Question about NeoWave PC Audio Graphic Equalizer External Sound System
Hi, I have a problem with my neo laptop. There is no sound from the internal speakers. I have uninstalled and reinstalled the audio driver and checked that it is up to date. There is only a brief muffled sound from the speakers when I click and unclick mute. Like the sound you get when you turn an amplifier on or off so I think they are working or atleast able to work but they need some kind of settings adjusted. My wifes sister has used the laptop and adjusted some things not knowing what she is doing and now it is not working. System restore does not go back far enough because my wifes sister has been using the laptop for a while.It is using realtek HD audio and running windows vista. Please can you help. I have tried everything I can think of. thanks, William.
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Posted on May 29, 2011
My internal speakers are not working pls.
Please check out a few things with your laptop 1. Play some music files and see what the software tell, if it normally plays music but you cannot hear it from the internal speaker then plug in a head phone or speaker and play some music if you are not able to hear in the headphone/speaker, then the problem is with the internal speaker, (Take it to the laptop service center for repairing the internal speakers).
2. Mostly sound problem occurs due to driver software problem it may be some times corrupted, uninstalled accidently but in such cases while trying to play a music file an error will appearing stating about the problem of sound driver, but first you can try uninstalling the audio driver and reinstall it.
3. To Uninstall insert the Driver cd that came with your laptop and Click on the audio driver icon or setup program, which will prompt you to install the audio driver> on second instance it will prompt you to uninstall or repair the driver> Click on Uninstall and after being uninstalled restart the computer and install the driver. In many instances it solves the problem.
Hope this helps.
May 09, 2011 | Computers & Internet
NO SOUND THROUGH MY LAPTOP
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Nov 14, 2010 | ASUS I-A16C Sound Card
Hello, hope you can help me please. The sound on my acer is really crackly, how can I get rid......many thanks Pat
Hi! As a first course of action please reinstall your sound card driver. It may just be a program error and reinstallation can be a big help. Thank you for using FixYa!
Aug 18, 2010 | Acer Audio Players & Recorders
Distored sound
distorted sound from external speakers or internal speakers?
isolate please. remove external speakers if you have one. just troubleshoot on the internal speakers alone.
uninstall the audio drivers. install the latest one. if fails. download then flashed the latest bios.
run diagnostics extended test to check the internal speakers. if also fails then replace the internal speakers.
Dec 05, 2009 | Computers & Internet
Audio Problem
when was the last time when your audio was working fine? try to do a system restore first, if not fix then download the latest audio driver. uninstall then reinstall the audio driver. try connecting an ext speakers if you will audio if yes then check audio settings from the control panel. if not then update the bios if not then replace motherboard.
Oct 15, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron E1505 absolutely no sound anymore
1. remove all external peripherals.
2. use the internal speakers
3. uninstall / reinstall the audio drivers
4. reboot system
5. if still hearing the crackling sound check if cracking sound can be heard only inside windows of even in the bios.
6. check bios hdd if in acoustic mode performance if yes then set it to normal.
Oct 08, 2009 | Dell Inspiron E1505 Notebook
Not clear sound quality making some noise when i play a song
you need to uninstall and reinstall the audio driver or try to uninstall adn reinstall the player that you are using to hear sounds? is it doing the same if you are going to use a headphone? if so thats only a software problem, if headphone sounds fine, its the internal speakers thats having problem.
Sep 12, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Muted sound from left speaker, no sound from right speaker
try uninstall/reinstalling audio driver. if it fails contact Dell tech support possibility that the internal speaker is already loose/broken.
May 25, 2009 | Dell Inspiron E1505 Notebook
External speakers for toshiba laptop problem
Check device manager and make sure the audio drivers are not disabled. If so enabled it. I am quite sure you have checked to see if its muted. If it is enabled and its not working, try updating the drivers or uninstalling and reinstalling latest driver audio driver OEM site.
**If you reinstall the same driver you might get the same error but its what a shot.**
May 22, 2009 | Toshiba Satellite A75-S211 Notebook
MY HP SPEAKERS WILL NOT WORK AND NEITHER WILL THE HEADPHONES
The simple and the only solution to this is reinstalling the sound card drivers.
Go to device manager > under sound video and game controllers
Right click on the IDT high def audio codec and uninstall it.
Also uninstall the connexant or th realtec audio driver
remember don't install the IDT codec back.. just reinstall the sound driver from the recovery manager > advance options > hardware driver installation.
Regards,
Anup
Apr 05, 2009 | HP Computers & Internet
NeoWave PC Audio Graphic Equalizer External Sound System Logo
171 people viewed this question
Top NeoWave Computers & Internet Experts
David Payne
David Payne
Are you a NeoWave Computer and Internet Expert? Answer questions, earn points and help others
