Question about Craig Powerplay 250 Car Amp
How to install Craig power play 250 car audio amp. Need wiring diagram if available.
Got a 1987 ford 250 economize van 5.8 liter4v h.o. engine. Need the distributer cap wire diagram
Craig, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
1987 ford 250 economize van 5 8 liter4v engine firing order diagram Google...
Wants to start but wont Ford Truck Enthusiasts Forums
1987 ford 5 8 liter 4v engine firing order diagram Google Search
Mar 19, 2016 | Ford Cars & Trucks
I want to install a subwooper into my toyota altis 20007 model but theres no audio out connections in the car audio. how can i fix this problem. i want a diagram on the car audio system of the toyota altis...
You can visit scosche or PAC to see if an "add an amp" wiring harness is available. It will adapt to have power, remote turn on, and RCA outputs. If this is not an option, you may need to look into installing an aftermarket radio. hope this helps.
Aug 21, 2011 | Car Audio & Video
Jbl audio wiring diagram/schematics/color codes/ect.ect.ect.
http://documents.victorytechnologies.com//documents/product/2322.pdf
Mar 15, 2010 | JBL BP1200.1 Car Audio Amplifier
I need the wiring connections for a Craig amp #V501
THE SOLID RED IS USEUALLY UR POWER NOT SURE ABOUT RED WHITE WIRE ON AN AMP THATS A FIRST FOR ME AND IVE DONE LOTS AND LOTS OF CAR AUDIO INSTALLS
Feb 08, 2010 | Car Audio & Video
I NEED FREE DIAGRAM OF CAR STEREO AND AMPLIFIER
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Jun 14, 2009 | Alpine CDM-7854
CDX-SW200 plays the stereo but not the CD's
sounds like you connected the amp turn on lead to the power antenna wire coming from the deck, so the amp turns on when you have the radio on, but turns off when playing cds. you need to connect the amp turn on lead to the amp remote wire.
Jun 11, 2009 | Sony CDX-SW200 AM/FM Compact Disc...
1 10 jl jl 250/1 mono block amp cuts off an on help
your subwoofer is wired incorrectly to your amplifier. Figure out which ohm load of subs you have and then what ohm load options your amp is stable at. Next go to either the Crutchfield website. find their learning center. go to subwoofer wiring diagrams. or go to www.the12volt.com and find their section on it
Jun 11, 2009 | Jl Audio 250/1 Car Audio Amplifier
Craig Powerplay 250 Car Amp Logo
51 people viewed this question
Top Craig Car Audio & Video Experts
xxxxxx xxx
Are you a Craig Car Audio and Video Expert? Answer questions, earn points and help others
