Question about Toshiba Computers & Internet
I was using my Toshiba L455 when I was prompted that updates with my widows 7 were available. After the auto shut down my leds in the front left of laptop light up (charger, batery and power) the fan comes on but the computer will not boot. THERE IS NOT AN ISSUE WITH THE SCREEN AND I CANNOT GET TO THE BIOS TO RESET TO FACTORY. I've tried unpluging the charger, removing the battery and holding down the power button for 30 seconds and then I tried holding it upside down with not battery and charger and held the power button for 60 seconds then put the charge in held the power button for another 30 seconds and put the battery in while holding the power button but my lap top will still not come on. Again this occurred after a windows update and its almost like the computer is sleeping or in hibernate. Please help!
  • Toshiba Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap you might also check the ram make sure its securely seated and the cmos battery
hope this helps
Posted on May 29, 2011
I shut down my toshiba copier 282 in the right way . It gives me the message shutting down in progress but it doesn't shut down automatically as before. It only shuts down with the on/off switch
AD+206
Auto Shut Off Mode timer
setting (Auto Shut Off
Mode/Sleep Mode)
ALL Refer to
content
<0-20>
SYS Timer to turn OFF the
power or to enter the
Sleep Mode automatically
when the equipment
has not been
used
0: 3min. 1: 5min.
2: 10min. 3: 15min.
4: 20min. 5: 25min.
6: 30min. 7: 40min.
8: 50min. 9: 60min.
10: 70min.
11: 80min.
12: 90min.
13: 100min.
14: 110min.
15: 120min.
16: 150min.
17: 180min.
18: 210min.
19: 240min.
20: Not used
check this or update firmwear
Sep 29, 2016 | Toshiba Office Equipment & Supplies
Why does my computer automatically shut itself down on the same day each week.
There are a couple possibilities...first, when you say shut down, do you mean that it restarts, or it actually shuts completely off? Windows update will auto-run weekly and restart the system if necessary. Otherwise, I'd suspect something with your antivirus scanner settings.
Jan 10, 2015 | Computers & Internet
Error f3-f100-0004
Corrupted operating system Reload selecting the "repair" option.
Or restore from back thru Safe Mode if access is possible.
Jan 12, 2013 | Toshiba Satellite L455-S5975 Series Laptop...
Hi my toshiba L455-S5045 won't power on, I've
This clearly shows that you have a defective motherboard and it needs to be replaced. Try contacting Toshiba support for this, hope this computer is still under warranty.
Jun 30, 2011 | Toshiba Computers & Internet
I"m running windows 7 on
Click here to download the Latest Version of Adobe Flash Player from Adobe Official Site. It is a small size plugin about 2.26MB in size, which can easily be download for FREE and installted in seconds.
Hope it helps! Good Luck!
CreativeTECH
Apr 15, 2011 | Computers & Internet
I need audio drivers for toshiba satellite L455-S5045 model
This link to Realtek High Definition Audio drivers should help you. http://tinyurl.com/pcsound
Feb 28, 2011 | Computers & Internet
Please give me a driver toshiba satellite A40. thanks.
You can use Device Manager and/or Windows Update to locate the necessary driver for your system. If you know the manufacture of the hardware in question you can visit their respective website and obtain the driver from there.
Also, feel free to visit this help article found on the Windows Help and How-to website about Tips for fixing common hardware problems.
How to update drivers using Windows Update
1. Click Start, click All programs, then click Windows Update.
2. If prompted press Continue or provide administrator credentials.
3. In the left pane, click Check for updates.
4. To see if updated drivers are available, click View available updates.
5. Windows Update will list any updated drivers that are available under Optional downloads.
6. If any updates are available, click the driver that you want to install, and the click Install.
How to manually update drivers using Device Manager in Windows
1. Click Start, right-click Computer, and select Manage.
3. In the left pane, click Device Manager.
4. In the middle pane you will see a list of categories for installed hardware.
5. Check for any devices that have a yellow warning icon.
6. Right-click that particular device entry, and select Update Driver Software.
7. If you have already downloaded the driver select Browse my computer for driver software.
a. Specify the location of the driver you downloaded and follow the on-screen instructions.
8. If you have not already downloaded the driver you can have Windows search online.
a. Click Search automatically for updated driver software, and follow the onscreen instructions.
Jan 28, 2010 | Toshiba Satellite A60 Notebook
How to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Jan 25, 2009 | Toshiba SD6100 DVD Player
Computers & Internet Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
