Question about Raymarine C70 GPS Receiver
My C70 shows "no data
5 Suggested Answers
dj_relly999
  • 4070 Answers
SOURCE: My depth finder on my E-120 works for a minute or
Hi! You will need to reset the unit to work normally. Try this, remove the battery and press/turn the power button for 10secs. while the battery is removed. Put in the battery and turn the unit on and see how it goes. This should reset the system and resolve the problem. Hope this helps and have a good one!
Posted on Jun 12, 2010
  • 16 Answers
SOURCE: fish finder
You have either the DSM250 or DSM300 digital depth sounder module installed. The C80 is not seeing it.
There is an LED status light on the DSM. For starters, it should be lit either red, yellow or green to confirm it is actually powered on. We are hoping for a green light.
Double-check the cable between DSM and C80 for tightness. Also double-check the DSM's power cable for tightness.
The DSM's are sensitive to voltage level onboard. Make sure the DSM's connections to the circuit breaker panel or battery are tight and clean. Double check with a multimeter the there is 12V DC available to the DSM.
Let me know what you find.
Posted on Dec 28, 2007
SOURCE: 4150sx finder erratic depth
I had the same problem last time I was out in shallow water (in less than 2 metres of water) and I suspect that the problem was weed wrapped around the transducer but won't know for sure until I take it out on the water again. I had another problem re water temp which I'll enter separately.
Posted on Apr 24, 2009
gopakumarg43
  • 74243 Answers
SOURCE: My Lowrance LMS-332C GPS was
Hello
If the GPS works and sonar section does not work at all, check the followings.
1# Check the power cable's connection at the unit. Also check the wiring
2# Make sure the power cable is wired properly. The red wire connects
to the positive battery terminal, black to negative or ground
3# Check the fuse.
4# Measure the battery voltage at the unit's power connector. It should
be at least 10 volts. If it isn't, the wiring to the unit is defective, the
battery terminals or wiring on the terminals are corroded, or the battery
needs charging.
Check whether there have any wiring break, loose. During servicing the boat, there is chance to get the wiring of sonar to sonar sensor at the botom of the boat may have damaged. Check these. OK.
Posted on Aug 29, 2011
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
My Garmin 400c dual beam transducer keeps freezing up, it will flash "0" depth and then go to a "updating software" screen.
check your battery voltage. Low voltage can cause errors end prevent the sonar from starting up. If charging the battery doesn't work then contact garmin for a replacement.
Nov 30, 2010 | Garmin Fishfinder 400c With Dual Beam...
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
How do i get a reading just for speed and depth on
If you have no chart card for your local area, you definitely need one! As far as getting various data on the screen, as long as it is available on the system, you can display different kinds of data by pressing the "data" button and then following the steps to add data to your readout.
Jul 15, 2009 | Raymarine C70 GPS Receiver
How do you get the fish to show up on the screen on a lowrance X96 depth finder? We just got it and there is no manual with it.
Are you looking for the little fish symbols?
Press MENU, down arrow to SONAR FEATURES and press ENT. Arrow to FISH SYMBOLS and press ENT. Press EXIT twice. Any significant return in the water will now show up as a fish symbol.
Are you looking for the fish arches?
You won't get any arches unless the boat is moving and of course there are fish passing within the transducers signal. The shallower the water, the less area you are covering and less likely to get a fish return.
There is an OK guide to understanding what you see on the sonar screen at the link below. It if pretty technical but parts of it may help you out.
http://primus.lowrance.com/support/resultDisplay.do?gotoLink=5&docType=1000&contextId=351%3A5.47%2C11918.11930%2C22.47&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FSonar&contentId=9de88fa2-0b60-4b44-a470-29ee14767b3e&responseId=135ccbe2cfd4f608%3A1fe88d%3A122773df7e0%3A7c2&groupId=4&answerGroup=1&score=981&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FSonar%2FChart+Tutorial.htm&result=0&excerpt=Chart+Tutorial+Deciphering+Sonar+Charts.&question=chart+tutorial&resultType=5000#Goto5
An X96 owners manual can be downloaded from http://www.lowrance.com/en/Downloads/Manuals/
Jul 11, 2009 | Lowrance X96 200khz Fishfinder
Gps error message "gps module not responding"
Check the connectors and wiring between the GPS module and sonar unit. If it's an internal GPS module yo may have knocked loose a connector internally.
Jun 01, 2009 | Lowrance LCX-17m Sonar with GPS GPS...
Fish finder
Jun 18, 2007 | Raymarine C80 GPS Receiver
Raymarine C70 GPS Receiver Logo
93 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
