Question about Sharp AF-S80FX Air Conditioner
Hi, I have an 8,000 BTU unit. The unit is about 5 years old. It was running fine, no problems at all. Then whan I went to turn it back on after a few days-nothing. No noise, no air, nothing. It just did not turn back on. Before this happeend it cooled, it reponded to degree changes all was fine. The green light button on the test and retest comes on, but there is not a sound from the unit itself. Its like you would hit a power button that was not plugged in (but it is). This problem occured about 1 month ago , I tried at that time to clean filter etc. and just tried again this weekend. I did clean the filter, keep checking plugs but I have no idea what else to do or if it's completely broken. Thank you so much for any advice. It is very miuch appreciated.
  • Anna Allen May 30, 2011
    I really appreciate all your advice on how i should fix my air conditioner...unfortunately i was unable to get it to work. Perhaps its time for a new one, but thank you again for all your help:) I am really glad for what to do and I will keep trying. And I appreciate how clear your your instrustions were,
    Again thanks, instructions were very clear and I havhem out for future printed future reference.
  • 1,940 Answers
After changing or cleaning your Filter, you need to reset the A/C. Follow the procedures below:
  1. Disconnect the power plug from the power supply.
  2. Clean the air filter.
  3. Hold down the POWER ON/OFF pad of the unit's control panel and plug in the power plug to the power supply. Keep pressing the POWER ON/OFF pad until the unit emits a "BEEP" sound. (for approx. 5 seconds)
  4. Disconnect the power plug from the power supply and plug it in again.
  5. Start your air conditioner's operation.
If the A/C still doesn't start, try this:
  2. Hold down the MODE pad of the unit's control panel and plug in the power plug to the power supply. Keep pressing the MODE pad until the unit emits a "BEEP" sound. (for approx. 3 seconds) The unit will start to operate.
  3. Stop the unit's operation by pressing POWER ON/OFF pad.
  4. Start your air conditioner's operation.
If your problem continues, contact 1-800-BE-SHARP (1-800-237-4277).
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on May 29, 2011
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
I have an older 8000 btu unit - i have no manual. its 98 outside - when i start up this unit , should i have it on hi- med - or lo ? if i run it too hard will i freeze it up?
If everything is clean and the unit is properly charged with freon then it should not freeze up and I would start it anywhere you want to as that just controls the fan speed. It's108 here. Best of luck and thank you.
Jul 22, 2011 | Kenmore 8,000 BTU Single Room Air...
HI HOW DO YOU REMOVE THE GRILLE COVER TO CLEAN THE CONDENSER COILS & FINS WE HAVE TWO OLD MECHANICAL 8,000 BTU HAIER UNITS TRYING TO COOL A L SHAPED ROOM OF ABOUT 850 SQ. FEET WITH TWO CEILING FANS FOR...
These a/c under 10,000 btu usually are brutal to get into
Some come apart in halves others just have lots of screws
Good Luck!
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 06, 2010 | Haier Heating & Cooling
Not blowing cold air anymore
Possibly dirty evaporator coil or condenser coil. Maybe dirty filters. Also could be low on refrigerant charge.
May 17, 2010 | GE AJCQ08ACB Air Conditioner
Runs for 2 min the must reset plug
Need more info. but in the meantime. if it is a brand new a/c why not plugging the unit into another outlet. Do not use any extesion cords cause it may blow the fuse. Also make sure that you are not using an outlet that is connected to a refrigerator. if it is an old a/c or a least 2 years then the condenser (back of the unit) is problably dirty. Run a garden hose behind it for a bout ten minutes while it is running. if it still shuts off you might have a bad compressor.
Mar 21, 2010 | Frigidaire 8,000 BTU MS II Compact Room...
E1 error code on air conditioner
I called haier about this error code. E1 indicates that a button on the control panel or the reomote is stuck. I was instructed to unplug the unit and push each button at least 5 times, one at a time. Plug the unit back in, and this fixed my problem with error E1 and the unit works fine.
Jun 23, 2008 | Haier HWS08XC1 8,000 BTU Window Air...
Jenn-Air JGD8130
i have the same problem.. jgd8130.. can i change out the burners or orfices..etc to make one or two of the burners for more btu's? ro9beam2002@yahoo.com
Mar 09, 2008 | Kitchen Ranges
Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
EVerstar Portable A/C
I have the same problem how can i solve this problem>
Sep 03, 2007 | Danby DPAC8020 Air Conditioner
Sharp AF-S80FX Air Conditioner Logo
223 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
