Question about Haier HC48C1VAR Central Air Conditioner
Haier HR30C1VAR central air unit is not blowing at full capacity the unit is full of freon
    President:
  • 3,074 Answers
Clean the coils, with cleaner or a garden hose, disconnect power first remove top and spray from the inside out, not to hard as it will bend the fins closed, you will see dirt come out and pray until it is clean. Good Luck Tim
Posted on May 29, 2011
I need to know how much Freon my fedders central air takes.It is 7 years old
On the unit name plate it will say factory charge of weight and type or refrigerant.
Aug 21, 2013 | Haier HPR09XC7 Portable Air Conditioner
I have central air and I was wondering how do you put freon in it because its not blowing out cool air
Is the compressor starting? On the outdoor unit you will see a large copper pipe and a small copper pipe. Is the larger of the two cold to the touch? wet? Just because a central air system is not blowing cool air does not mean it needs freon. If you have clogged filters it cannot do an air exchange. So, I would recommend checking the easiest things first before adding Freon.Most people make the mistake of adding Freon and overcharge their system. In a low load situation you can slug the compressor with liquid and your system is ruined. If you do have to add Freon it indicates that you have a leak. An AC System is a closed system and if it is working properly you should not have to add Freon.
Aug 03, 2011 | Whirlwind FH-778 Air Conditioner
My Haier window airconditioner dose blow cold air even on max do I need freon and can I replace freon my self, model no.# HWF05xCA
dcorey, Freon is no longer used. R134A refrigerant gas is what is now used. Unless, you have all the proper equipment to purge the system and then introduce the refrigerant gas into the compressor, on the high side and the low side, it's not a DIY project. However, you can contact Haier Consumer Support 1-877-337-3639 for an authorized repair center in your area.
Hope this helped you.
Jul 07, 2011 | Haier HWR08XC7 Air Conditioner
What supply house sells haier air handlers in Atlanta ga
any 4 tonnes air handler will fit if you respect de gas for the unit if r22 than than r 22 air handler if r410 than r410 air handler you can put r410 air handler if r 22 not avalable but be sure that expension valve is compatible.
Dec 13, 2010 | Haier HC48C1VAR Central Air Conditioner
My heat unit will not blow hot air unless we go outside and hit a button on the back bottom of the unit. Once we do that it will blow hot air for that cycle. when it is time for it to come on it is cold...
If it does not have a furnace or heating elements for heating, then it is a heat pump, which is rare for a central AC system, but makes sense of the fact that it blows warm air when you reset the pressure switch, which may indicates freon pressure charge problem if your AC system has a reverse valve and uses freon to for heating (heat Pump).
Do you get heating when outside unit runs? if you do, check freon pressure levels and top up to required pressures. The button you depress is a pressure reset switch ... that is if your AC system is a heat pump ... which, as pointed above, it is not common for central ACs.
Nov 07, 2009 | Ruud Central System Air Conditioner
Compressure and fan not coming on, contactors pulled in from 24v .light blinks 3 times lps hps are jumped add freon still not working.
Sounds like your breaker is tripping for your outside unit. Compresser could be grounded out or a breaker problem.
Oct 08, 2009 | Haier HC48C1VAR Central Air Conditioner
Window unit haier a/c (sorry, not sure model type, but it has a remote) isn't blowing cold (cool, but not cold) air and it sounds like the motor is just running in a 'fan' capacity. what can i do to get...
have your unit cleaned first, if it is cleaned and still the trouble persist. check if the compressor works. if not check the running capacitor for leak. if all are working fine have your unit system reprocess.
Aug 01, 2009 | Heating & Cooling
My furnace is blowing cold air
Is the a/c a heatpump also? Is the furnace gas, electric? Thanks
Dec 06, 2008 | Haier Heating & Cooling
Central a/c
check to make sure that the kids didn't change any other settings. Is the themostat still set for cold not hot? Also check the temp setting. Hope this helps.
Sep 11, 2008 | Heating & Cooling
Haier central ac unit problem
HEY,Kim, connect the red hose with the crooked end on the small line service vale and the blue crooked end to the fat line service valve and read the preassure now. Also the yellow line connect to the refrigerant tank...!
Jul 09, 2008 | Haier Energy Star ESA3183 Air Conditioner
Haier HC48C1VAR Central Air Conditioner Logo
137 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
