Question about GPS
Battery dos not take a charge nead new battery .but were to buy one
  • 122 Answers
Write the exact type number Search for the type number in google to find compatbletypes most likely nokia types Order through website Idea: dealextreme they have free shipping Cheers Rene
Posted on May 29, 2011
Battery/charger
Charger go true a lot of power voltage regulators and in the end is not powerful inought to power loptop without battery, same capasity neaded to help maintain stable curent.
Feb 17, 2014 | HP Compaq Presario F500 F700 and G6000...
Laptop runs on battery and charges ok,but wont run just on the charger-hp f700
Mobile not swithching on
conect the charger & try it if it goes on you need to charge the battery if dos not keep a chage you need a new battery
Apr 26, 2013 | Cars & Trucks
I got a new alltornator and battery and the alltornator still will not charge my battary what should do
with a new battery and alternator there is little left as to why the battery is not charging. assuming you have connected uo the wires to the alternator correctly, having cleaned the battery terminals back to shiny metal and fitted the correct drive belt (most important) With the belt correctly tensioned the top of the belt should be level with the top of the edges of the pulleys. If it it is not then the belt will not drive the alternator fast enough to charge the battery
Jan 05, 2013 | 2005 Dodge Magnum
It won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Nov 01, 2012 | Casio Cell Phones
My laptop won't turn on even though it's plugged into the recharg
Try removing the battery and running the laptop just on the p/s. If it works like this the battery is dead. Otherwise the laptop has a problem.
If the battery is dead, buy a new battery or run it on p/s alone.
Laptops should be run on battery alone as much as possible, or the battery dies.
Apr 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
My ice maker is pooring out water. How do you stop the water from pooring out?
unplug frig,if water still come's in than you have a bad inlet valve and nead to turn water off.if water doe's not come in than you nead to unplug ice maker and plug frig back in.if no water come's in than you have a bad ice maker.in most case's you are better off buying a new ice maker.
Nov 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
To whom it may concern; i perchessed a apm62 modal #800-0219-001 ser. #r0711107791 on september 1/08 from best buy. for the past 2 weeks. i have bin haveing problems with this unit. when laptop is...
You have posted this to a public forum that has 7 million visitors a year. As such, as a moderator here I have removed your personal details.
It sounds like you have purchased a Targus charger that takes the 12 volts in your truck, to charge your laptop? It sounds faulty and the connectors are bad. You could try connecting it direct to the battery, however that unit you have is only warrantied for 2 years from purchase. You had the old one 8 years. Also as a BIG CLUE, the unit is discontinued. Contact customer service using the link below and tell them your troubles. You have a HELL of a lot of spelling errors!
Warranty
Mar 15, 2017 | Computers & Internet
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
