Check all the plastic agitators and make sure they are all secure and an attach bolt has not backed out of one and rubbing the outer tub. It will wear a hole in it fast if it is.
Usually when the bearings go bad, it gets very loud on the spin cycle, like a loud roar and sometimes clothes will have rust or grease stains on them.
I just replaced my tub bearings on my Frigidare and spent about $60. They are all pretty much the same. On mine they only list the complete rear outer tub assembly with bearings, but you can knock the old bearings and seal out and match them up at a bearing supply house or you can buy online. Online seems much cheaper. If you buy bearings, make sure you get ones with a -2rs on the end of the part number. ex. 6308-2rs. They are sealed and hold up much better in water environment.
I would give it a try, the junk man doesn't care if it comes in pieces or one big piece.
There are a couple online articles that can probably help you. Do a google search for 'washer rear tub bearings"
Jan 29, 2009 | GE WPXH214A Front Load Washer
Frigidaire GLTF530DS Front Load Washer Logo
402 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
