Question about Pure Flip Ultra 4GB Camcorders Pink U1120P
My pink flip ultra camera U1120P wont turn on. The screen comes on when its plugged in, but it doesn't work (even with really strong Duracell batteries) when not plugged in. I have fully charged it and it doesn't work still. There is also no reset button in the tripod mount like other forums and people have said. Can you please tell me how to get it working again, or where the reset button is? Thanks, Jess
Turns on for a second and turns off
could be batteries are not strong enough the best batteries for a camera are duracell
May 25, 2012 | Kodak EasyShare M1093 IS Digital Camera
My flipshare video has frozen-will not even turn off
Try holding the power button in for 10 seconds,this will reset the Flip usually.
If that doesn't work there is a pinhole in the bottom of the camera where the
tripod screws into,take a pushpin or something that small and push in for 5 seconds.
Then press the power button and it should reset.
It may be freezing because it needs the firmware updated,plug in your Flip camera to your computer and the Flipshare software will come up and check for new updates to the firmware.
Jul 14, 2011 | Cameras
I just bought my 11 year old an ultra hd 2 hr flip video, we cannot even get it to power on, any suggestions?
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time.  Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge.
A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port.  Screen should light up temporarily and Red light showing charging on front of camcorder.
IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again.  maybe connection not good.  OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that.
If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too.    IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at   http://www.theflip.com/en-us/
Feb 13, 2011 | Pure Digital Flip Video Ultra Camcorder
Plugged it into my computer, now wont even turn on!
HI,
TURN IT ON WHILE ITS CHARGING WITH COMPUTER,SOME TIME THERE WILL BE STROKING ON PROLEM..
TNKS
RABBANEES
Nov 04, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Video Mino keeps freezing up, can't shut down or upload
At least the following works on my first generation Flip Ultra camcorder (not Mino). Remove battery, put it back next morning. After that be careful not to touch "on" slider switch on the side of the camcorder while Flip logo is still on the screen. I mean turn the device on by using the slider switch and do not touch that switch again until Flip logo on the screen is gone. Doing the opposite (trying to use the "on" switch again while device is still "booting" and Flip logo is on the screen) will lead to the Flip Ultra freeze.
Jul 27, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra - freezes at initial Flip screen - will not shut off
I found a fix that worked for mine.
It was doing the same thing, freezing at the "Flip" screen and would not turn off. I did the remove the batteries deal. It worked once but issue reoccured 2 months later and the battery fix didn't fix it.
What did fix it was...
With the camera off, hold down the Right Arrow button and the trash can button at the same time and turn the camera on.
A few seconds later, I was at the start recording screen!!
Good Luck!
Jul 21, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Video Won't Turn On
For the Flip Ultra - Take out batteries you should see a flat somewhat square piece of metal with a small black piece sticking up from it. Take a pencil and push the black piece down wait a few minutes then try turning your flip back on.
Feb 06, 2009 | Pure Digital Flip Video Ultra Camcorder
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Lcd won't work when it is flipped and facing out in the back.
The flex strip is cut and thats why you are facing that problem ... please use it the way it works till you can ,,,,, when it completely goes dead have it replaced by a repairman ....
Oct 14, 2008 | Canon PowerShot A630 Digital Camera
Pure Flip Ultra 4GB Camcorders  Pink  U1120P Logo
32 people viewed this question
Top Pure Video Cameras Experts
Are you a Pure Video Camera Expert? Answer questions, earn points and help others
