How do i stop a Sansui SV2918 tv from auto tuning?
  • 373 Answers
If the channel are constantly changing then you have bad channel switch inside the set. The switch is located just behind the channel up or down (depending on which direction the channel are going). I have fixed them before by taking the back off and squirting with WD40 to loosen them up. However, the best fix it to replace. They are called tact switches and there are many different kinds in different TV's You would have to have the exact replacement. Has to be unsoldered the old and solder in the new. I recommend changing all of them including the Volume + and _ and the others as well. Do a search online for electronic parts and you will find a supplier.
Posted on May 29, 2011
What is the value of cap c415 on sansui tv sv2918
Make sure you use an identical capacitor!
Feb 22, 2017 | Sansui Televison & Video
No heater for tv model no.SV2918
Check the continuity of the CRT heater [pin 1~8]. If it is found open, no need to proceed. If it has continuity, check the AC voltage there when the LOT works. Should have about 6.2VAC. If not, check all the solder terminals and series resisotr. connected to this bus. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Jun 10, 2016 | Sansui Televison & Video
My Sansui SV2918 has vertical collapse and no sound.Please help.
Sansui.. Funai made?? Most Funai sets are identical. Find a diagram for a similar TV. Or.. Google the part# of the output IC. The datasheet should contain application data, including a basic schematic of the vertical cicuit.
May 19, 2014 | Televison & Video
Sansui sv2918 keeps blowing k2996 mosfet. Power led flashes and ta-ta-ta sound is heard
Check the Flyback Transformer
and associated circuits.
If 2SK2996 is blown, it may take out the PWM IC and some components
that goes with it.
Let me know what you find or needs further assistance.
Sep 17, 2012 | SansuiM1315 TV
I have a sansui tv model sv2918,it doesn't play
The TV has some firmware defect. Seek tech support.
Unplug it from AC mains wall socket, and plug it again after 5 minutes. This must make it a hard reset.
May 31, 2012 | Samsung Televison & Video
Tv not switching on Sansui SV2918, replaced faulty PTC and trans D2449 for lopty switching
all the transistors ,& capacitors i.e 47mfd 63v or100mfd 63v must be changed before u on the tv. if 300v is not coming to middle pin of d2449 then 4.7ohm resistor(fusible) may be gone
Mar 24, 2010 | Televison & Video
Powersupply Faulty
Check for short circuit on your Powersupply. If you can isolate it, much better. check the voltage regulator if it supplies power to the system. better still check the regulator itself.
Jul 10, 2009 | Televison & Video
Hi I live in Kempton Park South Africa and my Sansui TV Model SV2918 does not swith on. The product is very good and I would like it to b repaired. Do you have suggested maintenance people that I coul
Hi, I need assistance re tuning my TV for the VCR. I am not able able to get the two solid test lines. My TV is a Sansui SV2790NICAM and the VCR an Orion.
Please help!!
Mike, C.T.
May 25, 2009 | Televison & Video
Sansui tv sv2918
replace vert IC301, C432, ( D431 & R431 should also be blown)
Jun 18, 2008 | SansuiM1315 TV
Televison & Video Logo
74 people viewed this question
Top Televison & Video Experts
Electro Med Services...
