Question about Garmin nuvi 1490T GPS Receiver
Pluged in the car, after 5-6 minute the unit turned off and it was not possible to turn it on again
  • Garmin Master
  • 3,053 Answers
Hello jose,
Maybe this will help you some. I have found you the complete manual which covers most of the models of the Garmin Nuvi. It is the full manual from start to finish with complete operating procedures as well as schematics, operation instructions complete with pictures, and trouble shooting section and even other contact numbers to deal direct with Garmin, if your model is not covered in this manual.
Here is the link for you:
http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Also if you can, please rate my solution if you can and some kind words would be appreciated. I also took the liberty to put my link at the bottom of this page that directs you to my personal page for all my areas of expertize, such as Automotive, Appliance, Electronics. Feel free to check it out anytime and save my link for future problem. Thanks So, Much Mike.
http://beta.fixya.com/users/mc1bean
Posted on Oct 25, 2011
Sub zero FREEZER temperature display is all of a sudden -22 in lieu of the usual -5. is it possible that somehow it has switched to celsius? if so, how do I change it back to farenheit? Model 601F/F
These instruction are from the site below:
To convert the temperatures from Fahrenheit (°F) to Celsius (°C) readings:
  • Turn the unit off then back on again using the unit on/off button.
  • Within one minute of turning the unit back on, press and hold the door ajar alarm bell ON/OFF key and the UNIT ON/OFF key simultaneously for 5 seconds.
  • Release the keys and "°C" will appear on the LCD indicating that temperatures will now be displayed in Celsius units of measure.
  • To convert back to Fahrenheit units of measure, repeat the steps above. "°F" displayed will confirm Fahrenheit units of measure.
  • Refer to the product use and care guide for further information.
  • Note:
    • Temperature Units Selection must be performed within the first minute after switching the unit ON.
    • Model 427R will require temperature conversion for both the upper wine storage zone and the refrigerator drawers separately.
Without a bell on / off button on the control panel, it is not possible to change the temperature display.
400 600 700 Series Temperature Conversion
Jan 29, 2015 | Refrigerators
I have an AMCOR ALTL1200E, fan works, cold air comes out when the compressor turns on BUT after 5 minutes compresor turns OFF, then after 5 minutes again it turns on, what is wrong, thanks
Sounds like the unit is cycling off on a high head pressure (condenser coil too hot). When the condenser cools, the automatic switch resets. The unit cuts off again when the condenser heats up again. Clean the condenser coil, and clear out any debris (bird's nest, lint etc.)
Aug 30, 2013 | Amcor ALTL-12000E Portable Air Conditioner
The GE Profile Dishwasher will not allow me to start without the heated drying light coming on. I want to wash without this headed drying at the end of the wash. When I try to turn it off it turns the...
Try pressing the "Start/Reset" pad hold it for 5 seconds to reset the dishwasher and wait 2 minutes. If the problem persists, reset (reboot) the dishwasher by turning off power to the unit at the house circuit breaker/fuse box for 30 seconds. Or if its pluged in below the sink like mine unplug and plug back in. Restore power and the dishwasher should function normally.
Aug 02, 2017 | GE 24 in. Profile PDW9800J Built-in...
Possible short . reciever turns off after 5 minutes or so ..
Still sounds like a thermal issue. Does the unit FEEL hot just before it dies? Make sure it gets a lot of clearance for ventilation and don't run too much auxilliary equipment from its rear power outlets.
May 24, 2010 | Kenwood VR-407 Receiver
Tomtom xl wont turn on an overheat
It is a design flaw. I had the exact thing happen and TomTom advised "not to let it get warm" inside the car. I'm sorry, this is supposed to be affixed to the windshield and it gets hot. When the sun hits, it stops charging. Hold it in front of the AC vent for a few minutes, it cools down and it charges again. But it shuts off in the heat because it will not charge!
Apr 26, 2009 | Tomtom ONE XLS Car GPS Receiver
Camera off!!!
Hi there. Try this:
Remove the batteries and any card you may be using. Leave them out for 5 minutes and replace them and the card, then turn the camera on. This should work.
Rob
Mar 03, 2009 | Canon Cameras
When turned on, lights come on, but will not blow...
First off, I dont think you caused this problem by vacuuming the unit. It is possible that you did not leave much time before restarts but you then said you tried leaving it off for 5 minutes which should be adequate enough. f you let the unit set for a couple of hours before a restart that should be enough time for the compressor to cool down to ambient temp. I would then try restarting the unit, if it works leave it on for a while and make sure it is producing enough cooling. If there is no change in the situation I would suggest that it would need to come back out of the housing and check that the compressor is receiving voltage to it. It is possible a start capacitor or relay is the cause of the problem. If it started first time I would suggest it is worth having it checked by a professional as it could be the charge or the starting devices. First off though let it completely cool down and try again. Hope this is of some help.
Sep 14, 2007 | Heating & Cooling
After turning the unit on, it clicks to start, but then clicks right back off...
once you switch the unit off mid cycle, it needs time to equalise before it will switch on again.  otherwise check the cap.to start the compressor.
Sep 13, 2007 | Whirlpool ACQ122XK Air Conditioner
Garmin nuvi 1490T GPS Receiver Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
