Question about GE Dryers
Dryer makes a sqealing soundor squeaking sound while running with clothes in dryer take them out and let run empty it is quiet.
    President:
  • 3,074 Answers
Drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Posted on May 29, 2011
Kenmore clothes dryer squeaks loud to get going
Sounds like a bearing or the drive belt. Try turning the empty drum by hand. If it sounds normal you probably just need to replace the belt. If it make strange sounds when you turn it by hand then its probably the bearing.
The belt isn't a big deal but a bearing probably is.
Feb 16, 2013 | Dryers
MAYTAG QUIET PLUS II DRYER IS SQUEAKING
It seems to me you need a new belt that go over and around the drum in witch you put the cloth first you have to go on line and find the rubber belt to replace it, may need make and modle or part number. you will have to take the top off first by removing the screws and then the front panel - the front panel has the electric on/off switch connected to it so be careful not to pull it apart. The rubber belt fits around the drum and then is attached to the pulley/drive motor. have a vacume handy to clean up the worn off pieces from the damage belt. Reattache the front panel and top of the dryer.
Dec 25, 2012 | Dryers
Dryer making thumping noise when drying clothes and while running empty.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 17, 2011 | GE Dryers
Dryer squeaks when running with clothes in but not when empty
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 30, 2011 | GE DBXR463EDWW Electric Dryer
I have a maytag dryer model MDE3757AYW that is making a loud squeaking/sqealing noise. the drum still turns and dries the clothes though.
heatman101
Oct 02, 2010 | Maytag Dryers
Squeaking Sound like the fan belt needs replacing.
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Apr 05, 2010 | Hotpoint TDL14 Electric Dryer
Dryer makes loud squeaking sound when spining
how old? Dryers squeak for one of 3 reasons..bad belt, bad motor or drum rubbing against dryer framework.
run it empty...intermittent squeaks usually are the drum...something's bent
continuous- is there any burning smell? If so, most likely the motor, if not, possibly the belt.
Open the top (most have screws or can just be pried open) and watch it run...identify the source of the sound if possible
try spraying the belt and motor with a little wd-40 and let it dry for a day, then try again.
If that doesn't help, repairman or new/used dryer...probably better off to find a decent one off of craigslist b4 paying to repair an already faulty machine
Feb 22, 2010 | Kenmore 62802 Electric Dryer
Magic Chef Dryer runs fine but Squeaks loudly
this sounds like a drum guides that need replacing soon.
Jun 17, 2009 | Magic Chef CYG4000AWW Gas Dryer
Squeak
check what is called an idler or tension pully. lubricating these can somestimes help but only a temporary fix. actualy its not a fix. only makes it quiet. replace them or call service these parts are easily accessable
Apr 25, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
96 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
