Question about Keurig Platinum B70 Coffee Maker
Wo'nt brew or anything else. Have descaled regularly but then it just quit...Help
  • Keurig Master
  • 43,501 Answers
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Posted on Sep 05, 2011
Why is my delonghi ec702 brewing slowly even after regular descaling? The water barely drips out even with no coffee in the filter.
I had same problem, now gone. Check your water Intake filter in the water reservoir. If it looks discolored, it may be clogged. I used a brush and plain water to clean it off, and now machine works like brand new!
Jul 28, 2014 | DeLonghi EC702
Nuova Simonelli Oscar No Steam After Descale
when you descale your machine, how did you drain the water? I think the scale particles clogged your steam pipe. And also if you had put a lot of descaling chemicals, this chemicals can eat up the heating element. If you can remove the heater and check it physically and also cleaning and removing the scale inside the tank will help.
Jul 15, 2012 | Nuova Simonelli Oscar Coffee Maker,...
Descaling won't brew
Desacle now or it won't reset to factory settings.
Mar 11, 2012 | Keurig Platinum B70 Coffee Maker
My capresso coffeeTeamGS maker will grind the coffee but will not brew it????
Hi. Your brew unit is by passing the water that is supose to brew. You'll have to clean the brew unit. Jura brewunits are not easly removeable, + you can't buy parts unless your a authorised repairer. Try doing a manual descale cycle. You need to add descale solution to the watertank and operate the hot water and steam functions, which allows the solution to enter the system. Open these functions until water and steam are pumping through, then switch them off and let it sit for a few minutes, then repeat the above 5 or 6 times. This allows the solution to break up any build up. OK, now you have manualy descaled the steam and hot water circuits. Now allow the machine to try and make coffees." we are only trying to clean the machine, so dont drink the coffee." Try 5 or 6 times to see if this is starting to brew better. WE DO NOT LEAVE THE DESCALE SOLUTION IN THE MACHINE. We need to flush the system with fresh water as per above. Descale is corrosive, so we need to get it all out. I hope this has worked for you, other wise you'll have to take it to an authorised repairer. Dazza REPAIRER
Sep 24, 2011 | Jura Capresso CoffeeTEAM GS 46405
I have had my Kuerig coffee maker for over a year now which I believe means it's no longer under warranty. However, I paid quite a lot for it so I'd really like to see if I can have it repaired...
unfortunatly keurig treats any home model as throwaway once warrenty is up. They even do the same with mostcommercial models. By the sounds of your problems its time for a new one. sorry. try for a b145 or b150 they are a little more robust.
Sep 05, 2011 | Keurig Platinum B70 Coffee Maker
1. It sometimes doesn't give me a full cup as per the setting. 2. It was hardly working and I descaled with vinegar - it worked while I cycled the vinegar through but then quit working entirely
If your brewer is not brewing the full amount selected, it may be caused by the following:
The exit needle is clogged by coffee grounds or cocoa mix. Please refer to the K-Cup Holder cleaning instructions.
The brewer may need to be de-scaled. Please refer to the de-scaling instructions.
The removable water reservoir was removed during brewing. Place the water reservoir back onto the brewer and perform a cleansing brew without a K-Cup.
First try to make a descale maybe repeat it the next day.
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/FD69E91A51CA41BEBF4CCAA138325BBF.ashx
Then try also this
http://www.youtube.com/watch?v=DqRs4Ott21s
Jul 04, 2011 | Keurig Special Edition B60 Coffee Maker
Display reads descale, what can i do to fix this
Descaling the Brewer Mineral content in water varies from place to place. Depending on the mineral content of the water in your area, calcium deposits or scale may build up in your Brewer. Scale is non-toxic, but left unattended, it can hinder the Brewer's performance. Descaling your Brewer helps maintain the heating element and other internal parts of the Brewer that come in contact with water.
NOTE: Do not use water that has been treated by a 'water softener'. The increase in sodium levels in the water can cause scaling in the brewer and hinder its performance.
The Brewer should be descaled every 3-6 months to ensure optimal performance. It is possible for calcium deposits to build up faster, making it necessary to descale more often. This Brewer is equipped with sensors to detect when scale buildup is interfering with the performance of the Brewer. When this is detected, the LCD screen will indicate 'DESCALE'.
NOTE: The Brewer will continue to operate even when the LCD screen indicates 'DESCALE'.
However, if you do not descale the Brewer soon after it is displayed, continued scale buildup could damage the Brewer. If this occurs, 'DESCALE' will begin to flash, alerting you to the potential damage to the Brewer if you do not descale immediately. Promptly follow these steps each time the LCD screen indicates 'DESCALE' to ensure that the Brewer functions optimally.
1. 4459906401_be71bd1933_t.jpg Empty the Water Tank and refill it with vinegar, filling up to the MAX mark on the water tank viewing window. 2. 4459906749_2d2d8c9472_t.jpg Place a 12 oz. or larger ceramic cup (do not use a plastic cup) on the Drip Tray. The Drip Tray and Drip Tray Plate can be removed to accommodate taller mugs and travel mugs. 3. 4460685206_41a39b1eab_t.jpg Select the largest brew size (11.25 oz. serving) by pressing the button on the control panel. 4. 4460685734_41eef702a7_t.jpg Run a cleansing brew without a K-Cup®. Pour the contents of the cup into the sink. 5. 4459906625_e723d37450_t.jpg Repeat the cleansing brew process until the Water Tank is empty, pouring the contents of the cup into the sink after each cycle. Remember to raise and lower the Safety Locking Arm between each cycle so the control panel buttons illuminate. 6.
Let the Brewer stand for at least 4 hours while still on. 7. 4459906401_be71bd1933_t.jpg Rinse the Water Tank thoroughly and fill with fresh water. 8. 4459906749_2d2d8c9472_t.jpg Place a 12 oz. or larger ceramic cup (do not use a plastic cup) on the Drip Tray. 9. 4460685734_41eef702a7_t.jpg Run a cleansing brew without a K-Cup®. Pour the contents of the cup into the sink. 10. 4459906625_e723d37450_t.jpg Repeat the cleansing brew process until the Water Tank is empty, pouring the contents of the cup into the sink after each cycle. You may need to perform additional rinse cycles if you notice any residual taste.
Remember to raise and lower the Safety Locking Arm between each cycle so the control panel buttons illuminate. 11. 4443328562_50d07cb55b_t.jpg Disconnect the power plug from the wall outlet for at least 15 minutes, then re-plug the power cord into the wall outlet. The machine is now ready to use.
NOTE: If the LCD screen continues to indicate 'DESCALE' after completing the process, repeat the 'Descaling the Brewer' process.
Check out this link for support on your unit.
http://brevilleusasupport.com/product/bkc700xl#2044
May 25, 2011 | Breville BKC700XL Stainless Steel
Low water pressure, so takes ages to produce a cup of coffee. Has been de-scaled regular
If you get good flow with the portafilter out, you may need a new pump. When you descale do you run the descaler through the brew head? That is one problerm that people make is running the descaler through both the wand and the brew head. Sclae will build up in the pipe in the brew head and restrict it.
Feb 28, 2010 | FrancisFrancis! X1 Espresso Machine
Descaling
No, it does not quite clean both boilers, even though they are connected, you will have to use the preground chute if your machine has one, if not then grind and brew method will work. The reason, you want to get some of the cleaner through the white plastic valve behind the brewunit and the fitting that connects it to the boiler.
Feb 21, 2010 | Saeco Vienna De Luxe Espresso Machine
Keurig Platinum B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
