Question about Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop
When I start my old gateway profile 4 I get only black screen but it does try to read on boot up and I can hear the windows opening sound but nothing else
    Problem Solver:
  • 5 Answers
Open the back of it up and check for leaking capacitors if you find some leaking black stuff replace them "Capacitors (888).235.4692
Posted on Apr 17, 2012
5 Suggested Answers
  • 49 Answers
SOURCE: I have a gateway profile 4 I played a cd and there is no sound.
If you have reinstalled your operating system, you will have to install the drivers for your computer.
Posted on Jun 29, 2009
Siouxie
  • 100 Answers
SOURCE: When turn on the gateway screen apear, but the
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Posted on Nov 08, 2009
  • 92 Answers
SOURCE: CD drive not reading on gateway profile 4 all-in-one
If you are using "Roxio Easy CD Creator" then this software must be updated. http://www.roxio.com/enu/support/default.html
Posted on Feb 03, 2010
  • 16 Answers
SOURCE: GATEWAY PROFILE 4 P/N 3501443 has video problems
format/repair ur system using Booable cd and then check
Posted on Apr 13, 2010
Boot screen
Try these two things:
1. Go to your BIOS setting by pressing F10 immediately after you switch on your notebook, then select your HDD as your First boot drive and then save changes and exit. If it does not works then follow step 2.
2. Reinstall/freshinstall your Windows OS with a windows OS disc.
Jan 17, 2014 | Gateway NV4402u Notebook
My Gateway Profile 5.5 is running Windows XP and it boots up, and gets past the windows XP display and then goes to a black screen. The mouse arrow is still visible when the black screen pops up, but it...
Try the fix I've described in this link:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
if that doesn't work, try this next one:
http://www.fixya.com/support/r4501848-when_windows_xp_start_secondary_fix
You can also try to start the computer in safe mode and do a system restore back to when you know it was working. (Just a hint--try this first!!!!)
Aug 02, 2011 | Gateway Profile 5.5 PC Desktop
Gateway MD2614u, froze at start up when restart was attempted nothing appeared but a black screen. It will not restart. I have tried the battery/power reset, vacuum any dust and hooked up to another...
Actually this is a hard drive fault most likely, or a faulty had drive. If you don't have a recovery disk you are going to have to start the machine and try to do a recovery to boot repair. You can usually access this with F10 or F12, not really sure on a gateway.
Dec 29, 2010 | Gateway MD2614u Notebook
Press f11 to start recovery doesn't work
do you have a recovery cd or a copy of windows xp, try pressing f12 to get to a boot menu or f8, to get to a safe boot option or a last previes known good option, or some thing like this. press these options on off on off just before it goes to load the windows. try that hope it helps
Nov 30, 2009 | Cameras
When my Gateway 300S is powering up, it recycles.
If you repeatedly hit F8 key when the computer starts to boot it will open the boot menu screen. There should be an option to "halt computer on all errors". This should bring up the blue screen of death. It should give you something like
STOP: 0X0000007E, the a whole bunch of other numbers. after that it may display a file name. You can search the internet for STOP: 0X0000007E and the file named mentioned. You may be able to find a solution by doing this. It is usually caused by a bad driver or executing a bad command on Windows start up. You can boot the computer in safe mode from the boot menu and maybe repair the problem but it's a tough one to find. I'm trying to repair a similar Gateway computer. It doesn't list a file name and I'm pretty sure that it's a video driver or the onboard video card. The problem is Gateway is no longer in business and it's hard to find updated drivers I"m going to try to backup all the files on the drive and re-install windows and try to repair the drivers with more updated ones. The gateways are hard because they don't have slots in the motherboard to install anything but an old PCI video card. It may be time to think about a new computer soon.
Nov 14, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
I have a Gateway MX 3228 laptop that does nothing. I can hear a slight sound from the area of the hard drive when I turn it on. The battery is supplying some power as the button light illuminates when the...
If you get no display at all, it could be failed memory.
Find and open the memory slot, remove and reinstall whatever memory module you find and retry it.
Many systems I've seen will do absolutely nothing if memory is faulty; they do not give any POST beeps, displays or start to read from the hard drive.
The hard drive will spin up when power is applied but will not start their own self-test or look for the boot sector if bad memory is in play.
Good luck-
Oct 24, 2009 | Gateway MX3228 Notebook
Gateway laptop screen is black?
This could have several causes, including malware installed on your system, but is frequently the result of some kind of hardware driver conflict. Have you recently installed any new hardware or software to your system? If so, disconnect it and try again.
The black screen is an indication that the windows os is not booting onto the system. If you have the recovery console installed, or have the cds, you can run the recovery console to troubleshoot or repair your installation of windows. This procedure is different for xp or vista, so we need to know what os you're on, as well as any error messages you see when it fails to boot.
To begin with, try tapping F8 as it boots up and see it you can get into the OS options screen, then choose Last Known good configuration to boot windows.
Here's a great article to help you troubleshoot the situation, then let us know how it goes and what comes up..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 15, 2009 | Gateway 7330GZ Notebook
COMPUTER WILL NOT BOOT
This does not sound like a power supply issuse
Try This:
tap F8 while booting the PC
This should take you to the Advanced Boot option window
Use you up & down keys: Safe mode With Command propmts(Enter)
Operating System (Enter)
Sign in under your user name( or owner)
once at a command prompt (Black Screen)
Tyoe chkdsk /r (Enter)
You will get a message ( This valume is in use would you like to start a chkdsk on reboot (Y) (Enter) Reboot PC
This should start a chkdsk after the chkdsk is complete reboot the PC you should go to you profile (desktop with Icons)
Good Luck
Dr Geek MD
Feb 22, 2009 | Gateway GT5220 PC Desktop
Gateway screen stops at power saving mode
Try This
1 Start tapping F8 while poering on the PC
(Don't stop tapping until you get to the advanced boot option menu
2.With the arrow key(up & down) go to Safe Mode With Command Prompts <Enter> chose Operating System <Enter> Signin as ADMINISTRATER
Note: this should get you to a command prompt window with a blinking curser
3.In the (Black) Command prompt window type chkdsk /r <Enter>
4. you will get a message stating the valume is in use and can not be used would you like to set a chkdsk on reboot <Y> <Enter> and reboot PC
On Reboot the PC will go thru a system check. This will take several minutes.
5. after the chckdsk is complete reboot the PC you should be able to access you profile to signin
Jan 20, 2009 | Dell OptiPlex GX280 PC Desktop
Gateway Profile 4 All In One (MPN PROFILE4SE) PC Desktop Logo
91 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
