Question about Liebert (GXT2-10000T230) (GXT2-10000T230) UPS System
System is not starting - Liebert (GXT2-10000T230) (GXT2-10000T230) UPS System
How do i shut mac off then put start up disk in ?
Simple. Load the Apple System start-up disc first while the computer is running. You should see its icon on on the screen. Then select restart from the Apple Menu on the top left of the screen. Hold down the C key as it reboots. You will now boot into the start-up disc. This method also applies to Disc Warrior and other tools. Alternately, with the computer already running, insert the Apple System start-up disc then go to System Preferences also under the Apple menu, Under the start-up disc icon, select your apple system icon and restart.
Third alternative. With the computer running insert Apple System start-up disc. Restart the computer. Before the chime, press and hold the option key, left-hand bottom side of the keyboard to the left of the Apple (Command) key. You will see your system HD icon and the screen as well as your Apple System disc. Click on the System Disc and that will boot the machine.
Jul 09, 2014 | Apple iMac G4 Desktop
Tip
How to perform System Restore on Windows XP
System restore it is often the first tool to solve problems on your computer.
Each time you do an update, or install a new software, system settings will be modified, sometimes this can cause Windows operative system malfunctions.
System restore to a date before you had the problem can repair most Windows faults.
Here is the how to:
Before starting System restore close all this running applications.
You can start System restore from start menu:
1.
Click Start.
2.
Point to All Programs.
3.
Point to Accessories.
4.
Point to System Tools.
5.
Click System Restore.
6.
Follow the instructions on the wizard.
You can also start system restore to create a restore point before making an important change to the system.
For example you can decide to create a restore point before installing a new anti virus, or downloading Internet Explorer update.
on Aug 27, 2008 | Microsoft Windows XP Professional With...
System restore for systemx s51g23013ga3th0
System Restore or System Recovery?
System Restore does not delete your data.
System Recovery deletes everything and sets your system back to when you first purchased it.
To launch System Restore you can:
Windows XP - Click Start/Programs/Accesstories/System Tools/System Restore
Windows Vista - Click Start/Programs/Accessories/System Tools/System Restore
Windows 7 - Click Start then in the search box type "System Restore" (without the quotes) and the system will show you the link to click above in the search results.
For System Recovery - RTM - Read The Manual
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for Manuals. Search the manuals for how to start the Recovery.
May 06, 2012 | Computers & Internet
Have a hp cam trying to install it on an ibm pc
I suggest try to check what type of Operating System you have. After you verify your Operating System, Download the driver from the manufacturer website.
Here's how you can check your Operating System:
Windows 7
Start->Control Panel->System and Security->System (in Category View)
Start->Control Panel->System (in Large or Small Icon View)
Vista
Start->Control Panel->System and Maintenance->System (Default View)
Start->Control Panel->System (Classic View)
Apr 16, 2011 | Computers & Internet
I need to bypass my viper remote start system as I
Check ur battery take out any extra wire that hook up to the battery.The system should have no power to the Viper system.U should able to start ur car without the Viper remote.
Apr 21, 2010 | Viper Security and Remote Start System...
I'm trying to install a c4380 wireless printer with windows 7 but it won't take, says it's not supported by software
  1. First find out if you are using 32 or 64 bit
  2. Click Start
Collapse this imageExpand this image vistastartbutton.jpg , type system in the Start Search box, and then click system in the Programs list.
  1. The operating system is displayed as follows:
    • For a 64-bit version operating system: 64-bit Operating System appears for the System type under System.
    • For a 32-bit version operating system: 32-bit Operating System appears for the System type under System.
Method 2: View System Information window loadTOCNode(4, 'moreinformation');
  1. Click Start Collapse this imageExpand this image vistastartbutton.jpg, type system in the Start Search box, and then click System Information in the Programs list.
  2. When System Summary is selected in the navigation pane, the operating system is displayed as follows:
    • For a 64-bit version operating system: x64-based PC appears for the System type under Item.
    • For a 32-bit version operating system: x86-based PC appears for the System type under Item.
  3. Then go to hp website and download driver for windows 7 for correct bit version.
  4. Unistall old driver install new.
Nov 28, 2009 | Xerox DocuColor 12 Printer
Always when printing out from my email it takes very long until it starts to print ,any tip ??
Open control panel.
Start->controlpanel ->printer and faxes.
Right click on printer then click on property.
Click on advanced
Then enable start print immediately.
Also go to start ->run type "cmd" in run then press enter
Then type in command prompt "net start spooler"
then press enter.
Then check.
If still same issue then change usb cable and also uninstall old driver then reinstall driver.
Let me know if you need further assistance.
Thanks.
Oct 25, 2009 | Computers & Internet
System restore
For windows XP , Try start - run - msconfig - launch system restore
For windows vista
Click on start - Type system restore in start search - Click on system restore at the top - Wait for system restore to launch.
Sep 18, 2009 | Dell Dimension 4600 PC Desktop
I would like to restore my system. i do not know how to start it
click on start, all programs, accessories, system tools, system restore,
once u open system restore, click on next, select a date to which u want to restore the system and click on finish, system restore will happen and system will restart, if successful it would show the msg system restore successful
Nov 14, 2008 | Gateway Computers & Internet
System restore
Start the System Control Panel applet. Select the System Restore tab. Clear the "Turn off System Restore on all drives" check box to enable System Restore, or select this check box to disable System Restore. Click OK.
An alternative to the usual method of enabling and disabling Windows XP's System Restore feature is to use the registry. To use this alternative, perform the following steps: Start the registry editor (regedit.exe).
Go to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore.
If a "DisableSR" value doesn't exist, go to the Edit menu, select New, DWORD value, and create the value.
Set the value to 1 to disable System Restore or 0 to enable System Restore.
Go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\sr to prevent the System Restore service from starting.
Double-click Start, and set the value to 4 to stop the service from starting or to 0 for normal startup. Close the registry editor.
Feb 07, 2008 | Computers & Internet
Liebert (GXT2-10000T230) (GXT2-10000T230) UPS System Logo
27 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
