Question about GE Heating & Cooling
Just cool air coming through not cold, this is #21c506604, very old a/c. Can this be fixed or are these obselete?
2 Suggested Answers
SOURCE: not cooling rooms, air not
I called the contractor and found out there is a leak outside.
Thanks
Posted on Jul 31, 2008
Old portable ac unit puts out cold air but not enough to cool a bedroom
Some portable ACs will suck in warm air from outside, making it hard to cool the room. The only fix is toget a machine with a balanced pair of ducts.
Sep 26, 2014 | Heating & Cooling
Hello ... i got a one year old AC haier esa3105 and i got a problem; the air is not cold its kinda cool but nothing compering to when it was new. i set it up to go down to 61F lowest temperature on the...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 14, 2011 | Heating & Cooling
I have a Artic Air White Reach In Freezer. It is not blowing cold air from he top where the cold air comes in. Freezer was at 60 degrees F. I turned the defrost switch to make sure it wasn't in...
Is the freezer itself getting cold.To blow cold air.the freezer should get cold/friezed.the cold air blows from freezer to fridge side.first the freezer side gets cold, then when the freezer side gets enough cool to its set cooling temperature, at that time the defrost cycle starts.In defrost cycle the fan in the freezer starts running and the cool air from freezer starts going to fridge side.There is a ventilation passage between fridge and freezer from where this cool air passes.---------------- If in your case, the freezer is getting proper cold, but its not blowing cold air from freezer to fridge, then possibility is that, there is a blockage in ventilations.But if ventilation its clear, then its defrost problem.First try manual defrost reset procedure. The procedure is as follows: ---- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. Then its defrost board problem. ------------------------- BUT if in your case, the freezer section itself is not getting cold, then the problem is compressor related.The compressor is the part which cools the freezer frost.In the compressor, there is a refrigerant to cool the freezer.If the compressor gets weak or the refrigerant gets low, then it will not cool the freezer, if the freezer is not cool then it will blow warm air from freezer to fridge, in defrost cycle.In that case, the compressor is faulty and its the cause of problem.------------ So you will have to first check , that is your freezer getting cold or not.as per that you can start the troubleshooting.------------------
You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 01, 2011 | Arctic Air Freezers
Refrigerator not getting cold enough
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Not cooling
it sounds to me like u have a gas leak.you shouldent run the a/c until it gets fixed reason being that the cold suction gas is used to cool the compressor windings.if u continue to to run it you may end up in more expenses:-)
Jul 07, 2010 | Quasar HQ2082UH Air Conditioner
Engine temp guage shows cold
Let the truck run for about 15 minutes. If the engine temperature does not come up turn the heater on and check to see if the air coming out is hot or cool. If it is hot the engine's thermostat is operating fine and most likely the problem is with the temperature sending unit for the gauge. If the air is cool the thermostat is stuck open. Try replacing the thermostat if the air is cool.
Jun 05, 2010 | 1996 Isuzu Hombre
No longer cool
If the unit is operating normally but not cooling properly than you are low on refrigerant.
Oct 01, 2008 | Haier HWR06XC5 Wall/Window Air Conditioner
Maytag (Amana) ABC2037DES Refrigerator not cooling
Your condenser coil is frozen up with condensate...need to fix the defrost system, most likely it is the control sub module.
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Heating & Cooling Logo
53 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
