Question about Bosch Dishwashers
My dishwasher model SMU50M22SK/14 has stopped with errorcode E01 what can i do. The machine is one year old
3 Suggested Answers
  • 161 Answers
SOURCE: Maytag Dishwasher Model DWU9200BAB
Do you have an air gap between the disposal and the dishwasher? If not required raise the hose and as high as you can. It must be above the water level in the sink. Try attaching it to the underside of the counter. At some point the hose should be above 32 inches. It the problem is with the dishwasher itself. Don't fix, replace. They are not really designed to last over 10 years. The new ones , especially in the last year or two are a BIG improvement over any older one. So quiet you can't tell they are even running, they clean so much better and are much more energy efficient. Stainless steel interiors are just a fad. The plastic tubs are actually less likely to leak and are by there nature more quiet.
Posted on Jul 03, 2008
BElectric
  • 1140 Answers
SOURCE: I have a 8 year
I have covered this in several previous solutions for Bosch dishwashers. I have copied the text below from a previous request for help, rather that write the entire thing again.
If this doesn't help, please post back and I'll try to assist you further.
"It sounds like the flood protection system has been activated. This is most likely due to water in the bottom of the dishwasher (under the washing compartment) or it could be due to a faulty float or float switch.
The first thing to do is check the float inside the dishwasher. It's the dome/mushroom shape plastic part in the bottom of the wash compartment. Have a feel around under the dome and check there isn't anything trapped underneath it (maybe cutlery or a build up of waste). If something is stuck in there, simply removing it should be enough to get you running again.
If it's clean underneath try pushing the dome down gently in case it's just stuck in the up position. If it pushes down, lift it up and down a few more times, clean underneath it and make sure it drops down on it's own when you lift it and let go. If it falls freely, you're good to go.
If there's nothing under the float and it moves up and down freely, next check for water in the bottom of the washer. To do this, tilt the washer forwards then backwards to about 20 degrees. Obviously, if it's under-counter you'll need to pull it right out before doing this. If you see a pool of water on the floor then you have water leaking into the bottom of the washer!
There are several possible causes of this - some are simple and easy to correct - but you should do these checks first, then post back here for further assistance."
Please rate my solution if you find this helpful. Thanks
Posted on Oct 17, 2010
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
How can i fix error 0001
Xbox-experts.com - Error code 3 RLOD E01 / 0001
https://xbox-experts.com/errorcode/E01/0001/
General info on Error code : 3 Red Lights E01 0001 and how to fix it!. Short circuit in the console/faulty PSU. E-Code / Secondary Error code‎: ‎E01 (No ...
Binary/Hex‎: ‎00000001 / 0x01 -> 1
Primary Error code‎: ‎3 RLOD
Sep 24, 2015 | Office Equipment & Supplies
Started with E01 and E25
The E01 fault code means that the dishwasher has suffered a power module failure.
The programming of replacement power modules E01 up until E05 has been locked down by Bosch so in the event of an error code of this type it's recommended that you contact a Bosch approved dishwasher engineer.
Apr 12, 2015 | Bosch Dishwashers
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Our Model DCC-2200 started boiling and then smoking from the plate.The unit is approximately 2 years old.
The thermostat that controls plate temperature has stuck closed. Stop running the machine until this problem is repaired. A thermal safety fuse should have blown (stopping any further heating).
Feb 02, 2010 | Cuisinart DCC-2200 14-Cup Coffee Maker
Door hinge spring broken
Yes, it can be fixed. Sounds lilke just a matter of either fixing or replacing hinges/springs.
May 10, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
My 14 yr old Magic Chef Model DU4K seems to be leaking (it is dripping into the basement just under where the dishwasher is located). it started when the arm at the bottom of the dishwasher did not seem to...
Being 14 years old I dought if spares are still available for this machine personally at 14 I would rather replace the unit if you are not in a possition to replace it you could advise from your local appliance repairs as to weather parts are available and what the cost is of parts for the unit before you decide to possible throw good money after bad (spend money on something that has very possibly seen the end of its life)sorry for the bleek outlook but reality is that old machines such as this seldom are worth repairing.
Jan 23, 2009 | Dishwashers
Soap dispencer won' t dispence soap
My Bosch intergreted dishwasher is only 3 years old. For the past year, the dishwasher dispenser refuses to open on the second cycle. We have had the repair man here 3 times, and each time he says it's fixed,but it clearly is not. Does anyone know what to do about this??
Barbara Berger
Sep 30, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Feb 16, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
48 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
