Question about Homelite Mighty Lite Lawn Trimmer
Spool retainer stuck; how to get spool retainer off?
Where can I get a spool retainer for my ryobi 24 volt string trimmer
Fixya is unable to suggest Ryobi spool retainer sources.
Apr 12, 2018 | Ryobi Garden
How to remove outer spool on lower shaft on my troybilt trimmerTB21 EC
There is a retainer on shaft at top of spool you will need to remove and you may have to bend a screwdriver to get it at angle to remove, try and do not destroy. After you remove retainer spool should slip off.
Aug 25, 2017 | Garden
How to remove spool on craftman 25cc gas trimmer
Unscrew the bump knob. Pull out the line spool. Remove the retaining push washer from the drive shaft. The spool housing will now pull off the shaft.
Sep 26, 2014 | Garden
Replace trimmer line
The steps for replacing line in a single line trimmer head are virtually the same for many trimmer head types, like double line trimmer heads.
1. Remove the Trimmer Head Spool
Removing the spool is the first step in replacing trimmer line in any conventional trimmer head, but trimmer head spools can disassemble in different ways.
The trimmer head pictured above and below disassembles by simply unscrewing the knob around its arbor bolt. Other trimmer heads can use press tab and other twisting styles for disassembly.
2. Insert Trimmer Line and Wind the Line
Single line trimmer heads have just one channel in their spools for winding line. The channel will have a hole in it somewhere that keeps the line in place as it is wound around the spool. Insert one end of the trimmer line in the hole.
Depending on the trimmer head, it might be helpful to bend a small portion of the cutting line at an angle before inserting it in the starter hole. Also, cutting the line at an angle can help this first step on some trimmer heads.
Of course, it is also important to make sure that the replacement line matches the diameter specification of the trimmer head before beginning. Once the line is started correctly in the channel hole, you're ready to wind. Most trimmer heads will indicated the correct winding direction right on the spool somewhere.
It's also important to wind the line carefully, keeping it in neat rows as much as possible. The line will have a much higher chance to feed incorrectly during trimmer use if it suffers from sloppy winding.
3. Snap the Line into its Retaining Notch
A conventional trimmer head will have a retainer on its spool. Snap the end of the trimmer line into the retainer after it is wound around the spool. The retainer will hold the line in place as the spool is replaced in the trimmer head assembly.
4. Replace the Trimmer Head Spool
With the cutting line held in place, the spool is ready to be replaced in the trimmer head assembly.
First feed the extra trimmer line through the trimmer head eyelet. Make sure to release the line from the retainer before completely securing the spool into position.
Replace any knobs, bolts, or other trimmer head pieces removed during disassembly.
Your single line trimmer line is now reloaded, and your trimmer should be ready to get back to work.
Although there are many steps to reloading line the conventional way, a little practice and familiarity with your trimmer will speed the process up a great deal. Once you're up to speed, reloading trimmer line this way can take less than five minutes.
If you want to know about the double line replacement, please click this
Thanks.
Apr 01, 2012 | Garden
How do i remove string holder to refill on a homelite electric 13 inch trimmer
You push in the tabs on the side of the spool retainer. Then, you pull the spool retainer up to remove. Then, you can remove the spool. See page 13 of your owners manual here with more instructions and diagrams also.
http://www.homelite.com/system/manuals/stringtrimmers/UT41110_221_eng.pdf
Jul 04, 2011 | Garden
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
Trimmer head line loading instruction
Jun 29, 2011 | Husqvarna 28cc Gas Line Trimmer
The ink cartridge will not eject. It's stuck inside the printer.
Canon Selphy CP800. I had a cartridge ribbon break when it stuck to some photo paper I was trying to reuse and the cartridge became stuck and would not release. All you have to do is try to print a dummy print, the printer will then display that the ink cartridge needs replacing, it will then allow the cartridge to pop out when the release catch is operated. Beware of broken and torn ribbon inside the printer and try to remove the obvious loose pieces before inserting the new cartridge. Any remaining bits of ribbon should stick to the next photo you try to print but a ruined photo is a small price to pay as your printer should work ok once the debris is cleared. If you are adventurous you can dismantle the cartridge by inserting a small flat screwdriver into the retaining clips at each end of the cartridge cover. remove the used ribbon from the spool as it is only stuck onto the spool spindle. Re thread the unused ribbon onto the spool ensuring it travels round the deflecting spindle which is easily prised out and replaced over the ribbon. You must ensure that the new ribbon is wound onto the spool in the correct direction (check this by comparing the rotation with good cartridge by ensuring the ribbon tightens as it should) then wind the ribbon forward until the black line appears on the clear sheet of ribbon and carry on printing.
Dec 19, 2010 | Canon Selphy CP510 Thermal Photo Printer
Ryobi CS30 Spool Retainer wont come off!
No trick - sounds like it is stuck!
Can you take it back?
If no - well - keep trying :(
Are you taking if off to put on other head attachment?
Jul 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite Mighty Lite Lawn Trimmer  Logo
301 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
