Question about Maytag MFI2269VE (218 cu ft) Top Freezer Side by Side Bottom Freezer French Door Refrigerator
I have a maytag mtf2142mewoo the freezer is a solid block of ice all the way thru the coils in between the fridge and freezer may be the defrost timer? If so where is it
  • 531 Answers
SOURCE: defrost timer location on Kenmore model 106.56542400
carry control board part#2149705
Posted on Apr 06, 2009
  • 159 Answers
SOURCE: Sid By Side Freezer Icing and Fridge not Cold
most fridges in s.a the defrosting is done by the thermostat if the fridge does not have a pc board
Posted on Jun 17, 2009
  • 6 Answers
SOURCE: Fridge Freezer ices up
easy....drain hole iced up....when it defrosts it will flood base of freezer....24 hour switched of to defrst it will cure it
Posted on Jul 15, 2009
  • 38 Answers
SOURCE: i have a Maytag MSD2656GE side by side- the
I believe your evaporator fan is not working
Posted on Apr 16, 2010
toolkits
  • 1099 Answers
SOURCE: My Maytag MSD2756GES freezer coil is completely
Defrost problems can cause the fresh food section not to work. You need to find out why it’s not defrosting. There are three things that cause a defrost problem: defrost heater, defrost thermostat and defrost control.
If you have an older refrigerator, it probably has a mechanical defrost control. Find it and turn it clockwise until the refrigerator cuts off. (Note that the defrost control is normally located either in the refrigerator near the cold control or at bottom behind the kick plate). If your refrigerator is newer it will have an electronic defrost control and you won’t be able to turn to defrost so just continue without doing so. Now that it’s in defrost, wait a few minutes. If the defrost heater gets hot, replace defrost control. If it doesn’t get hot, then the problem is either the heater or the thermostat.
At this point, you need to melt the ice. The best way to melt the ice is to use either a hair dryer or by using hot water (this will be faster but will make a mess).
Once the ice is gone, you can check the heater by unplugging wires and using an ohmmeter to check for continuity. If you have continuity, the heater is good and you should replace thermostat. If you don’t replace the heater, at this point you won't be able to check the thermostat but if the heater is good replace it. Defrost parts can be found at AppliancePartsPros.com
If you have a GE refrigerator made after the year 2000, do not replace the defrost thermostat. Trust me the thermostat is not your problem. 99.9% of the time it will be the heater. Sometimes it is the main board or the thermistor.
Also note that
It's possible that the defrost terminator is bad.
If it doesn't have an electronic adaptive defrost control, then the mechanical defrost control is bad.
In the future, avoid ALL appliances that use electronics. They fail very very regularly and are expensive to replace.
Just think if you had a fridge with a TV in it, and the tv went out. Who would you call? A TV repairman or an appliance repairman?
Buy a Whirlpool refrigerator with the least amount of electronics you can get.
Also, there is a door switch that goes to the freezer section. It controls the light and the adaptive defrost. If the switch is bad, that too can cause the problem.
Lastly, do not buy anything made by electrolux corporation (frigidaire is one of them for example).
They have cheap evaporators that leak and can't be fixed, thus causing you to buy a new fridge every year or so.
Hope this helps your problem......
Posted on Jul 28, 2010
I have a problem with my s75438dt,the fridge as stopped working
If defrost heaters in freezer stop operating during defrost cycle, ice builds up around coils and blocks cool air from being blown to refrigerator side. If ice you need to defrost with heat and replace heaters. Remove rear freezer wall and look for solid ice covering coils. Also push freezer door switch closed while keeping door open and determine if fan is working.
Feb 06, 2016 | Refrigerators
Refrigerator will not stay cold and ice is building up in freezer.
your compressor or condensor or capacitor is bad, need a technician
Dec 11, 2015 | Maytag Refrigerators
Side by side refrigerator will not cool on refrigerator side plus a build of ice temp control, model # psb2151grw
It sounds like your freezers' evaporator coils are not defrosting normally.At least once a day ,a refrigerator automatically defrosts the coils in the rear of the freezer compartment.In most cases ,the electric heater that is activated by a timer circuit,comes on and melts any ice buildup .If that heater doesn't come on for several days,the ice builds up into a solid block,and it doesnt allow any air to pass thru to the refrigerator side of you box.
Nov 14, 2012 | Maytag Refrigerators
I have a GE GTS 221C fridge/freezer. The fridge is working fine. All of a sudden, the freezer is not freezing. Just cold, but not enough to keep food frozen. The fan on the freezer is working.
remove the rear cover inside the freezer if it has a lot of frost on it,then the evaporator coil is frozen up and you cant blow cold air over or thru a solid block of ice,defrost it,then check the defrost heating element,defrost thermostat and timer or defrost circuitry for no power or defective components,you can use a hand held hair dryer to defrost it quicker
Jan 08, 2011 | GE Freezers
I got LG fridge freezer my freezer has ice building and the temp is warm WHAT COULD BE THE PROBLEM. kclakhani@hotmail.co.uk
your defrost system isnt working and you cant blow cold air thru a solid block of ice,remove the rear panel inside the freezer and check the evaporator coil for this type of ice buildup,they should only have a light frosty coating on them when the units cooling and not defrosting,then either the heating element below the coil is bad,the defrost thermostat on top of the coil is bad or the defrost system isn't getting power to operate
Nov 14, 2010 | LG Refrigerators
My fridge has a solid block of ice at the back of the fridge. I have removed the ice and it seems that the ice is starting to reappear. The temp of the fridge doesn't seem to be that cold. Please help....
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Maytag MTB2456G Top Freezer Refrigerator
Water is dripping into the bottom of my fridge. I have cleaned and vacumned the coils. How do I access the drain to see if it is frozen?
Remove the ice maker and back panel in freezer.1/4 inch nut driver to remove screws. there are 3 screws for the ice maker 2 on the back wall and 2 on the bottom panel. Use a hair dryer to melt ice block.All water will flow down into drip pan under fridge. May overflow use a turkey baster to remove water from pan. Pour hot water onto drain until the water flows freely into the pan.
Jun 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Maytag wide by side not cooling. just prior to this frost build up on top of freezer. Compressor not running.
Check to see if you have frost on the back panel of your freezer in your fridge. If you do your coil is frozen over and you'll have to defrost your freezer. I just did mine cause mine wasn't cooling properly on my fridge side. My coil was solid ice.
Apr 05, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Maytag MFI2269VE (218 cu ft) Top Freezer Side by Side Bottom Freezer French Door Refrigerator Logo
74 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
