Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
I have a 7950 Bissell. I can't get it to **** up from either the tools or floor area. I tried adjusting the knob on side but still no luck. Any suggesions?
  • 276 Answers
First check to see if there is suction at the motor duct. If not contact you local BISSELL Authorized Service Center at http://www.bissell.com/customer-support/.
If there is suction,
a) Check if the small rounded window tabs on the Floor Nozzle are locked in
their mating slots and not inadvertently lifting the tank up out of place?
b) Check to ensure oval seal is in place at the top of floor nozzle window.
c) Check the diverter knob for proper setting and the diverter door opens and
closes properly. If no, and it does not appear to be broken, remove the floor nozzle window, open diverter door manually, keeping the flat
side of the door against the unit. Set the diverter knob on the tools setting.
Manually close diverter door until there is resistance, hold it in place while
turning the diverter knob towards the floor setting to lock it back in place.
Reinstall the floor nozzle window. (If diverter door will not lock back in place,
go to a BISSELL Authorized Service Center).
d) Check for the black foam gasket under the diverter door. Replace if
necessary.
e) Check floor nozzle window to ensure it is screwed down properly. If there is
a ¼" gap between the window, where it wraps around to the side of the
unit, and the base on the slanted section, reinstall window.
This gap can be eliminated by installing the tabs at the top of the window,
hold it in place, then push up from the bottom of the window to bow the
window, push it against the unit and then evenly slide it down into place.
f) Check half moon window to ensure it is screwed down properly on
CleanView models. The floor nozzle window should be lower to the floor
then the half moon window.
g) Make sure tank is not full on the outside of the bladder.
h) Check the tank lint screen for debris. Remove it to check.
i) Check tank lid and tank for damage.
j) Check float and baffle to ensure they are properly installed properly. The
baffle should be even with the top of the tank
Posted on Jun 01, 2011
Bissell model # 7901r
What is your question?
Feb 21, 2017 | Bissell Vacuums
Bissell 3576 height adjustor broken
Hi Chris! Lock the vacuum in the upright position, set the height adjustment to the desired setting, then recline the handle for the change to be made.
If you continue having difficulty, you may want to have one of our Authorized Service Centers inspect your vacuum.
Here's a quick link to help you locate one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
May 19, 2013 | Bissell 3576 CleanView II Bagless Upright...
How do we fix a broken upright stop? the upright stop will not stay up. something is not right.
Hi Jeremy! You may want to have one of our techs at a BISSELL Authorized Service Center inspect your machine.
Here's a quick link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 23, 2013 | Bissell 7950 ProHeat Upright Wet/Dry...
Control knob for bissell carpet machine came off to change from floor to tools
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
yul
Mar 28, 2010 | Bissell 8910 ProHeat Clear View Upright...
I HAVE A BISSELL PROHEAT CARPET CLEANER AND WAS WONDERING IF THERE IS AN ATTACHMENT TO CLEAN TILE FLOORS. THANK YOU BONNIE UPDYKE
you should check the website of the manufacturer, be carefull as the grout between the tiles is the weakest link to keeping your floors solid...you may damage or fade the color of u'r grout if it is not protected...and if it is protected and has been sealed with a protectant, then you may be removing the sealant with the extreme hot steam from the carpet cleaner.
Feb 22, 2010 | Bissell 7950 ProHeat Upright Wet/Dry...
How do you use the tools?
unwrap the main hose and fit the tool you want to use then turn the control knob on the side of the unit select tools
Oct 26, 2009 | Bissell 7950 ProHeat Upright Wet/Dry...
Bissell 7950
appears that you may have all the belts in place but the beater brush is jammed and it can't spin.. the jam may also be blocking the vacuum port so that you don't get any suction to that area. I suggest you unplug the vac, then open the base section to gain access to the beater bar and check to make sure the brush can spin freely.. also check that the drive belt is properly seated on the shaft and that there are no obstructions in the vacuum port.. hope this helps you..
Sep 21, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Flap
Most likely the diverter valve is broken part #2136988. You will have to remove the top to replace it.
Aug 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Broken Smart Mix Dial-How to replace
You will have to remove the top, the knob screws on but has a stop tab. Is the plastic below the knob ok, if not then you need to replace the top cover. After you replace the knob, then put the piston on from underneath, have it set to water only selection, then put the top cover back on.
Mar 04, 2008 | Bissell 7950 ProHeat Upright Wet/Dry...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
108 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
