Question about Microsoft Windows XP Home Edition
Beeping tower annoying
How do i stop my beepin of the tower? is it the mother board? i reboot it and it still works and everything but everytime i go an use the net and my msn it beeps i cant work on them without it beeping at me all the time.....how do i stop this problem .... ???? do i have to defry it?
  • 59 Answers
Did you check your processor fan? . i had a computer in which th eprocessor fan was jammed and was not working and it was beeping. i fixed the processor fan and the beep was gone
Posted on Aug 24, 2008
Had to put my motherboard in a new case, and i have tried to follow the manual but i am still lost as the pc is not powering up? i think i have connected everything correctly but still not getting power,...
make sure the aluminum tower is covering black chip on mother tight with metal clasp on alumnium tower is covering chip make sure fan is properly tight on mother board make sure battery in mother board is in and make sure fuse is in mother board then restart push f2 and start your reboot....
Feb 17, 2011 | Foxconn 760GXK8MC-RS Motherboard
PC will not power up, and power supply is working. The Mother board is in a HP Pavilion a1473W
A few things to check:
Firstly, scheck that there are no blown, or bulging capacitors on the motherboard, this board had a tendency to fail due to these going.
Then, remove all non-essential peripherals and leave only one ram module in the board, try to boot, if it does boot, replace all in turn, booting each time you do so and identify the faulty component.
If it will still not boot, listen for any beeps you may get.. note them down and if there are any, repost your query.
Things to try now:
Remove the cmos battery, leave out for 30 seconds and then replace, try to reboot.
Then try removing all the ram and rebooting with no ram to see if there are any beeps. If it does beep there is the chance that there is still life in the board, if not, the board is probably dead.
Finally, remove the board and power it up on an antistatic surface, using a temporary switch to trip the motherboard pw switch ( or use a screwdriver on the two terminals briefly). If it does power up now, check the switch from the case to the motherboard for breaks or damage, replace / repair and rebuild the tower
Jan 28, 2011 | EliteGroup RC410L/800-M2 (V1.0)...
MY PC RESTARTS WHEN IT SHOWS BIOS,,,,,,,,,,,,,,,,,,,,,,,,,,IT ALSO SPEEDS UP PROCESSOR FAN AND SHUTS DOWN
I'm by far no computer tech, but I'm not a newbie either. I had a similar problem a few years back with my GX280. In order to keep my 1yr old son out of my computer tower, I had hast-fully and unknowing incorrectly installed a new stick of ram. Installed the ram powered the machine back up, "OK son time for bed" By the time I got half way down the hallway I knew something was wrong. I have never smelled boiling or burning bleach before, but thats what grabbed my attention. Immediately I ran back to the computer and literally pulled the power cord from the wall, but it was already to late. The problem... That unknowingly, improperly installed stick of ram was not fully secured by the hold down clips and was slightly raised half in, half out of the slot. The ram stick was hotter than the surface of the sun, yet undamaged. My mother board wasn't so lucky. I powered the machine on again, it beeped at me 4 times 1 long tone 2 short tones and 1 long tone blank monitor and did nothing else. The beeps I thought probably the computer cursing me in its own dll language. I again pushed the power button to reboot. when the computer rebooted, again with the beeping accompanied by the cpu fan exponentially. I didn't and couldn't see the physical damage to the board until I removed the board from the tower itself. I noticed on the underside of the mother board I had burnt a blazing trail from the ram bus slot to the main power slot where the wire harness connects to the board from the power cube. This problem the cpu fan running away with itself can also happen when a component is improperly connected, or not connected at all. Check ALL your CONNECTIONS. If that doesn't work, you might have some sort of hardware problem.
Hope this works for you, or at least helps you out.
Good luck, have a great day, and remember computers are like vehicles you own one and eventually your gonna have a problem.
:Crabby
Sep 22, 2010 | Dell OptiPlex GX280 PC Desktop
Computer powers on, no beep, monitor is blank
open the tower, on the mother board you will find the RAM card approx 6 inches long, take out the card and restart the comp, you should get the beeping sound and the mother board is fine, if no beep that indicates the motherboard has gone bad.
place the ram card properly into the same slot and then restart the computer. NOTE while putting your hand into the comp components always make sure that the pwr cord is pulled out or else you will get shock.
also check the cord at the back of the harddrive should be fixed properly. take it out and refix it at both ends . probable cause is there is some loose connection of the cord or the RAM.
May 10, 2010 | Computers & Internet
Same problem, extremely annoying
Go to Speakers properties > levels > mute pc beep.
That should stop the annoying power beep but not the startup jungle.
Regards.
Jul 29, 2009 | Lenovo 3000 V100 Notebook
Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
Jun 18, 2009 | Adidas Candy Digital watch
Tower is beeping and monitor on/off switch is blinking
If the computer has been moved recently, I would chack the Video card in the mother board to make sure it is seated in the slot all the, Unless you have on board video.
Apr 12, 2009 | Dell Inspiron 531s Desktop Computer
File error
Press Enter and 6 at the same time. It should reboot the system immediately and will stop the annoying beeping!
Oct 19, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
