I have a DV250 WiMAX/WiFi Modem that connects to the internet if I use a LAN cable. Other laptops with wireless modems see the network but cannot access the internet.
ZeroCool2u
  • 15 Answers
SOURCE: How do I make my
there should be a wizard built into your operating system that will let you do that or if you have the little wireless icon on the bar with the start menu double click that and click on the option on the upper left part of the screen that says "setup a wireless network for a home or small office" you should have the option of securing it with a password.
Posted on Jul 04, 2008
mrbrown0603
  • 45 Answers
SOURCE: limited or no connectivity to
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Posted on Oct 08, 2008
louislevel_2
  • 374 Answers
SOURCE: I'm having problems setting up
Maybe you can try to check your fire wall setting,sometime antivirus is blocking your camera through internet access.you can add your camera for exemption for blocking in the iternet.
Posted on Feb 28, 2009
dante777
  • 623 Answers
SOURCE: dell dimension 2400, wireless internet
Hi Whitney,
I was able to locate manual and a troubleshooting guide.
  1. Manual
  2. Troubleshooting Guide
Summary: Your modem only supports 802.11b standard, which limits the throughput to max. 11Mbps (compare to 802.11g = 54Mbps, 802.11n = 108 Mbps). In other words: your connection is only about 10% of the speed compared to a wired connection via Ethernet cable (100 Mbps). So - if you can - you should try to use a wired instead of a wireless connection, but you have to decide what makes is more important to you: having no cable and you can be away from the modem or the connection speed.
This also means - and that is in regards to APremkumar's solution - that you can skip all 802.11n adapters (this would just be a waste of money). Since you will not find an adapter that only connects to a class b network, look for something like "802.11b/g".
An example page is here. You can choose between an internal (PCI card) or external (USB adapter) solution. Both are ok and the decision depends on the availablity of a free USB port on your Dell and your comfort of opening the computer case or not. (You can always come back here and ask for help;-)
If you have any more questions, please let me know - I'm happy to help!
Posted on Mar 31, 2009
whitebirch
  • 433 Answers
SOURCE: hi i have a acer Veriton 3600G and i am trying to
Your modem in your computer is the 56K (telephone not broadband)
For your Local Area Network you want the network drivers. It will not harm anything if you download drivers for the modem or network because when you set up your local network it will internally switch of the modem and use the network.
Do the Broadcom -LAN and the Conexant -Modem
please leave me a rating...
Posted on May 17, 2009
My laptop is HP. With windows 8 I need to turn off broadband ?? To connect WiFi lan setting only..No dial up
If your HP has a Wireless adapter - should have - you should connect to WiFi as soon as you start up your computer. Some start up WiFi throgu a compination of function keys, you should check your keyboard and your user's manual.
I don'r Understand what do you mean by "connect WiFi Lan settingg". WiFi is not the same as LAN. LAN is the cdirect conection to a broadband modem and if your LAN port is coonected through a cable to your modem, you connect to Interent at startup,
No dial up? I'm not sure if anywhere in civilized wold anyone with a computer still uses a dial up Internet modem.
Resumed: EXCUSE ME BUT YOUR QUESTION IS A MESs
May 26, 2015 | Computers & Internet
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Cant get on the internet
Heelo,
we need more information then this.
What make and model laptop, operating system etc.
How are you wanting to connect (wired or wireless) which make and model modem you have and they type of internet connection (ADSL, cable etc)..
Feb 17, 2011 | Computers & Internet
I want to start inter net from my laptop what to do
Hello Punitrava, Hi, you can connect to the internet several ways, here are the common ones. 1. Via a free WIFI hotspot, find a WIFI area like in malls or coffee shops and enable you WIFI connection on your laptop. after enable the laptop detects the wireless connection and simply connect. 2. Via a USB modem, inquire about this on your wireless telephone company. 3. Via the Local Area Network like computer shops, insert any available LAN cable on your LAN connection, you need to consult the LAN administrator. 5. Via a DSL connection, just plug in the LAN cable from a DSL to your laptop. you need a DSL/internet account from your telephone company.
Jan 08, 2011 | Compaq Tablets & eReaders
What is difference between lan card and modem
The difference between a Lsn Card and a modem are this - A Lan card is a card that you slide into the side of a laptop and it can allow you the ability to get onto a network wirelessly. A Lan card for a PC allows a Lan connection by way of a CAT 5 cable that will allow you to get onto the internet or if a crossover cable is attached to your pc to another you are directly connected to the network. A modem is a piece of hardware that is installed into a slot in the PC that will allow you the ability to get onto the internet by attaching a phone line to it through the RJ 11 jack (which it comes with 2 rj11 jacks on it).
Here is the picture of LAN port and Modem port
Dec 24, 2010 | Siemens Computers & Internet
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
Acer aspire 9410, cannot connect to the internet using dial-up
You have two different devices here. A modem and a wireless network adapter. Two totally different devices. It sounds like the modem quit working but the wireless network adapter still functions. I'm assuming that the modem is built it. If you absolutely have to have it you could buy a PCMCIA modem if your laptop has a PCMCIA slot to plug it into. You could also have a corrupted modem driver.
Oct 01, 2009 | Acer Aspire One PC Notebook
How do I hook my wireless usb netopia chip in order to sign on the internet
You ned to contact an Internet Service Provider to determine if your USB wireless adapter is compatible with their service.
Read this info for an idea on how to connect to the Internet :-
There several ways to connect to the Internet.
1. You can use a cable or DSL modem and connect this modem to the laptop with a LAN cable.
2. You can use a wireless router with a cable or DSL modem and connect to the wireless router using a wireless card (a PCMCIA wireless card or the laptop may have a built-in wireless card). This wireless card can also be used in WiFi locations such as the airport, McDonalds and Starbucks etc.
3. You can use an USB G3 wireless adapter. This type of device uses the G3 mobile network and may not give you Internet coverage in some locations.
All these require an Internet Service Provider and the costs vary widely depending upon the various plans they offer. Check the ISP in your area and compare the plans and cost of their plans and pick the one that best suits your needs.
Sep 11, 2009 | Computers & Internet
Presario 900 laptop what internet dongle do i need to connect to internet.
that completely depends on what kind of internet service you have.
The laptop has a Ethernet connector so, if you have a internet connection in your home you should be able to connect it with a wire to the router or the modem and it should work.
Sep 11, 2009 | HP 285527-001 - Compaq Presario...
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
