Question about Jandy Laars Lite2 Lj 250,000 Btu Heater
Heater over haeted and shut down - Jandy Laars Lite2 Lj 250,000 Btu Heater
    Top Expert:
  • Jandy Master
  • 5,743 Answers
Check gas pressure if too low will soot up and overheat if ok check manual bypass if spring is bad water doesn't flow through heater it boils and overheats
Posted on Mar 05, 2016
Fan works no haet
One of two things may be happening. The heater core may have gone bad or the heater switch may be broken. Hope this helps
Mar 25, 2015 | Cars & Trucks
Have atwood ehm6sm not getting hot enough, mixing valve seems to be in correct position. any electrical issues I should know about?
This unit is only 110v and gallon, your not going to get alot of hot water but you could check what temp it's set for. You might have a bad element. If you have the haet exchanger part of it hooked up, you could run your engine and get a better supply of hot water.
Jun 20, 2011 | Attwood Atwood Marine Water Heaters...
When haets on blows cold.changed thermostat and put in antifreeze.
your waterpump could be bad an not circulating the coolant. or the heater core or raditor is clogged.
Jan 04, 2011 | 2001 Pontiac Montana
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
Why would my heater not work? I have a 1994 Ford Escort.
Does the fan blow but no haet comes out or are you not getting any temp. reading on your gauge?
Dec 10, 2009 | 1994 Ford Escort
Strong antifreeze smell when running the heater in 99 silverado, can't see a leak, strong smell, is heater core bad
Usually a smell of antifreeze in the cab when the heater is running is a sign the heater core is leaking. Just becasue you dont see a leak at this time doesn't mean there isn't one. It might small enough that the haet from the core is burning off the leaking antifreeze. I would suggest replacing the core before you get in one day and there is a puddle on your floorboard. Or if you go to a local parts store and rent a cooling system pressure tester, wait until the vehicle is cold, pressure the system to 12 lbs and then check for leaks. Hope this helps you out......
Oct 22, 2009 | 2001 Chevrolet Silverado 1500
HEATER WILL START AND AFETER A FEW MINUTES WILL STOP HAETING
DO YOU HAVE A CODE? CHECK IF ALL THE BURNESR ARE ON IF NOT MUST BE CLEAN.ALSO THE PRESSURE AT THE FILTER IS BETWEEN 10-18 PSI IF NOT CLEAN THE FILTER
Sep 04, 2009 | Hayward Pool & Spa
Central haeting keeps turning on when itself
Change your air filter, if the system has to work too hard, it will over heat. If the filter is allowing air flow and the system still shuts off it is the thermostat. Keep in mind the Thermostat gauges the temperature where the thermostat is located, if its next to a running fireplace it will think your entire house is that temp.
Feb 02, 2009 | Water Heaters
2003 Ford Ranger Edge Heater problems
LOW COOLANT TOP OFF With cap off after Idling fro 10-15 mins with haet temp selector switch on HOT
Jan 13, 2009 | 1998 Ford Ranger SuperCab
Over haeting
Had the same problem....turned out to be the water pump.
Jan 13, 2009 | 1999 Pontiac Montana
Jandy Laars Lite2 Lj 250,000 Btu Heater Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
