My battery shows 95% when connected to a power source, but when I remove it, it powers down and cannot run on battery power.
    Master:
  • 328 Answers
Battery charging life cycles are almost finished you sucked up all the chemicals on it you got to replace it or keep using it like that
have a nice time sir .
Posted on May 29, 2011
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Power schemes battery
Chances are that your battery doesn't / wouldn't hold a charge anymore. The laptop runs off battery power. When it is plugged in, the AC power "goes right through the battery", to support the laptop's operations. When the power cord is unplugged, and the battery doesn't hold a charge, the laptop will shut down, as your battery is (too) low to continue supporting the laptop's operations.
The easiest way around this problem is to get a new battery for the laptop.
If your battery is (quite) new (and a Lithium battery), you may wish to see if you can "revive" the battery's "life" ... first by depleting the battery (completely), then charging it (until it shows it is full, plus a couple more hours), and repeating this process a few times. If you're lucky, the battery will slowly/gradually start to hold some charge, but, don't expect it to be very long.
The (preferred) way to use re-chargeable batteries is to charge it fully, unplug it from the external power source, use it until it is depleted, then plug in the external power source to charge it up (fully) again .... and NOT to keep it on a power source all the time.
Oct 26, 2013 | Lenovo G500 59373039 Intel Core i5-3230M...
I have a HP Omnibook vl6200 running WinXP Pro. Works properly on the AC power, but shuts down if AC power is removed. Installed a new battery pack and battery monitor software showes battery is fully...
The first thing is to check if your battery is still okay by taking it off then measuring if it has some electric charge. If you are able to use a measuring meter then that's super but if you are not able to you can use a 24V truck light bulb and connecting with 2 wires to the positive and negative side of the battery. If it lights up brightly then the battery is okay. If it's got no electric charge then there are two possibilities either the battery is not okay or the charging system of the laptop is not working. Supposing your battery is okay. Then you need to have your laptop checked on the charging system. Remember laptop batteries do not last forever they actually deteriorate to until they are completely unrechargeable. So the Battery is my prime suspect.
Oct 07, 2011 | HP OmniBook XE3 Notebook
I am connecting a 1000w Cobra Power inverter to a deep cycle marine battery that will be used to run small appliances while camping. How do I properly connect the inline circut breaker for maximum safety?
The breaker goes in in series.
So, that means (for example) you remove the hot wire to the unit, from the positive battery power source, and hook this wire to one side of the breaker, then connect the other terminal to the positive battery power source.
This will stop current flow if anything over 40 amps happens on the line.
You actually can hook the breaker anywere along the circuit, but the closer to the power source, the better you are protected.
Mar 02, 2011 | Inline 40 amp. In-Line Circuit Breaker
It shows message as "turn on camera" while try to
Assuming your computer has a built-in iSight camera - which should be all Macs made since 2006 except for the Mac Mini and Mac Pro (not MacBOOK Pro!) - your camera
a) May not be being seen by the computer. Check Apple Menu > About This Mac > More Info > USB and see if "built-in iSight" is listed in the USB Device Tree. If it is, then it may be being used by another application that uses a webcam, like Skype, iChat, or what have you. If it IS NOT detected:
b) Try resetting your SMC:
Resetting the SMC on Mac portables with a battery you can remove
Note: Learn about removing the battery on MacBook and MacBook Pro.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Resetting the SMC on portables with a battery you should not remove on your own
Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
  2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
  3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
  4. Release all the keys and the power button at the same time.
  5. Press the power button to turn on the computer.
    Note
    : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
  2. Unplug the computer's power cord.
  3. Wait fifteen seconds.
  4. Attach the computer's power cord.
  5. Wait five seconds, then press the power button to turn on the computer.
Dec 20, 2010 | Computers & Internet
I put my acer aspire one laptop into standby by putting down the monitor which automatically lock the laptop but then when i use it again the monitor is dark and i cant see anything. the power is on and i...
ok, press the Power button on the Laptop once, and if nothing happens, press the power button again but this time hold it down until it goes off... then remove the battery for 2 minutes, after that put the battery back and press the power button, it should power on and the monitor will show. (Do not plug into power source during all the above process).
Bams Tech.
Dec 02, 2010 | Acer Aspire One Netbook 8.9" Notebook
I had been using my computer when all of the sudden screen went black and I could hear the windows shutting down. I thought maybe my battery was dead and I was not paying attention, so charged it. But when...
Do a hard reset by turning off the computer and removing the battery and unplug the AC adapter. Without any power source, press and hold the power button and put everything back after. Power on the computer again, if it does not work, try to connect your laptop to an external monitor. If it shows some display it means that the LCD monitor of your laptop has gone faulty.
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
I have just purchased a 95 Aura very low in price, none of the windows go down, this is unusual for all of the windows to not work. Is there something that I am missing to repair this
The first thing to check, is the 25amp circuit breaker located in
the fuse block under the back seat near the battery. If that checks out, remove the master switch from the drivers door panel and using a 12v test light or volt meter check for power at
the brown wire connection, grounding the test light to the black
wire connection. If no power, try another ground(door jamb/pillar)
if it's got power now, repair bad grnd. If not, repair bad pwr. feed
or use a different power source. But if there is power to the
switch and it won't work, replace the switch.
Hope this helps.
Aug 14, 2010 | 1995 Oldsmobile Aurora
The battery light remains on unless the power
If the computer will run on battery alone, and you cannot fully charge the battery, it's probably time for a new battery. The life expectancy is 2-3 years if treated right. Some people get a lot more life than others.
Here's a suggestion: when you run your computer, let the battery run fully down at least once a month. Do not leave it plugged in to line power all the time. Do not keep charging it when it is only a little bit discharged.
Jul 01, 2009 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
David Payne
David Payne
