Question about Makita 33cc Chain Saw w/16" Bar DCS34-16A
Hard to start, intermittent run - Makita 33cc Chain Saw w/16" Bar DCS34-16A
Intermittent starting issue
If any aftermarket devices were installed and used these wires for power or ground can cause these issue.these wires are the main communication center for the whole car very hard to repair without specialty tools Dealer repair.
May 06, 2014 | Chevrolet Uplander Cars & Trucks
Why is my 1991 olds cutlass calis hard start & spiting & poping when its hot
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Dec 04, 2012 | 1991 Oldsmobile Cutlass Calais
1997 Buick intermittent starting problem
Do you own a scan tool ? One that shows engine sensor data parameters ? Checking sensor data would be the thing to do .
047 Engine Hard to Start or No Start Scan Data for Ignition
Check spec. to factory spec.
048 Engine Hard to Start or No Start Scan Data for Starting Problems .
Sep 20, 2017 | 1997 Buick LeSabre
I have a 93 legacy since new, it`s an "L"4dr auto trans. under117k alway`s maintained,babied `n garaged. Recently had front to back exhaust replace for state inspection. Almost from the day I...
hi it sounds like a sensor may be faulty or getting worn, luckily you dont need equipment to check codes, look under the dash on drivers side and you will see 2 small black plugs close together plug them in with the car off but key on acc and the check light will flash codes, slow then fast. for example if 4 times slow then 2 times fast it means code 42 then just google it for the code meanings
Jul 06, 2011 | 1994 Subaru Legacy Outdoor
Freezer not freezing, refrigertor seems to be working fine. making an intermittent clicking sound
your compressor is not running ..the clicking sound is the compressor start relay ..hard start capacitor ..../relay/overload all in one..will fix this problem call your local appliance parts/or used appliance store for this part ..the wiring is simple //remove compressor cover to view relay ...remove it with screwdriver ..dont worry about breaking this relay .remove it to see 3 terminals ..one is start /one is run /one is common ./look at diagram on the hard start and wire it to the correct compressor pin/terminal then wire the 2 wires off old relay to the power wires to new hard start ...it will work again ...believe me ..the part cost around 20.00 let me know ..good luck../joe/
Aug 28, 2010 | Hotpoint Refrigerators
1998 s-10 2.2l intermittent hard start
because you said it sounds like timing problems i may have an idea. i dont remeber if these have a distributer? but its common for the distributer on the newer GM trucks and i dont know why but its like the spark jumps around inside causing incorrect firing order when trying to start and just gets worse and worse. remove and inspect for build on on rotor and tabs on distributer.
and get back to me with problem
plz rate
Michael
ASE certified
Jan 30, 2009 | 1998 Chevrolet S-10 Pickup
1993 Acura - intermittent fuel pump operation (no start)
I thing it is definitely the fuel relay. I had the same problem. The relay is quite big and it is located and bolted under the dash on the driver side, brown in color. You can't miss it.
Aug 06, 2008 | 1993 Acura Integra Hatchback
Makita 33cc Chain Saw w/16" Bar DCS34-16A Logo
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
